    Bathroom Magic Mirror
    67 Posts 25 Posters 101.4k Views 27 Watching
    • spitzlbergerjS Offline
      spitzlbergerj Project Sponsor Module Developer
      My first MagicMirror is now finished and mounted in our bathroom.
      my SmartMirror
      The following requirements had to be fulfilled:
      • maximum woman acceptance factor
      • minimum depth
      • rimless mirror
      • Mounting a LED light bar
      • Integration into my Homematic installation
      • Button to reboot the Raspberry pi
      • Button for further control tasks
      • Motion control
      I have planned the mirror with SketchUp:
      Picture 1:
      SketchUp
      Picture 2:
      SketchUp
      Picture 3:
      Fräsung für Silikonfuge/Milling groove for silicone joint
      SketchUp
      Picture 4:
      SketchUp
      Picture 5:
      SketchUp
      Picture 6:
      SketchUp
      Picture 7: (wall mount)
      SketchUp
      I used beechwood
      Picture 8:
      Picture 9:
      Entlüftungsöffnungen rechts und links oben/Vent opening (out) on left and right top
      Picture 10:
      Belüftungsöffnung unten/Vent opening (in) at the bottom
      Picture 11:
      Bohrungen für Taster/Holes for buttons
      Picture 12:
      Fräsung für Metallwinkel/Milling for metal angles
      Photos of the assembly
      Picture 13:
      assembly
      Picture 14:
      assembly
      Picture 15:
      assembly
      Picture 16:
      assembly
      Picture 17:
      assembly
      Picture 18:
      assembly
      Picture 19:
      back
      Picture 20:
      back
      Picture 21:
      back
      To connect the mirror to the power, I use a “cold device plug” (C13/C14 coupler). I split the former extension cable in the middle.
      And that’s how the mirror looks finished
      Picture 22:
      finished
      Picture 23:
      finished
      Picture 24:
      finished
      The following websites helped me with the construction and the configuration
      https://www.heise.de/ct/hotline/Ein-Ausschalter-fuer-Raspberry-Pi-und-Raspi-Zero-3892620.html?wt_mc=print.ct.2017.25.150
      https://webnist.de/python-script-auf-dem-raspberry-pi-automatisch-starten/
      https://pi-buch.info/hdmi-ausgang-unkompliziert-ein-und-ausschalten/
      https://www.nils-snake.de/archives/magic-mirror-bewegungssensor-einbauen-teil-5
      I have used:
      • Raspberry pi 3
      • Beech wood from the hardware store
      • Aluminium composite panel (ACP) with cutout (https://www.plattenzuschnitt24.de/ - german: Alu Dibond Platte)
      • Spy mirror (https://www.glas-star.de/spionspiegelnachmass/chrome-spy-spiegel/)
      • Silicone (PCI Silcofern S) Color: black (Important! Never use transparent silicone. Otherwise you will see it and regret it!)
      • Screen (HP 22w (1CA83AA) 54.6 cm (21.5 inch) monitor (IPS, Full HD, HDMI) https://smile.amazon.de/gp/product/B0732RBR3J/ref=oh_aui_detailpage_o01_s01?ie=UTF8&psc = 1)
      • Radar motion detector (Amazon Haljia 5 RCWL-0516)
      To fix the frame to the wall I use fittings as they are also used in the assembly of kitchen wall cabinets (see also picture 7). These are height-adjustable and depth-adjustable. The frame is fastened there over a vertical screw from above by the frame at the substructure. (see picture 24). I used these parts:
      rail: https://www.amazon.de/gp/product/B01MPZM5ER/ref=oh_aui_detailpage_o03_s00?ie=UTF8&psc=1
      fitting left: https://www.amazon.de/gp/product/B01BDR8JV0/ref=oh_aui_detailpage_o03_s00?ie=UTF8&psc=1
      fittign right: https://www.amazon.de/gp/product/B01BDR8K32/ref=oh_aui_detailpage_o03_s00?ie=UTF8&psc=1
      Download the Sketchup File
      Addendum to the motion detector - radar detector:
      In addition to the cutout for the monitor, I would now have an additional small cutout for the radar board (20 x 40 mm) made. The radar detector works perfectly, but unfortunately not through the Dibond plate. I had to fix it at the bottom of the frame. That’s OK, but it would have been perfect behind the mirror glass.
      Regards
      Josef
      http://www.spitzlberger.de/smartmirror, https://github.com/spitzlbergerj/MMM-TeslaLogger, https://github.com/spitzlbergerj/CaravanPi, https://www.la-gondola-barocca.de
      E 1 Reply Last reply Reply Quote 19
        Very impressive.
        • C Offline
          cyberphox
          wow that is nice!
          • Y Offline
            yawns Moderator
            Nice end result, well done. Your woodwork looks very professional
            • P Offline
              PaulB
              WOW! That looks so professional. Great work. Hope you have a lot of fun with the mirror :)
              • qu1queQ Offline
                qu1que Project Sponsor
                Wow!! I like your mirror a lot. Impressive the final result. What are the buttons for?
                spitzlbergerjS 1 Reply Last reply Reply Quote 0
                  spitzlbergerj Project Sponsor Module Developer @qu1que
                  @qu1que Thanks a lot for your post.
