MMM-NOAA - Another Weather Module
I hate you! :-)
@mykle1 Don’t hate me… @Sean made it… I just adapted it to NOAA3 LOL
Description:
Added Moon Phases and some style updates
Please follow Readme on Github!
To update just do a ‘git pull’ in the MagicMirror/modules/MMM-NOAA3 directory
Version 3.2.2
Download:
[card:cowboysdude/MMM-NOAA3]
Hi together,
I´m new on this nice modul.
I install and setup the module and use Openweather. The measurements are shown on the Mirror but without any Unit. (% or °C…) And the Images of Sun and Moon and the 4 day Forecast will not appear. Anybody know the Mistakes I do in the Setup. I don´t use the AQI Key because is not nessesary for me.In the Termial I got some Whoops… I show below…
Whoops! There was an uncaught exception... TypeError: Cannot read property 'length' of undefined at Object.parseForecast (/home/pi/MagicMirror/modules/MMM-NOAA3/providers/ow.js:184:42) at Request.request [as _callback] (/home/pi/MagicMirror/modules/MMM-NOAA3/providers/ow.js:55:17) at Request.self.callback (/home/pi/MagicMirror/modules/MMM-NOAA3/node_modules/request/request.js:185:22) at emitTwo (events.js:126:13) at Request.emit (events.js:214:7) at Request.<anonymous> (/home/pi/MagicMirror/modules/MMM-NOAA3/node_modules/request/request.js:1161:10) at emitOne (events.js:116:13) at Request.emit (events.js:211:7) at IncomingMessage.<anonymous> (/home/pi/MagicMirror/modules/MMM-NOAA3/node_modules/request/request.js:1083:12) at Object.onceWrapper (events.js:313:30) MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection? If you think this really is an issue, please open an issue on GitHub: https://gi thub.com/MichMich/MagicMirror/issues Whoops! There was an uncaught exception... SyntaxError: Unexpected token c in JSON at position 0 at JSON.parse (<anonymous>) at Object.parseUV (/home/pi/MagicMirror/modules/MMM-NOAA3/providers/ow.js:74:23) at Request.request [as _callback] (/home/pi/MagicMirror/modules/MMM-NOAA3/providers/ow.js:69:17) at Request.self.callback (/home/pi/MagicMirror/modules/MMM-NOAA3/node_modules/request/request.js:185:22) at emitTwo (events.js:126:13) at Request.emit (events.js:214:7) at Request.<anonymous> (/home/pi/MagicMirror/modules/MMM-NOAA3/node_modules/request/request.js:1161:10) at emitOne (events.js:116:13) at Request.emit (events.js:211:7) at IncomingMessage.<anonymous> (/home/pi/MagicMirror/modules/MMM-NOAA3/node_modules/request/request.js:1083:12) -
Hello,
I am trying to use your new module. I was using the previous one with openweathermap. I can’t get any info display on the screen as you can seen below :
FYI : my API key is working well with the default weather module and i use you API airkey on your 1st module without any problems
If i do understand well in your ow.js, you use this 1st url : http://api.openweathermap.org/data/2.5/forecast/daily?lat=“+this.config.userlat+”&lon=“+this.config.userlon+”&units=imperial&appid="+this.config.apiKey;
At 1st sight : you missed the use of one variable. Should it be written like this : http://api.openweathermap.org/data/2.5/forecast/daily?lat=“+this.config.userlat+”&lon=“+this.config.userlon+”&units=“+this.config.units+”&appid="+this.config.apiKey; ?
Another thing : daily forcast are not allowed in free plan so this url won"t work with free plan. I tested it on my browser, to get the forcast I have to use : http://api.openweathermap.org/data/2.5/forecast?lat=“+this.config.userlat+”&lon=“+this.config.userlon+”&units=imperial&appid="+this.config.apiKey; -> i don’t have any idea if you retrieve the info needed in your parser.
Hope it helps to debug my problems :)
Thanks a lot for your work
Thank you to @revere521 for finding a problem I didn’t even know existed!! Missing a file that the module is looking for!! I’ll fix that~ :)
ALL fixed…do a git pull and all will be well :)
@galm Do a git pull in the MagicMirror/modules/MMM-NOAA3 dir and it will work for you ;)
@cowboysdude said in MMM-NOAA - Another Weather Module:
MMM-NOAA3
Hello,
It did not change anything :( still not showing any values
Hello,
I do the git pull too, but I still get the Errors in the Terminalwindow shown on top.
No Forecast and now measurement unitsThe Api request work in the Browser for my coordinates an id.
Any Ideas.
What provider are you using? OpenWeather is proving to be a problem but I’m working on it.
@cowboysdude
Yes im Using Openweather -
Trying to update my MMM-NOAA but I’m getting the following message.
pi@raspberrypi:~/MagicMirror/modules/MMM-NOAA3 $ git pull
Updating 083122c…747044d
error: The following untracked working tree files would be overwritten by merge:
latlon.json
Please move or remove them before you merge.
Aborting -
Thanks!
No Problem. Always glad to help out when I can! :smiling_face_with_sunglasses:
Description:
A fork of @Sean MMM-WeatherBackground but remade for NOAA3
Day
Night
Version 1.0.0
Download:
[card:cowboysdude/MMM-WeatherBackground]
@cowboysdude
Thanks for this great module noaa3
One question
is there a possiblity to increase the size of the module?
Regards -
This will increase or decrease the body element on the page. You would put that in your custom.css file in the CSS directory.
…the ONLY way to make ONLY NOAA bigger is by editing the css file itself…
body {
zoom: 75%;
@cowboysdude : Hello, did you manage to make the openweather API to work with your module?
@galm Sir I am working on it and hopefully will make some progress tomorrow before football starts :)
