MMM-NOAA - Another Weather Module
@tbbear Thank you! Glad to help in anyway I can!
absolutely perfect, readme changed and all other stuff i only see one little topic after i loaded your module it said MMM-NOAA_master so i had to remove the _master all other things are TOP!!! by the way i think u should be the new default weather app im MM
i know i am the thorn in ur side but i think it would look better if the topic “Stunden mit Tageslicht” would use the same font size as the other lines.
@tbbear said in MMM-NOAA - Another Weather Module:
Yeah that’s what happens when you do a manual install it’s how github sends the file… can’t control that… if you do a git clone that doesn’t happen ;)
Perhaps later…right now dinner is calling my name… just got done watching the Cowboys game so food is priority LOL
of course. enjoy ur meal
Where do you see that? I’m looking at it and don’t see it… NOW I’m curious LOL
Why Thank you… however I don’t think the MM admin feel the same LOL
u should have dinner not write to me… but is see it on my MM and also on you screenshot that their is a different font size for this
dont worry he will learn whos module is the best !“!”!"!
I’m good :) That’s odd… what do you have in your custom.css file?
UPDATE
- No longer need to add lat or lon to the config.js
- put bottom forecast into table format
3 weather comes in default language flavors now …it’s automatic!
4 config option - showForecast: true or false to show or hide bottom forecast
[Thanks to @Mykle1 for fixing my css!! and @tbbear for fixing my German]
Tested and Runs on MM 2.1.3!
See the README on Github
Download:
[card:cowboysdude/MMM-NOAA]
@cowboysdude said in MMM-NOAA - Another Weather Module:
You’re most welcome bro! :^)
Oh snap! Drinks all around! :^)
another fantastic update!
Love the forecast! -
Just a little issue:
Someone else facing this problem with the missing today highest temperature?
Was in the old version the same.
Makes no sense for me, since this runs in a loop, and the other stuff is showed correctly.
Any ideas?
looks good now only the wind is missing -
… the next day it was working correctly again… weird
@barnosch said in MMM-NOAA - Another Weather Module:
It’s quite possible that the data from the API was missing yesterday. I’ve seen this a few times in other modules.
@Mykle1 said in MMM-NOAA - Another Weather Module:
was the same here
