MMM-NOAA - Another Weather Module
@gashion Hi, looks like u are using the v2 so u need to change ur config. U need only a few lines now:
apiKey
airKey
and rename pws to pws1
Please remove the rest -
@tbbear
Hi, thanks for ur reply.I tried what u said and still the same. Nothing changed.
New config settings:
{ disabled: false, module: 'MMM-NOAA', position: 'top_right', config: { apiKey: "83c61585aabeb89c", // https://www.wunderground.com/weather/api select the middle plan... airKey: "x7hcisbyAjENpBy4f", // IF you want Air Quality Index pws: "IKIVIKKO4", // go here to find your pws: https://www.wunderground.com/wundermap } }, -
@gashion Good but u forgot one thing Rename pws to pws1!!!
Hello,
First of all, thanks for your work.
I did have the same issue that @gashion had. I read your comment, it fix it !
But… to be honnest I really prefer the v1 look and feel. So is there a way to revert change and stay back in the v1 version ? -
@tbbear
How stupid of me. I replaced it and it works now. Thank you! :) -
I had the same issue. The change to config.js did fix it but now the temp is showing in Celsius. My locals are:
language: "en", timeFormat: 24, units: "imperial",any idea?
Thanks!
@stevegoble hi, this units option does only work for the default weather module. In NOAA its the value of the time format so 24 hours is european so Celsius, 12 hours is USA so Fahrenheit. Where are u living?
@tbbear
Thank you for the quick response. I am in Atlanta, GA USA. I prefer 24 hour clock so…sigh. -
@stevegoble if u have a few minutes i can fix it for u cause i just saw that v1 used units
@stevegoble ok, done do a git pull and u have it like it was using units
BAH! I just made the locale change to 12!! Thanks a bunch for the fix, I’ll update now… you da man!!
@stevegoble we love to make the users happy (if we can or we made the mistake lol)
I saw that lot’s of people dont like the headers in v2 so maybe an idea for a headerless option. Please let us know if u would like this option:
Bild Link) -
It looks much better :)
If you prefer not to have colored headers put this into your custom css file:
.MMM-NOAA .rheading {
background-color: transparent;
color: white;
}While module makers like to entertain ideas adding more config options is not always the
best answer when it can be changed easily using custom.css.There in lies the problem some like it, some don’t. Some like V1 of NOAA better.
So there will be 2 versions…1 and 2. :)
V1 can be found here -> http://173.56.209.189:443/topic/26/mmm-noaa-v1
[This is the only place you can get it from] :)V2 still on github [There will be no config option for this, instead use custom.css]
@tbbear said in MMM-NOAA - Another Weather Module:
Where? :-)
I changed the colors of the header to black. Looks better now…For me…
Good job and great module!
I managed with the custom.css, but I think the temperature can be seen very bad. Is it possible to reduce the size of the symbol or change the color of the font?
@Mykle1 there is a topic about the 3 top modules and their i found it
This topic only mentions MMM-NOAA twice, and only one of those mentions headers.
Soooooo, lot’s = 1? :-)
