    MMM-NOAA - Another Weather Module
    690 Posts 77 Posters 2.7m Views 70 Watching
    • cowboysdudeC Offline
      cowboysdude Module Developer
      @Nystro0m and @pjkoeleman
      Thank you both!!! IT was doubled, not sure how that happened but all fixed!! :)
      Nystro0mN 1 Reply Last reply Reply Quote 0
        Johans
        installed module last night, settings all according the help file, but nothing is displayed.
        Switched back to the wunderground module, that’s working fine.
        any idea. I suppose that when the API key is working with the Wunderground module it should work with yours too.
        what information do i need to provide for further investigation - also tell me how to get that. (I’m newbee - sorry for this - i’m in a learning process )
        (language was set to “nl” and then changed again to “en”).
        And I see module is loaded, but not displayed.
        cowboysdudeC Nystro0mN 2 Replies Last reply Reply Quote 0
          cowboysdude Module Developer @Johans
          @Johans check the console log and see what that tells you when it’s loading…
          You need to start your mirror and hit the ‘ALT’ key there will be a menu at the top…you want ‘toggle developer…’
          That’ll open up a side panel on the right and it will tell you what error there is…let me know so I can help you fix it :)
          • Nystro0mN Offline
            Nystro0m @Johans
            @Johans
            Im running on a Raspberry pi B ver.1 and it have some problems loading information from time to time when it been pushed to far.
            I would make sure that it is no error in the console from NOAA or other modules:
            Either by Comwboysdude method, but you could also run: “npm start dev” when starting MagicMirror.
            Another way that i did find more speed efficient is to open the MagicMirror interface on a secondary computer by going to: “Your.PI.LocalIP:8080/”.
            And then right-click and choose “inspect” in Chrome. Here you can find the console.
            Make sure to have your WhitelistIP set properly.
            I could also recommend Jophys - Remote Control Module.
            With this you can restart you MagicMirror, enter the web interface and such remotely if you are not comfortable with ssh.
              Johans @Nystro0m
              @Nystro0m
              thanks, learned again something new, on how to remotely connect to the MagicMirror.
              Meanwhile problem is solved.
              removed the line 400.
              these chars created an error ==========
                Johans @cowboysdude
                @cowboysdude
                thanks for showing me how to track & trace errors.
                Found root cause - line 400 in module MMM-NOAA.js.
                I removed the =========.
                Also added the “nl”: “nl-NL” into the lang file section.
                So now it’s all working - and in dutch - makes my wife happy :).
                Very beautifull - thanks for you support.
                  @Johans said in MMM-NOAA - Another Weather Module:
                  @cowboysdude
                  You are welcome… yes I fixed that on Github
                  Thank you!!! :)
                  Glad you made your wife happy! We have a saying here…
                  “Happy wife, happy life.” HAHAA
                  • Nystro0mN Offline
                    Nystro0m @cowboysdude
                    @cowboysdude
                    This update made messed up the CSS a bit, this screenshot is from default main.css and NOAA.css
                    alt text
                    The table content regarding the forecast data is fixed by:
                    .MMM-NOAA .tdh{
                    display: table;
                    That also make it align to the right, fixing a problem where the are not align properly if the lowest/highest temperature indexing inconsistent between tenths and some bellow (adding a number) for example :
                    (up) 10 (down) 8
                    (up) 16 (down) 11
                    Also, wFont does not response to font-size anymore. Im currently investing in this.
                    .MMM-NOAA .wFont {
                    And the barometer logo i can’t seem to find the resize option, i got around this by manipulating to core image.
                    I would also appriciate if there is a possibility to could change the “daylight”, “uv-index” and “humidify” colors in the .css.
                    Here are a Swedish translation for “Amount of daylight”:
                    Tillgängligt dagsljus
                    I found that this already consist in the translation-file. Does not seem to be loading for me.
                      cowboysdude Module Developer @Nystro0m
                      @Nystro0m Something is wrong with the layout… I’ll look at this later. Sorry about that.
                      What version of MM are you running? My dev machine is running 2.1.0 so that may be a reason you’re having issues… if you’re running a newer version so I just learned [Thanks @Mykle1]
                      Nystro0mN Mykle1M 2 Replies Last reply Reply Quote 1
                      • Nystro0mN Offline
                        @cowboysdude
                        No worries. Im running the latest version of MM and NOAA.
                        There is no hurry, i have customized the css to fit my need for now :)
                        Happy to help out if there is something you need to be tested etc.
                        cowboysdudeC 1 Reply Last reply Reply Quote 2
                        • 6
                        • 7
                        • 8
                        • 9
                        • 68
                        • 69
                        • 7 / 69
