    Stop the screensaver!
    42 Posts 17 Posters 49.5k Views 16 Watching
    • Mykle1M
      Mykle1 Project Sponsor Module Developer @m0111k
      @m0111k said in Stop the screensaver!:
      ps im newb here, how can i remove xscreensaver when it doesnt work? Thanks
      sudo apt-get remove xscreensaver
      However, I don’t think xscreensaver is capable of putting your display into standby. That is likely your system or settings.
      A 1 Reply Last reply
      • A
        Anthony Project Sponsor @Mykle1
        @Mykle1
        Is there any possibillity that Lucy interacts somehow with the screen saver? I am asking this because I have installed xscreensaver and working good but if I have lucy enabled I get the black screen and I must move the mouse to sho the MM again. Just a thought!
        Mykle1M 1 Reply Last reply
        • Mykle1M
          Mykle1 Project Sponsor Module Developer @Anthony
          @Anthony
          Perhaps, but I’ve never seen this behavior or heard about it before this. I will see if I can reproduce that here.
          • Mykle1M
            @Anthony
            I’m not seeing this behavior at all. You can clearly see that I have xscreensaver running with the “Screen Saver DIsabled” but I can’t reproduce what it happening to you. Lucy responds normally and no black screen issue. If you say “SHOW MODULES” does Lucy show them?
            ![0_1551838003790_Screenshot.png](Uploading 100%)
            Edit: Something seems to be amiss. The forum isn’t allowing me to post an image at the moment.
            Picture below.
            • Mykle1M
              • A
                @Mykle1
                Thank you for your reply. I haven’t try to see if Lucy works when I see the black screen because I can’t see the “Say, ‘Hello Lucy’” message and because of the latency problems I have I don’t know when it recognizes the keyword and wait for commands. My guess is that it will work but when I am finished with my mirrorsetup I will hung it on the wall so I won’t have mouse and keyboard connected to move or press a button for the mirror to show. Also the black screen appears not only in the standby mode. Last night I left the mirror showing my page 1 modules and in the morning I saw the black screen again. Moved the mouse and evertything showed up.
                  sdetweil @Anthony
                  @Anthony said in Stop the screensaver!:
                  that means screensaver kicked in… MM doesn’t do module visibility by mouse movement…
                  • A
                    Anthony Project Sponsor @sdetweil
                    I agree. But it doesn’t happen when I have voice disabled in my config. And I realized that it also doesn’t happen with voice enabled and MMM-ImageSlideShow showing my pics. Maybe because the pictures change every 10 seconds. But if I have voice enabled and MM shows only clock, calendar, weather etc after 30 minutes screen goes black.
                      sdetweil @Anthony
                      @Anthony and if MM is not running at all, what happens?
                      I run voice, and imageslideshow and don’t see this. If I shut down MM, screen will stay in forever
                      • A
                        Mine too. If MM is shut down my screen is always on. This also happen if modules with movement are shown in the MM like MMM-ImageSlideShow which have pictures rotating. My screen goes black only when I have modules like clock,calendar,forunecookie,rfacs etc shown. I don’t know if a specific module cause this. For example I now have my MM on for 5 days without black screen and the modules shown are clock, calendar, stats, compliments, news, pictures and weather. If I hide pictures module or replace it with rfacts for example in about half an hour I will get the screensaver black screen.
                        • A
                          Update.
                          Last 3-4 days my MM was running just fine without screensaver appears. Last night it happened again so I restart MM in dev mode to see if I find an error after the the screensaver’s black screen. When I moved the mouse (after some time the screensaver had appeared) the screen was white and in dev console I had a message saying websocket disconnected or something like that. Usually when I moved the mouse after the screensaver and without the dev tools enabled the black screen dissapears and I get my MM screen back. This time was different. I’ll try to upload a screenshot when I get home.
                            sdetweil
                            usually when u see that the MM runtime has crashed for some reason… even the debug console is gone
                            I haven’t found a way to debug what has happened… I see this occasionally…
                            • A
                              This is getting too weird. Yesterday I had the MM running in dev mode and after I saw the screensaver I moved the mouse and everything came back as normal and no errors in the console. I don’t know why this happens not all the time and with different characteristics everytime.
                                sdetweil @Anthony
                                @Anthony when the screen went to sleep was the developer window hidden too?
                                when my MMM-SleepWake hides all the modules, the Developers console is still on the screen
                                • A
                                  In my case when the screen goes to sleep everything is hidden, modules, dev console etc. I see only black screen. Is there any possibility that pi “forgets” the setting to disable the screensaver? I will try to go and change this setting and after put it back again to see if anyhting changes.
                                    sdetweil @Anthony
                                    @Anthony interesting… neither of my systems has forgotten the screen saver setting, been running for over 2 years now…
                                    • A
                                      I don’t think that this is the problem but I want to test it just in case.
                                      • B
                                        bhepler Module Developer
                                        At this point, I’m thinking a sudo apt-get update && sudo apt-get upgrade might be in order. There could be a bug in the Pi’s power management routines.
                                        • A
                                          Anthony Project Sponsor @bhepler
                                          @bhepler
                                          I will try this as well but 3 days now the problem does not appear. I haven’t touch anything on my MM and I don’t see the black screen. I will try a sudo apt-get update && sudo apt-get upgrade although. It is always usefull. Thank you.
                                          • A
                                            This is a screenshot of what happened after about half an hour after restarting magic mirror.0_1552744358584_2019-03-16-154428_1366x768_scrot.png
                                            B 1 Reply Last reply
                                            • 2 / 3
