    My bathroom smart mirror.
    3 Posts 3 Posters 8.7k Views 3 Watching
    • qu1queQ
      qu1que Project Sponsor
      Hi!
      First of all I would like to thanks to @goldjunge_chriz for the opportunity to acquire a 2-way mirror. It is impressive, much better than the acrylic sheet. And, I’d like to thanks to @MichMich too for the Magic Mirror software.
      Here I leave some pictures of the montage that I was doing this last summer, at leisure. I have been quite happy with the result. I hope you like it!
      I am going to try not to extend myself too much with the explanations, if someone has any doubts, I will kindly answer him.
      The bathroom cabinet consists of 2 pieces: a frame and a door:
      A coat of paint…
      The screen of a second-hand 24-inch LCD TV
      To correct these errors in the cut with the electric saw, I have put some plastic corners and black silicone. This is the result:
      E.L. wire installation:
      Mirror installation:
      The mirror was glued with black silicone too
      Preparation of the electrical wiring in the frame…
      … and the TV speakers. I designed a simple piece in 3D to put them inside (they are available in thingiverse in case someone is interested).
      Final assembly:
      Detail of Raspberry Pi 3B
      Last adjustments and … It works !!!
      I have made a pdf with the connection scheme of all the electronic part that you can see here (I’ve had to convert to png previously to put it here):
      And here is the python3 script to make it all works:
      #!/usr/bin/python3
      # Para que funcione correctamente, hay que instalar los siguientes
      # paquetes:   sudo apt install python3 python3-rpi.gpio
      # Script que activa la pantalla y el EL wire cuando detecta movimiento
      # a través del sensor de presencia PIR
      import RPi.GPIO as GPIO
      import time
      import os
      GPIO.setmode(GPIO.BCM)
      GPIO.setup(22, GPIO.IN)						# SALIDA DEL PIR (PIR OUTPUT)
      GPIO.setup(23, GPIO.OUT)					# EL WIRE (CABLE ELECTROLUMINISCENTE)
      GPIO.setwarnings(False)
      time.sleep(120)
      os.system('vcgencmd display_power 0')
      while True:
          if (GPIO.input(22) == 1):		                # SI DETECTA PRESENCIA (IF MOTION IS DETECTED)
              os.system('ogg123 -qz /media/pi/MUSICA/ &')	# ACTIVA LA MÚSICA (TURN MUSIC ON)
              os.system('vcgencmd display_power 1')	        # ACTIVA HDMI --> ACTIVA PANTALLA (TURN ON SCREEN)
              GPIO.output(23, GPIO.HIGH)			# ENCIENDE EL ELWIRE (TURN ON EL WIRE)
              time.sleep(600)					# "DUERME" 10 MINUTOS (SLEEP 10 MINUTES)
              os.system('vcgencmd display_power 0')		# APAGA SALIDA HDMI --> APAGA PANTALLA (TURN OFF SCREEN)
              GPIO.output(23, GPIO.LOW)			# APAGA EL WIRE (TURN OFF EL WIRE)
              os.system('sudo pkill ogg123')			# MATA PROCESO MÚSICA (TURN OFF MUSIC)
      And you can watch a video here:
      https://www.youtube.com/watch?v=WOjyTtQLJ6w
      I hope you like it as much as I do!!
      So far I have not managed to make the music stop when the push button is pressed, but I will end up getting it …
      Mykle1M 1 Reply Last reply
      Reply Quote 3
      • Mykle1M
        Mykle1 Project Sponsor Module Developer @qu1que
        @qu1que
        Good stuff!
        • CyruS1337C
          CyruS1337 Project Sponsor
          Looks really great. Thanks for the documentation and the review
