    Bathroom Magic Mirror
    67 Posts 25 Posters 102.5k Views 27 Watching
      secdude
      Thanks for that!
      • E
        evgeniy88
        Impressive work. How many cans of silicone did you use?
        spitzlbergerjS 1 Reply Last reply Reply Quote 0
        • spitzlbergerjS
          spitzlbergerj Project Sponsor Module Developer @evgeniy88
          Hi @evgeniy88,
          I probably needed a lot less than half a can. The relief of the milling helps to save material and still guarantee stability.
          Soon I will start building a bathroom mirror cabinet with a magic mirror. I will post the details in this forum again. :-)
          Best regards
          Josef
          Regards
          Josef
          http://www.spitzlberger.de/smartmirror, https://github.com/spitzlbergerj/MMM-TeslaLogger, https://github.com/spitzlbergerj/CaravanPi, https://www.la-gondola-barocca.de
          • E
            evgeniy88
            Thanks for your posts. At first I was skeptical about the idea of gluing a mirror on silicone, but now I want to use your design.
            • spitzlbergerjS
              Thanks a lot
              Josef
              Regards
              Josef
              • T
                tootiemac3
                Thank you for all this info.
                I am at the very start of my magic mirror journey and came across you mirror which is simply fantastic.
                I noticed you had metal LED buttons on the side of your frame which I would like to install one in mine for powering opn/off.
                Having looked at button tutorials I see most are just 2 jumper wires to the GIPO is this the same for your buttons?
                How is the LED powered?
                thanks!
                Vicki
                • spitzlbergerjS
                  please forgive the late reply. It slipped through.
                  I use these buttons: https://smile.amazon.de/gp/product/B00JSEX1A0/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
                  These have separate connections for “nomaly closed” NC and “normaly open” NO. And there are also the connections for the button LED.
                  But I did not connect the LEDs. Otherwise, besides the LED of the toothbrush and the LED of the mouthwash and the LED of the razor and … another LED would burn. Then I could slowly save the ceiling lighting in the bathroom :-)
                  Regards
                  Josef
                  • P
                    PeterKatana
                    Hi Josef,
                    Looks very impressive. Which source do you use for the wooden frame?
                    Thanks a lot
                    Peter
                    • spitzlbergerjS
                      spitzlbergerj Project Sponsor Module Developer @PeterKatana
                      Hi @PeterKatana,
                      What do you mean by source?
                      The frame is made of beech wood. You can buy it from a wood dealer or carpenter. I have taken solid wood shelf savior made of beech from the hardware store. These are glued rod-wise and therefore torsion-resistant.
                      Regards
                      Josef
                      Regards
                      Josef
                      • P
                        PeterKatana @spitzlbergerj
                        @spitzlbergerj said in Bathroom Magic Mirror:
                        Hi Josef,
                        thanks for the recommendation. I will search here for a carpenter. A miter saw I should have. Before I lived in Aschheim, that was easier. Now I am jobwise in Göppingen. Will search around.
                        I am curious for your next project you announced.
                        Stay safe !
                        Br Peter
                        • spitzlbergerjS
                          Hallo @PeterKatana,
                          Ich kann dir den Rahmen auch zuschneiden, wenn du mir die Maße sagst. Vielleicht kommst du ja mal nach Oberschleißheim oder in die Nähe.
                          Grüße
                          Sepp
                          Regards
                          Josef
                            SuneRadich
                            Your mirror looks amazing, but I am wondering. How is the electronics holding up, being put in a bathroom with alot of moisture? I cant see you did anything extra to keep moisture out of the mirror?
                            • spitzlbergerjS
                              spitzlbergerj Project Sponsor Module Developer @SuneRadich
                              Hi @SuneRadich ,
                              all electrical connections are clamped together in junction boxes for damp locations. The Raspberry Pi is also in such a box. Only the connections of the screen are in their original box, which in my view is not specially protected against moisture.
                              So far, there have been no problems and even if you remove the mirror, you won’t see anything scorched or similar damage.
                              Regards
                              Josef
                              Regards
                              Josef
                              • M
                                MaXi-XCeL Project Sponsor
                                Just amazing! So well executed. Thank you for the inspiration! :)
                                • P
                                  Servus @spitzlbergerj ,
                                  danke für Dein Angebot. Ich habe gestern noch nach Deiner Empfehlung einen Schreiner gefunden. Hoffe, der bekommt das jetzt hin. Falls das nicht klappen sollte, komme ich gern auf Dein Angebot zurück. Ist ja mein erster MM insofern vermute ich, das ich sowieso mit 100 Fragen zurück komme und vielleicht auch den Rahmen wieder verändern muss. Wir werden sehen. Tolle Community übrigens !
                                  Grüße Peter
                                  • spitzlbergerjS
                                    @PeterKatana, alles klar, melde dich einfach. Ich werde morgen den MagicAlibert weiterbauen. Die Spiegel sollten nächste Woche kommen ;-)
                                    Regards
                                    Josef
                                    • P
                                      Hallo @spitzlbergerj,
                                      eine Frage kommt mir noch in den Sinn: Ich habe meinen Spiegel so designed, dass ich einen IR Frame (Touch Screen) mit verwenden kann. Was ist denn Deine Meinung zu solchen Dingen. Im Bad wahrscheinlich nicht so praktisch, aber ich dachte im Flur, wenn man noch Aktivitäten steuern mag …wie Musik, oder das Display im Karusell …
                                      Vielen Dank ! Vg Peter
                                      • spitzlbergerjS
                                        Hi @PeterKatana,
                                        im Bad würde ich das nicht machen. Der Woman Acceptance Faktor würde vermutlich rasant in den Keller gehen, wenn auf dem Spiegel ständig “Dapper” (wie man in Bayern sagt) sind.
                                        Ich habe einen Spiegel mit einen Standard 7" Raspberry Monitor. Aber selbst da habe ich Touch am Ende nie benutzt. Es sind bei mir einfach InfoSchirme. Aktionen löse ich über Schalter, Taster, … aus.
                                        Regards
                                        Josef
                                        P 2 Replies Last reply Reply Quote 0
                                        • P
                                          Hi @spitzlbergerj ,
                                          Du hast schon Recht. Der Woman Acceptance Factor würde sicher darunter leiden. So richtig viele Anwendungsfälle außer vielleicht Musik steuern oder bei den Nachrichten weiterschalten fallen mir auch nicht ein. Mal schaun. Ich bau das mal zusammen mit dem IR Frame. Vielleicht entstehen da noch Szenarien, wo es sinnvoll ist.
                                          Danke für Deine Einschätzung !
                                          Vg Peter
                                          • E
                                            ernade @spitzlbergerj
                                            Beech wood
                                            Hi, A really nice work.
                                            could I ask you how do you rotate the imageod the screen in portrait?
                                            I am havin some difficulty to let’s happen in my screen. It goes to blue screen (of course not Windows blue screen).
                                            Raspeberry 4 B
                                            • 3 / 4
