    Electron CPU usage
    247 Posts 46 Posters 654.0k Views 42 Watching
      djsunrise19
      Input from my side: I checked the issues with electron 1.8 beta. Same problems.
        roramirez Core Contributors @pedroken
        @pedroken said in Electron CPU usage:
        I’ll try to use @Mykle1 's version of electron. I`ll google it (how to). Never did it.
        Well, you let we know if with that version of Electron is fixed the CPU usage. You can modified by hand the package.json to say to npm what version to install of Electron.
        Easy module development with MagicMirror Module Template
          djsunrise19
          My two cents again ;): My electron pakackage.json version is v.1.6.10. I made a downgrade to v1.4.15. Code says “invalid”. But the installation seems to work? Do you guys know, where I can check the installed electron version?
          No effect. 55% CPU and very sluggish (256MB GPU Memory):
            Mykle1 Project Sponsor Module Developer @djsunrise19
            @djsunrise19 said in Electron CPU usage:
            You can see the installed version in this file MagicMirror/node_modules/electron/dist/version
              djsunrise19 @Mykle1
              @Mykle1 Thanks. Yes, v1.4.15.
                I just had a thought (miracle). What version of MM is everyone using?
                My Pi3 B mirror is running MM version 2.1.0. I’ve had no reason to update it. It’s rock solid
                  djsunrise19 @Mykle1
                  @Mykle1 said in Electron CPU usage:
                  I had this problems since the new MM2 Version. Very long so. But my version is the newest one. 2.1.2 I think.
                    uh oh! So you DIDN’T have this problem before the new version?
                      SashMare
                      Hi.
                      I made a downgrade Electron from v1.7.15 to v1.4.15.
                      CPU load up to 320% is gone.
                      Hardware: BCM2835
                      Revision: a22082
                      MagicMirror: 2.1.2
                      W 1 Reply Last reply Reply Quote 1
                      • W Offline
                        wtidwell @SashMare
                        @SashMare @Mykle1 my
                        I also downgraded electron to 1.4.15 and I’m seeing dramatically improved performance!
                        D Mykle1M 2 Replies Last reply Reply Quote 1
                          djsunrise19 @wtidwell
                          @wtidwell said in Electron CPU usage:
                          Do you have some CPU load Screenshots? As I read, around 55% is to high too.
                          • W Offline
                            wtidwell @djsunrise19
                            @djsunrise19
                            Not on hand but I’m seeing in the mid 20’s with newsfeed animations
                              Mykle1 Project Sponsor Module Developer @wtidwell
                              Well, that’s good news! :^)
                                You guys are both running MM 2.1.2? There has been some mention that this problem arose after the upgrade. My Pi3 B mirror is still running MM 2.1.0. :-/
                                Just a thought.
                                  mibafz00 @Mykle1
                                  @Mykle1
                                  Today, I tried the following:
                                  MM 2.1.2 + Electron 1.7.5 --> CPU 100% during transitions
                                  MM 2.1.2 + Electron 1.4.15 --> problem still there, CPU 100% during transitions
                                  MM 2.1.0 + Electron 1.7.5 --> problem still there, CPU 100% during transitions
                                  MM 2.1.0 + Electron 1.4.15 --> problem (probably) gone, CPU 40% during transitions
                                  So i guess you have to downgrade both, MM and electron…!?
                                    Mykle1 Project Sponsor Module Developer @mibafz00
                                    @mibafz00 said in Electron CPU usage:
                                    I’m curious. What is the CPU load at rest, when no transitions are executing?
                                    In any case, that’s a good amount of testing on your part, and hopefully it will lead to a final diagnosis of the problem.
                                      djsunrise19
                                      Today, I tried a few things, too. Perhaps my results could be helpful for us. Sorry, this will be a long post ;). I have following the devices:
                                      • Raspberry 3 Model B - my standard mirror device
                                      • Asus Tinker Board
                                      • odroid C2 (ARM64)
                                      Software Versions MM:
                                      • MM v2.1.2 on all devices
                                      Electron Versions:
                                      • Raspberry 3 Model B (v1.6.11)
                                      • Asus Tinker Board (v1.4.15) but v1.6.11 works the same
                                      • odroid C2 (ARM64) (v.1.8.0 - because of the x64; I uninstalled spectron, because there is no x64 support)
                                      Configs:
                                      • Standard (Calendar, Compliments, Newsfeed, Clock)
                                      • MyConfig (Calendar, Compliments, Newsfeed, Clock, Todoist, Sonos, Netatmo, WheaterUnderground, Stocks, Reiseauskunft, Strava); here, cpu usage is a little bit higher, but the behaviour is the same.
                                      The 100% usage topic seems to be a electron problem and I think it can be solved with some downgrades of MM2 and electron. v.1.7.5 seems to be bad. Whatever, here is what I found out:
                                      1. nmon with the ATB (v1.7.5 electron here) and default config:
                                        CPU usage while transitions is very high. Lagging!
                                      2. nmon with the ATB (v1.4.15 electron here) and default config:
                                        CPU usage is better but, to be honest, way to high for transitions (cpu peaks). And still some small lags.
                                      3. nmon with the odroid and default config:
                                        The best result. but still peaks while the transitions. Some lags here, too.
                                      So, here is my actual config:
                                      4) nmon with the Raspberry 3 Model B and MyConfig:
                                      Same here, still lags.
                                      The last thing I tried was very interesting. I opened my chromium on the ATB and put the webadress from my Raspberry 3 Model B device in it. So I openend that Rapsberry 3 Model B MM2 on my ATB. And that happens:
                                      Absolutely smooth, no peaks at all.
                                      BTW: My Raspberry 3 Model didn’t have any more cpu usage while that process.
                                      Can anybody tell us, WHY?
                                      • ? Offline
                                        A Former User @djsunrise19
                                        @djsunrise19
                                        As I see, rendering engine of electron seems to be the reason of whole of thing. Electron has its own v8 and renderer. I doubt it goes worse on some late version. I don’t know why, but there is few things we could do.
                                        Report this to electron, wait a patch. Or downgrade or… turn off the animation.
                                        D Mykle1M 2 Replies Last reply Reply Quote 0
                                          djsunrise19 @Guest
                                          @Sean said in Electron CPU usage:
                                          @djsunrise19
                                          Seems logical. But I have to mention, that there is no MMv2 and electron version number combination that works without those peaks and small lags. The smoothest way ist the browser directly (like in MMv1 - everything was fine there).
                                          So the question is: Anyone here who doesn’t have those peaks and lags while the transitions with MMv2 and electron?
                                            This topic is only 17 days old, yet it has 5.0k views already. So, obviously there is a lot of interest. My answer likely was lost somewhere above, so:
                                            I do NOT have those peaks and lags
                                            • 6
                                            • 7
                                            • 8
                                            • 9
                                            • 12
                                            • 13
                                            • 7 / 13
