    55" LED TV Cr4z33 Mirror
    26 Posts 13 Posters 30.6k Views 10 Watching
    • Cr4z33C Offline
      Cr4z33
      So after 14 days I was FINALLY able to find a volunteer strong enough to help me hanging this 30 kg 55" smart mirror to the bathroom wall! :face_with_tears_of_joy:
      I took inspiration from @spitzlbergerj wonderfull smart mirror and I have to thank him for giving me the Sketchup file and all the informations needed! :thumbs_up_medium_skin_tone:
      The frame is made by beechwood (all the cutting and moulding was made by a carpenter) with specific measures to perfectly contain the LED TV.
      The glass has been glued to the frame by using a very special glue called Soudal Fix All High Tack.
      Keep it in mind if you want to make a borderless smart mirror as it is very effective.
      List of parts:
      • Raspberry Pi 3 B+
      • 55" Samsung LED TV UE55NU7170
      • Beech strips
      • Pilkington MirroView glass
      • 15W SEBSON Mirror Light LED
      • Poly Pool pp2522.2 Spaziozero Socket Rack
      • BTicino S3610D/F Connector Adaptor for P 30 and Pin 10 Amp with Lightning Protection
      • USB microphone Andoer (I made a hole at the bottom in the center of the frame to fit it)
      • 2 x GedoTec Cabinet hanger Cabinet suspension invisible Upper cabinet Buoyancy 130 kg Steel zinc plated for Press-in operation (find in the link also the leftside hanger)
      • A bunch of very good & handy WAGO 221-413 ELECTRICAL WIRE BLOCK CONNECTOR STRIP
      • A generic 4000K LED strip all around the frame to improve room light
      List of 3rd-party modules:
      • MMM-AssistantMk2
      • MMM-DarkSkyForecast
      • MMM-Hotword
      • MMM-NowPlayingOnSpotify
      • MMM-PushBulletNotifications
      • MMM-Remote-Control
      • MMM-RTSPStream
      Some other pics of my mirror:
      Special thanks go to (again) @spitzlbergerj , @Sean (especially for custom voice command needs and for initial modules setup), @shbatm for struggling at trying to help me fixing bugs and (my bad) mistakes done by myself (:smiling_face_with_open_mouth_cold_sweat:), @evroom and whoever else I forgot to mention (sorry!).
      Feel free to ask here, but give me time to answer because I have a quite busy life. :face_with_stuck-out_tongue_winking_eye:
      SketchUp file for the frame:
      https://www.dropbox.com/s/rr23bbfu0i34ksa/Cr4z33 Mirror.skp?dl=0
      DæmonEyesD 1 Reply Last reply Reply Quote 14
      • DæmonEyesD Offline
        DæmonEyes @Cr4z33
        @cr4z33 That looks gorgeous! What was the total cost for the full project?
        Also could you post some pics to show the side profile of your mirror when it is up?
        • Cr4z33C Offline
          Cr4z33 @DæmonEyes
          @dæmoneyes I got the TV for free from Samsung because of a promotion.
          Everything else is almost all stuff I was already having apart from the hangers and other minor things.
          Let’s say that if I had to buy everything from scratch it would have costed about 600-700 EUR?
          Side view is where the LED strip is.
          Tell me if you want to see it anyway. 😉
            sdetweil @Cr4z33
            @cr4z33 what is the glass? very nice… I have a 50in that I want to do similarly…
            • Cr4z33C Offline
              Cr4z33 @sdetweil
              @sdetweil it’s all written in the OP. 😉
              • V Offline
                vinp Module Developer
                That looks amazing. Nice job on the glass and making it look clean! How thick is the frame of the wood (how much does it stick from the wall) And love seeing it in Italian… complimenti !
                • Cr4z33C Offline
                  Cr4z33 @vinp
                  @vinp grazie. 😁
                  It’s 6 cm deep.
                  The TV wasn’t that thick, but I wanted to leave 3-4 cm more for room to fit all the stuff behind.
                  • G Offline
                    ganget
                    @Cr4z33 Looks really clean, I really like the border less glass. Seems like it’s a high quality mirror you used there! Job well done! :winking_face: :thumbs_up:
                    • MichMichM Offline
                      MichMich
                      That is CRAAAAZY! Nice work man! :)
                      • Cr4z33C Offline
                        Cr4z33 @MichMich
                        @michmich no thanks to you instead!
                        if it wasn’t for you all this would NEVER have happened. :heart:
                        • strawberry 3.141S Offline
                          This looks pretty slick, good job @Cr4z33
                          • Cr4z33C Offline
                            Cr4z33 @strawberry 3.141
                            @strawberry-3-141 cheers! 👍🏼
                              AxLed Module Developer
                              @Cr4z33
                              Nice job, well done, very clean finish.
                              AxLED
                              • P Offline
                                PeterStahr
                                This looks amazing! Which MirroView did u use? The 50/50 or 70/30? I have built some OLED Mirrors in the past but this looks really great as well! Do you have pictures of the mirror at low light conditions?
                                Best,
                                Peter
                                • Cr4z33C Offline
                                  Cr4z33 @PeterStahr
                                  @PeterStahr that’s the 6mm normal version.
                                  What do you mean with ‘low light’?
                                  The first two pics are without lights turned on. :)
                                  • P Offline
                                    pmsmart
                                    Good. i’m amazing
                                    • C Offline
                                      chandra
                                      that’s super.
                                      A question:
                                      how is ur andoer mic ( https://www.amazon.co.uk/dp/B01LCIGY8U)?
                                      Asking this because my usb mic ( generic one) has lots of noise.
                                      Should i go with the andoer mic or usb sound card +mic ?
                                      • spitzlbergerjS Offline
                                        spitzlbergerj Project Sponsor Module Developer
                                        Very good job! Gratulations!
                                        Regards
                                        Josef
                                        http://www.spitzlberger.de/smartmirror, https://github.com/spitzlbergerj/MMM-TeslaLogger, https://github.com/spitzlbergerj/CaravanPi, https://www.la-gondola-barocca.de
                                        • Cr4z33C Offline
                                          Cr4z33 @spitzlbergerj
                                          @spitzlbergerj thank you for everything happy you like it. 😁
                                            bolish
                                            Hi @Cr4z33
                                            Which MirrorView glass did you use? the normal version or the 50/50?
