    MMM-voice
    voice control
    329 Posts 55 Posters 973.7k Views 50 Watching
      Mykle1 Project Sponsor Module Developer @Mykle1
      I’m here for a while if you should come around
        Mykle1 Project Sponsor Module Developer @strawberry 3.141
        @strawberry-3.141
        I tested my microphone on the Pi by doing this:
        pi@Pi3:~ $ arecord -D plughw:1,0 test.wav
        Recording WAVE 'test.wav' : Unsigned 8 bit, Rate 8000 Hz, Mono
        ^CAborted by signal Interrupt...
        pi@Pi3:~ $
        That gave me this: 0_1489005574631_soundfile.JPG
        Which sounds ok. Clear, and not too much white noise.
        As long as my Audio Device Settings looks like this:0_1489005776320_audiodevicesettings.JPG
        I am not in debug mode
             			module: 'MMM-voice',
             			position: 'top_right',
                 		microphone: 1,
        			keyword: 'MAGIC MIRROR', // UPPERCASE ONLY
        			timeout: 15
        However, I am getting this: 0_1489006683272_fairest.JPG
        At least we got it working
        strawberry 3.141S johnnyboyJ 2 Replies Last reply Reply Quote 0
        • strawberry 3.141S Offline
          strawberry 3.141 Project Sponsor Module Developer @Mykle1
          @Mykle1 the second line is in debug mode only
            @strawberry-3.141 said in MMM-voice:
            So, can I remove that from showing?
              @Mykle1 it shouldn’t be there when you not added debug flag in the config
              Mykle1M 3 Replies Last reply Reply Quote 0
                @strawberry-3.141
                I’ll try debug: false and see what happens
                  @strawberry-3.141
                  You’re right again. I had config.js opened twice. One with debug and one without. I removed debug and saved and closed both. Now it’s fine. One last thing, if you don’t mind, I’d like to align everything in MMM-voice to the right margin. Please and thank you. :thumbsup_tone1:
                    @strawberry-3.141 Oh, and I can change the 'MAGIC MIRROR" activation phrase to something else?
                      @Mykle1 yes you can change it, that’s why it is configurable. try to apply the rule text-align: right; in custom.css
                      Mykle1M 3 Replies Last reply Reply Quote 1
                        I will endeavor to try, thanks for your help
                        • 7
                        • 8
                        • 9
                        • 10
                        • 11
                        • 32
                        • 33
                        • 9 / 33
