    MMM-voice
    voice control
    329 Posts 55 Posters 973.9k Views 50 Watching
    • C Offline
      c.keen
      At first when I tried to install using the bash script it stopped at the second step (can’t remember exactly why). But second time it worked itself completely through the steps. Starting the mirror I got the “Error” message. Then I read the thread here completely and removed all components necessary.
      I installed it again using the script and no warnings or errors were reported. But still, after “initialising” the Error message was displayed. ?? As described in the error.log I found “127” and in the debug.log the long message I reported in an earlier thread.
      I still have no idea …
      • C Offline
        c.keen
        And I started the raspberry and the terminal multiple times since the error
        • lucallmonL Offline
          lucallmon
          My entire mirror is JACKED UP hard after trying to install this module. How do I go about deleting all dependencies and everything in relation to this module?
          Going through the dependencies setup, it got to 5/6 and it gave me a slew of errors and then stopped. I’ve tried multiple times to re-install and it gives me the same. Now all I want to do is get rid of of it so I can go back to a working mirror. Any help would be greatly appreciated. @strawberry-3-141 @Mykle1
          • strawberry 3.141S Offline
            strawberry 3.141 Project Sponsor Module Developer @lucallmon
            @lucallmon would be interesting what these errors are, because step 5/6 is only performing a usual npm install as you do in most of the modules.
            • remove the module directory
            • open your bashrc file and delete at the bottom:
            export LD_LIBRARY_PATH=:/usr/local/lib
            export PKG_CONFIG_PATH=:/usr/local/lib/pkgconfig
            • in /home/pi/ there should be directories called pocketsphinx and sphinxbase, go into them and execute make uninstall, afterwards you can remove them.
            • run apt-get autoremove to uninstall dependencies that are not longer needed on your system
              lucallmon
              during [STEP 5/6] Installing npm dependencies
              I get the following errors and then it stops: ```
              npm ERR! Linux 4.4.50-v7+
              npm ERR! argv “/usr/bin/nodejs” “/usr/bin/npm” “install”
              npm ERR! node v6.10.0
              npm ERR! npm v3.10.10
              npm ERR! path /home/pi/MagicMirror/modules/MMM-voice
              npm ERR! code EACCES
              npm ERR! errno -13
              npm ERR! syscall access
              npm ERR! Error: EACCES: permission denied, access ‘/home/pi/MagicMirror/modules/MMM-voice’
              npm ERR! at Error (native)
              npm ERR! { Error: EACCES: permission denied, access ‘/home/pi/MagicMirror/modules/MMM-voice’
              npm ERR! errno: -13,
              npm ERR! code: ‘EACCES’,
              npm ERR! syscall: ‘access’,
              npm ERR! path: ‘/home/pi/MagicMirror/modules/MMM-voice’ }
              npm ERR!
              npm ERR! Please try running this command again as root/Administrator.
              npm ERR! path npm-debug.log.3606122589
              npm ERR! errno -13
              npm ERR! syscall open
              npm ERR! Error: EACCES: permission denied, open ‘npm-debug.log.3606122589’
              npm ERR! { Error: EACCES: permission denied, open ‘npm-debug.log.3606122589’
              npm ERR! syscall: ‘open’,
              npm ERR! path: ‘npm-debug.log.3606122589’ }
              npm ERR!
              npm ERR! /home/pi/MagicMirror/modules/MMM-voice/npm-debug.log
              [STEP 5/6] Installing npm dependencies | Failed
              thoughts?
                @lucallmon these are some access right issues, how do you run the installer?
                lucallmonL 2 Replies Last reply Reply Quote 0
                  lucallmon @strawberry 3.141
                  @strawberry-3.141 I did not use sudo should I?
                    @lucallmon I never installed it with sudo rights
                    lucallmonL 1 Reply Last reply Reply Quote 0
                      @strawberry-3.141 one of my biggest problems is that after trying to install this module, my AlexaPi doesn’t work anymore. I think it has something to do with the re-install of sphinx. Once I figure this out, I’ll reinstall AlexaPi.
                        @strawberry-3.141 so what is your suggestion in my case?
                        • 9
                        • 10
                        • 11
                        • 12
                        • 13
                        • 32
                        • 33
                        • 11 / 33
