    MMM-Fuel
    fuel pricegas stationpetrol stationvoice-controltankerkoenigspritpreisrechnernsw
    178 Posts 48 Posters 570.4k Views 48 Watching
      Dom1n1c
      I did a replacement on the Station names, because “Shell” is typically naming there stations after the Street name.
      I fixed the City name to have only the first Letter in uppercase.
      How can i remove the " null" part, which is occuring at JET stations,
      or how can i tidy up the street names? (every seperate word starting with an uppercase)
      of course i can start with a list of the complete string that should be replaced, but there might be another option.
      • strawberry 3.141S Offline
        strawberry 3.141 Project Sponsor Module Developer @Dom1n1c
        @Dom1n1c
        • null @jets is propably that they inserted the house number in the street name and the house number value returns null
        • for the street names i would split at the space character and then for each array item charAt(0).toUpperCase() and the rest of the string lowercase and finally join them together
          Dom1n1c
          I added checks for house numbers==null and splitted the street names.
          Also the Brand names starting with (star,ESSO,Aral were replaced automatically)
          (Shell and no-name stations are a special case, so i need to handle them individually)
          But, there is still another special case:
          Streetnames with " " or “-” should be splitted, but no housenumbers (from JET :D ).
          How can i avoid splitting numbers:
          This is the section that does the splitting
          words = str.toLowerCase().split(/-| /);
          can be found here in total:
          https://github.com/Dom1n1c/MMM-Fuel/blob/master/MMM-Fuel.js
            @Dom1n1c I commented on your changes
              reaper81
              Is it possible to choose other typs of fuel like non-leaded supergrade plus petrol or premium?
                strawberry 3.141 Project Sponsor Module Developer @reaper81
                @reaper81 the api only provides diesel e5 and e10 sorry
                  jayjay2017
                  Hi
                  If I take the example with a matching token,
                  “Node serveronly” does not start.
                  Loading config …
                  Loading module helpers …
                  WARNING! Could not validate config file. Please correct syntax errors. Starting with default configuration.
                  Whoops! There was an uncaught exception…
                  [SyntaxError: Block-scoped declarations (let, const, function, class) not yet supported outside strict mode]
                  var config = {
                  port: 8070,
                  ipWhitelist: [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “192.168.1.22”],
                  language: 'de',
                  timeFormat: 24,
                  units: 'metric',
                  module: ‘MMM-Fuel’,
                  position: ‘top_right’,
                  api_key: ‘f9fXXXXXXX’,
                  lat: 51.899177,
                  lng: 10.184662,
                  types: [‘diesel’],
                  Y strawberry 3.141S 2 Replies Last reply Reply Quote 0
                  • Y Offline
                    yawns Moderator @jayjay2017
                    @jayjay2017 please post your config without api keys or check your config on jshint.com
                      strawberry 3.141 Project Sponsor Module Developer @jayjay2017
                      @jayjay2017 sounds like your node version doesnt support es6 which node version are you using?
                        jayjay2017
                        The version of node was the point. I had Version 4.2.6, now updated to V7.7.2.
                        It works now.
                        Thank you very much.
                          sindbad6
                          Hi, have an issue with the shortenText parameter. When I use it, the address is max shorter(in px) then the name of the gas station. That’s a little bit anoying if more then one station is shown from the big companies and I can’t see the complete address, even if there is still enough place. Any idea, how I can change it? In the custom.css for example.
                          0_1489269011731_upload-acb11020-7933-41d5-a659-9402199ec1a1
                            strawberry 3.141 Project Sponsor Module Developer @sindbad6
                            @sindbad6 looks strange, your name gets cut after 35 chars and your address after ~19 can you send me your geo data you’re using in config as a private message?
                              sindbad6 @strawberry 3.141
                              @strawberry-3.141 Sorry, I’m a complete newbie and can’t see how to send a private message. I tried it over the chat button. I hope you meant this.
                                @sindbad6 do a git pull in ~/MagicMirror/modules/MMM-Fuel
                                  @strawberry-3.141 Thanks a lot. That’s much better.
                                    Stabber
                                    A great modul!!
                                    What should I do to see the map? I have google maps API, but I don’t know where to add it.
                                      strawberry 3.141 Project Sponsor Module Developer @Stabber
                                      @Stabber Currently the map can only be shown with my voice module https://github.com/fewieden/MMM-voice
                                        sindbad6
                                        Hi, I made a change in my MM-Fuel.js to implement an additional parameter for shortening the address of a gas station. It is not a big thing, but I would like if it would be integrated in the repository. The point is, I never have done it before. In between I got an account at github, but know? Can somebody give me a link where I can find belonging infos?
                                          @sindbad6 in short:
                                          • fork the repository
                                          • make your changes
                                          • push them to the fork
                                          • create a pull request
                                            @strawberry-3.141 Ok, I did it now. I’m not sure if I did right. Please inform me if something was wrong. I’m a little bit surprised, to get the possibility to merge my changes.
                                            • 8
                                            • 9
                                            • 3 / 9
