    MMM-NewsFeedTicker
    94 Posts 15 Posters 92.0k Views 14 Watching
    • justjim1220J
      justjim1220 Module Developer
      This module has been updated
      Please do a git pull && npm i to update
      Thanks!
      “Life’s Too Short To Dance With Ugly People”
      Jim Hallock - 1995
      • M
        mrSnatz
        Hello,
        Great module, exactly what I was looking for. however, the lettering stutters. Is there a way to fix this? I use a Rasperry pi3. How do I remove the logo from the feed? Many thx
        my config.js
          	  module: "MMM-NewsFeedTicker",
          	  position: "middle_center",
          	  //classes: "day_scheduler",
          	    feeds: [
              			title: "sportBILD",
              			url: "https://sportbild.bild.de/rss/vw-fussball/vw-fussball-45036878,sort=1,view=rss2.sport.xml",
              			encoding: "UTF-8",
              			className: "myClass",
              			//defaultLogo: ""
        and my custom.css
        .MMM-NewsFeedTicker {
            width: 80;
            height: 30px;
            background-color: none;
        .MMM-NewsFeedTicker .tickerbody {
            position: absolute;
            bottom: 10px;
            transform: translateZ(0);
            backface-visibility: hidden;
            animation: marquee 30s linear infinite;
        .MMM-NewsFeedTicker .image {
            margin-left: 0;
            bottom: 10px;
            height: 30px;
        justjim1220J Mykle1M 2 Replies Last reply
        • justjim1220J
          justjim1220 Module Developer @mrSnatz
          @mrSnatz said in MMM-NewsFeedTicker:
          In this section,
          margin-left: 0;
          bottom: 10px;
          height: 30px;
          add display: none;
          as far as the stuttering, I was told that animation will do that with Pi
          Jim Hallock - 1995
          • Mykle1M
            Mykle1 Project Sponsor Module Developer @mrSnatz
            Yep, the Pi struggles with some animations. Scrolling happens to be one of them. If they are important to you then you might consider something more robust than the Pi. There are alternatives from other single board computers, all the way up to mini ITX motherboards. Still others run MM (server) on a full blown desktop machine and use the Pi to remote in to view MM
            Reply Quote 1
            • M
              mrSnatz
              @justjim1220 said in MMM-NewsFeedTicker:
              display: none;
              Many thanks for the answer. Yes, I also thought about buying a stronger computer. What is your opinion on the Asus Tinkerboard? would he fix the problem?
              Mykle1M justjim1220J ? 3 Replies Last reply
              • Mykle1M
                I don’t have an opinion on the Tinkerboard. I’ve never used one, but there are several people on the forum that have. Perhaps then will chime in with their opinions. Good luck.
                • mumblebajM
                  mumblebaj Module Developer @justjim1220
                  @justjim1220 Have you ever managed to get this resolved? I a not getting the image from my 1 local news feed pulled in and not sure what else I can do to see if I can get it to come through.
                  The news feed is from: http://feeds.news24.com/articles/news24/SouthAfrica/rss
                  and the image is supposed to come from: https://scripts.24.co.za/img/sites/news24.png
                  justjim1220J 1 Reply Last reply
                  • justjim1220J
                    @mrSnatz
                    I have never used a Tinkerboard, so no thoughts regarding the use of one. Apologies!
                    Jim Hallock - 1995
                      A Former User @mrSnatz
                      @mrSnatz
                      I didn’t test this module on ATB, but ATB is definitely stronger than RPI.
                      However apart from this module, you have more option nowadays. I think you can consider RK3399 or S922X. I especially recommend Jetson Nano at this moment for powerful GPU. RockPi 4 or NanoPi M4 is also good for overall performance.
                      D 1 Reply Last reply
                      Reply Quote 1
                      • justjim1220J
                        justjim1220 Module Developer @mumblebaj
                        @mumblebaj
                        Please update your MMM-NewsFeedTicker and run it to see if it is working the way you are wanting.
                        git pull
                        Thanks!
                        Jim Hallock - 1995
                        • D
                          dirkie @Guest
                          I run MM on a dedicated Intel NUC and I still occure this stuttering you are talking about. I noticed that the suttering appears when “MMM-ImagesPhotos” loads new pictures in slideshow mode. I was able to reduce this stuttering by reducing the size of the images…
                          What I try to say “the power” does not help. I think the code is sometimes “sloppy”. Not that I could do anything better in terms of coding but just my 2cent…
                          • G
                            Giarry88
                            Hi guys! I know that this topic is quite old, but I am trying to add this module to my magic mirror unsuccesfully.
                            I added in the “config.js” file the module but it doesn’t show up. Any ideas on what i’ve done wrong?
