    MMM-Fuel
    fuel pricegas stationpetrol stationvoice-controltankerkoenigspritpreisrechnernsw
    178 Posts 48 Posters 570.4k Views 48 Watching
    • strawberry 3.141S Offline
      strawberry 3.141 Project Sponsor Module Developer @sindbad6
      @sindbad6 you closed your pull request and deleted the branch so there is no possibility to merge your changes
        sindbad6 @strawberry 3.141
        @strawberry-3.141 That’s what I was afraid of. I will try to correct it.
          Changelog v1.1.0
          • API provider development Guide.
          • API provider spritpreisrechner.at.
          • Disabled markdownlint rule MD026 (no-trailing-punctuation)
          • Disabled eslint rule no-console
          • Doclets.io integration
          • Contributing guidelines
          • Issue template
          • Pull request template
          [card:fewieden/MMM-Fuel]
            Anhalter42
            Anyone considered adding support of multiple locations? Useful for example for commuters to lookup prices at start and destination (and/or somewhere in between) of their daily way to work.
            • garblefluxG Offline
              garbleflux Project Sponsor
              hi strawberry. Absolut nice work, I use it daily! One question: How did you get the in the example (Cheapest Gas Stations) all the text in the listing left justified?
                strawberry 3.141 Project Sponsor Module Developer @garbleflux
                @garbleflux if you scroll down there is module configuration https://github.com/MichMich/MagicMirror#configuration you can add the class align-left
                  Changelog v1.1.1
                  • Disabled markdownlint rule MD024 (no-duplicate-header)
                  • Config option toFixed to show only 2 decimals for the price.
                  • Coordinate.to() throws exception if start point is not set.
                  Upcoming release v1.2.0
                  https://github.com/fewieden/MMM-Fuel/projects/1
                  • rudibaraniR Offline
                    rudibarani Project Sponsor @strawberry 3.141
                    Hi @strawberry-3.141,
                    thanks for creating this great module! Would any of the following be possible?
                    • hide the distance column
                    • show the prices of pre-selected gas stations
                    • show e.g. the three cheapest plus some pre-selected gas stations
                      strawberry 3.141 Project Sponsor Module Developer @rudibarani
                      @rudibarani you can hide the distance column with css in custom.css, the other points are currently not possible
                      • K Offline
                        kiki99
                        Hi and Thanks for this module.
                        I’ve only one Problem: I did not get the column with the price ;)
                        It seems all other things are okay.
                        What can i do/check?
                        Thanks a lot for every tip :)
                          strawberry 3.141 Project Sponsor Module Developer @kiki99
                          @kiki99 can you post your config?
                          • K Offline
                            kiki99 @strawberry 3.141
                            @strawberry-3.141: yes, of course ;)
                            		module: 'MMM-Fuel',
                            		position: 'lower_third',
                                		api_key: 'myApiKeyHere,
                                		lat: 49.164136,
                                		lng: 9.059751,
                                		types: ["E5"],
                            		sortBY: "E5",
                            		radius: 10,
                            		colored: true,
                            		open: true,
                            		rotate: false
                            i see no prices (no column for that). But the List works.
                              @kiki99
                                module: 'MMM-Fuel',
                                  api_key: 'myApiKeyHere',
                                  lat: 49.164136,
                                  lng: 9.059751,
                                  types: ["e5"],
                                  sortBy: "e5",
                                  radius: 10,
                                  colored: true,
                                  open: true,
                                  rotate: false
                              • K Offline
                                @strawberry-3.141 Oh my …, sorry for this stupid Mistake and the bad format.
                                Many thanks for the quick help :)
                                • F Offline
                                  FreddeHamm
                                  @strawberry-3.141 I have some issues getting this thing fired up. I have a working api and found my location. But for some reason, the magic mirror won’t show the Fuel List.
                                    module: "MMM-Fuel",
                                    position: "bottom_right",
                                      api_key: 'Just My API',
                                      lat: 51.674177,
                                      lng: 6.460384,
                                      types: ["diesel"],
                                      sortBy: "diesel",
                                      radius: 10,
                                      colored: true,
                                      open: true,
                                      rotate: false
                                  Where is my mistake?!
                                    strawberry 3.141 Project Sponsor Module Developer @FreddeHamm
                                    @FreddeHamm you should remove the api key from your post, it’s kind of a password.
                                    I have to look on this on the weekend, can’t spot something obvious right now
                                    • F Offline
                                      FreddeHamm
                                      any news?
                                        @FreddeHamm sorry, forgot about you. cant reproduce your issue though, i did a refresh install of mmm-fuel on my machine and inserted your config which resulted in the following state
                                        can you spot any errors in the logs (electron or terminal, pm2)? did you try to disable all other modules to reduce side effects?
                                        • F Offline
                                          FreddeHamm
                                          Thanks for your help. If i open the magic mirror site via browser (my.rasperry.pi.ip:8080) i see the module. But its not shown on the screen of the mirror itself…
                                            @FreddeHamm any errors?
                                            • 6
                                            • 7
                                            • 8
                                            • 9
                                            • 4 / 9