                  The bottom button boots the Raspberry in a safe way (without simply turning off the power)
                  The top button controls the lights in the bathroom via a homematic webservice.
                  Regards
                  Josef
                  • P Offline
                    PaulB
                    @spitzlbergerj
                    I love your work. Could you recommend any tipps on how to build a mirror in the bath? I would like to do this as my next project. So are there any Best Practices regarding any silicone or electronics?.
                    Greetings from Germany :)
                      spitzlbergerj Project Sponsor Module Developer @PaulB
                      @paulb Hallo Paul,
                      das Silicon, das ich verwendet habe, habe ich im Post angegeben. Der Spionspiegel verlangt ein spezielles Silicon (neutralvernetzend), damit die Beschichtung nicht angelöst wird. Und ansonsten habe ich Standard-Komponenten verwendet. Durch die Lüftungsöffnungen erhoffe ich mir eine bessere Belüftung. Bisher konnte ich keine Probleme feststellen.
                      Grüße
                      Sepp
                      Regards
                      Josef
                      • lavolp3L Offline
                        lavolp3 Module Developer
                        @spitzlbergerj Impressive mirror!
                        Especially like the lighting solution.
                        What glass did you use? (also from Germany here)
                        What is the material you have used for the backplate?
                        How to troubleshoot modules
                        MMM-soccer v2, MMM-AVStock
                          spitzlbergerj Project Sponsor Module Developer @lavolp3
                          Hi @lavolp3,
                          I bought the LED light bar here
                          As described in the last section of the article, I purchased the mirror from Glas-Star.de and the Aluminium composite panel (ACP - german: Alu Dibond) from plattenzuschnitt24.de as my backplate.
                          The Aluminium composite panel is 4 mm thick and serves as a “black background” and as a mounting surface for all installations. It also stiffens the wooden frame on which I screwed the plate.
                          greetings
                          Sepp
                          Regards
                          Josef
                          lavolp3L michael5rM 2 Replies Last reply Reply Quote 0
                          • lavolp3L Offline
                            lavolp3 Module Developer @spitzlbergerj
                            @spitzlbergerj OK so you’re using the Mirropane Chrome Spy there I assume.
                            Going to order that as well since I have the feeling it’s the best glass for a well lit bath.
                            Thanks for the Alu Dibond tip.
                            • P Offline
                              PaulB @spitzlbergerj
                              @spitzlbergerj Moin Sepp, danke für dein Feedback.
                              Werde es mal meiner Freundin vorschlagen… vllt wird das ja was :-D
                              Viele Grüße aus Hamburg,
                              Paul
                              • michael5rM Offline
                                michael5r Module Developer @spitzlbergerj
                                @spitzlbergerj Super nice build!
                                If you don’t mind, a couple of questions:
                                1. Seeing that you screwed the Dibond panel into the wood frame, did you cover up the screw holes afterwards or are they just not visible through the glass?
                                2. I didn’t see any brackets or bracing in the photos, so how are you actually holding the monitor in place?
                                Thanks!
                                  spitzlbergerj Project Sponsor Module Developer @michael5r
                                  @michael5r Good morning,
                                  I’ll be happy to answer the questions:
                                  1. I did not cover the screws. You still can’t see them through the glass.
                                    If you want to be sure, it should be sufficient to paint the screws with a black permanent marker.
                                    The only thing you see at the moment (if you know where to look ;-) ) is a small gap between the wooden frame and the silicone. At this point I apparently didn’t press the glass on well enough when I glued it to the frame. But that’s a little something.
                                  1. The monitor is actually already being fixed by the cutout in the Dibond plate. I adapted the cutout very exactly to the size of the screen. With an adhesive tape around it this is then sufficiently fixed. But I finally screwed two small angles to the wooden frame, which hold the monitor securely in the cutout of the panel. This is now doubly secure.
                                  Another tip about the motion detector (see also the supplement above in the text):
                                  Many greetings
                                  Sepp
                                  Regards
                                  Josef
                                    acdacd2
                                    Hello,
                                    very nice and waf.
                                    How did you fix the mirror on the wood ?
                                    Thanks,
                                    marc,
                                      spitzlbergerj Project Sponsor Module Developer @acdacd2
                                      @acdacd2 Hi, thank you very much.
                                      The mirror glass is glued with silicone. The groove in the frame serves this purpose. See also the pictures/photos 3, 8 as well as 17 and 18.
                                      Regards
                                      Josef
                                        SimtechBen
                                        Very Nice Mirror! Quality work. Can you tell me how you wired up the radar sensor and where you finally placed it? I am assuming that you are using it to turn the screen on and off. What module did you use for that? I cannot get mine to trigger reliably.
                                          bhepler Module Developer
                                          Excellent work! That is a really sharp looking mirror. And you obviously planned out a lot ahead of time. I especially love the cutouts for the angle brackets in the corners. That is some serious attention to detail.
                                            spitzlbergerj Project Sponsor Module Developer @bhepler
                                            @bhepler Thank you. Yes, I’ve planned a long time. The mirror should be allowed to hang in the bathroom :-)
                                            Regards
                                            Josef
                                            • 1 / 4