                            		module: "alert",
                            		module: "updatenotification",
                            		position: "top_bar"
                            		module: "clock",
                            		position: "top_left"
                            		header: "Calendario di Google",
                            					symbol: "calendar-check",
                            					url: "MY CALENDAR"					}
                            		module: "compliments",
                            		position: "lower_third"
                            		module: "currentweather",
                            			locationID: "6542009", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
                            			appid: "MYAPPID"
                            		module: "weatherforecast",
                            		header: "Previsioni Meteo:",
                            			appid: "MYAPPID"
                            		module: "newsfeed",
                            		position: "bottom_bar",
                            			feeds: [
                            					title: "ANSA",
                            					url: "https://www.ansa.it/sito/ansait_rss.xml"
                            			showSourceTitle: true,
                            			showPublishDate: true,
                            			broadcastNewsFeeds: true,
                            			broadcastNewsUpdates: true
                            disabled: false,
                            module: “MMM-NewsFeedTicker”,
                            position: “bottom_bar”,
                            //classes: “day_scheduler”,
                            feeds: [
                            title: “New York Times”,
                            url: “http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml”,
                            customLogo: “NYT_logo_rss_250x40.png”
                            title: “USA Today”,
                            url: “http://rssfeeds.usatoday.com/UsatodaycomNation-TopStories”,
                            customLogo: “RSS_Syndication_Logo-USATN.png”
                            title: “BBC World News”,
                            url: “http://feeds.bbci.co.uk/news/world/rss.xml#”,
                            customLogo: “bbc_news_120x60.gif”
                            Thanks in advance!
                              sdetweil @Giarry88
                              @Giarry88 from the MagicMirror folder do
                              npm run check:config
                              G 1 Reply Last reply
                              • G
                                Giarry88 @sdetweil
                                @sdetweil said in MMM-NewsFeedTicker:
                                Thanks sdetweil.
                                the terminal says:
                                pi@raspberrypi:~/magicmirror $ npm run check:config
                                npm ERR! missing script: check:config
                                npm ERR! /home/pi/.npm/_logs/2020-04-22T00_59_46_184Z-debug.log
                                the log says:
                                1 verbose cli [ ‘/usr/bin/node’, ‘/usr/bin/npm’, ‘run’, ‘check:config’ ]
                                2 info using npm@6.14.4
                                3 info using node@v10.20.1
                                4 verbose stack Error: missing script: check:config
                                4 verbose stack at run (/usr/lib/node_modules/npm/lib/run-script.js:155:19)
                                4 verbose stack at /usr/lib/node_modules/npm/lib/run-script.js:63:5
                                4 verbose stack at /usr/lib/node_modules/npm/node_modules/read-package-json/read-json.js:116:5
                                4 verbose stack at /usr/lib/node_modules/npm/node_modules/read-package-json/read-json.js:436:5
                                4 verbose stack at checkBinReferences_ (/usr/lib/node_modules/npm/node_modules/read-package-json/read-json.js:391:45)
                                4 verbose stack at final (/usr/lib/node_modules/npm/node_modules/read-package-json/read-json.js:434:3)
                                4 verbose stack at then (/usr/lib/node_modules/npm/node_modules/read-package-json/read-json.js:161:5)
                                4 verbose stack at /usr/lib/node_modules/npm/node_modules/read-package-json/read-json.js:382:12
                                4 verbose stack at /usr/lib/node_modules/npm/node_modules/graceful-fs/graceful-fs.js:115:16
                                4 verbose stack at FSReqWrap.readFileAfterClose [as oncomplete] (internal/fs/read_file_context.js:53:3)
                                5 verbose cwd /home/pi/magicmirror
                                6 verbose Linux 4.19.97-v7l+
                                7 verbose argv “/usr/bin/node” “/usr/bin/npm” “run” “check:config”
                                8 verbose node v10.20.1
                                9 verbose npm v6.14.4
                                10 error missing script: check:config
                                11 verbose exit [ 1, true ]
                                What does “check.config” do?
                                S 2 Replies Last reply
                                  sdetweil @Giarry88
                                  @Giarry88 ok, I hate this thing.
                                  npm run config:check
                                    sdetweil @Giarry88
                                    @Giarry88 said in MMM-NewsFeedTicker:
                                    It checks the config.js file
                                    • G
                                      Giarry88
                                      Ok, i’ve checked and corrected it with geanie and now the syntax is correct but it still doesn’t show it on mm
                                        sdetweil @Giarry88
                                        @Giarry88 open the developers window ctrl-shift-i on the keyboard, and select the console tab and scroll up to see any errors.
                                        • G
                                          Giarry88 @sdetweil
                                          yes,
                                          Load script: modules/MMM-NewsFeedTicker//MMM-NewsFeedTicker.js
                                          :8080/modules/MMM-NewsFeedTicker//MMM-NewsFeedTicker.js:1 Failed to load resource: the server responded with a status of 404 (Not Found)
                                          loader.js:187 Error on loading script: modules/MMM-NewsFeedTicker//MMM-NewsFeedTicker.js
                                          script.onerror @ loader.js:187
                                          loader.js:194 Load stylesheet: css/custom.css
                                          (index):1 Refused to apply style from ‘http://localhost:8080/css/custom.css’ because its MIME type (‘text/html’) is not a supported stylesheet MIME type, and strict MIME checking is enabled.
                                          loader.js:203 Error on loading stylesheet: css/custom.css
                                            sdetweil @Giarry88
                                            @Giarry88 sounds like u didn’t install the module in the right place
                                            • 4 / 5
