    MMM-QuotesFromReddit
    magic mirrorquotesrandom
    10 Posts 4 Posters 5.0k Views 4 Watching
    • bthuilotB Offline
      bthuilot
      Description
      Picks a random post from /r/quotes and displays the title meaning a random supply of quotes! Ideally meant to replace the compliments module.
      Download
      [card:bthuilot/MMM-QuotesFromReddit]
      Mykle1M 5 2 Replies Last reply Reply Quote 0
        Mykle1 Project Sponsor Module Developer @bthuilot
        @bthuilot said in MMM-QuotesFromReddit:
        Blasphemy! ;-)
          Spankythemusical
          Is there any way to add a css file to control the font size? While this is an unbelievably wonderful module, the quotes come in so large that it sometimes takes up half the screen.
            Mykle1 Project Sponsor Module Developer @Spankythemusical
            @Spankythemusical said in MMM-QuotesFromReddit:
            The readme for the compliments module:
            https://github.com/MichMich/MagicMirror/tree/develop/modules/default/compliments
            Configuration options
            classes
            Override the CSS classes of the div showing the compliments
            Default value: thin xlarge bright
              Spankythemusical
              While it is entirely possible that I’m overlooking something simple, adding that config to the MMM-QuotesFromReddit section of config.js has no effect.
                @Spankythemusical
                My mistake entirely. I thought we were talking about the compliments module.
                in your custom.css file you could try adding this:
                .MMM-QuotesFromReddit thin.xlarge.bright {
                  font-size: 21px;  /* Adjust accordingly */
                  Spankythemusical
                  No problem. I was sure it was something that I was doing wrong. So in my MMM-QuotesFromReddit.js file I added:
                          getStyles: function () {
                                  return ["MMM-QuotesFromReddit.css"];
                  Then I created a MMM-QuotesFromReddit.css file and put in the line that you wrote. Still no change. I’m going to continue messing with it, but any additional help would be unbelievably appreciated.
                  EDIT: I figured it out. I changed the line:
                  wrapper.className = "thin xlarge bright";
                  to:
                  wrapper.className = "small";
                  Works like a charm!
                  bthuilotB 1 Reply Last reply Reply Quote 0
                  • bthuilotB Offline
                    bthuilot @Spankythemusical
                    @Spankythemusical Hey sorry for the late response, I will make it so that you can change that in the config file soon and not need to edit the js file.
                      Spankythemusical
                      @bthuilot It’s no big deal. I honestly don’t know if the issue I was having was the same for anyone else. Just glad I was able to find a workaround so that I could use your module. Thank you for the work!
                      • 5 Offline
                        5M3D1N4 @bthuilot
                        @bthuilot I know this is years later but is this module not available anymore?
                        • bugsounetB bugsounet referenced this topic on
