    MMM-Gas
    56 Posts 13 Posters 45.0k Views 12 Watching
    • cowboysdudeC
      cowboysdude Module Developer @richland007
      @richland007 Do a git pull as things did change and I updated it a month ago or so.
      • richland007R
        richland007
        I did a git pull and than an npm install insde the module but still no luck only updated on today’s date and time.
        No list of gas stations nothing just that.
        Do we have to change anything in the module settings on the config.js file for the update??
        Denis
        Mykle1M 1 Reply Last reply
        • Mykle1M
          Mykle1 Project Sponsor Module Developer @richland007
          @richland007
          This should be your config entry. Have you tried another zip code? See if this one works.
                      disabled: false,
                      module: "MMM-Gas",
                      position: "top center",
                          zip: "10306"
          richland007R 1 Reply Last reply
          • richland007R
            richland007 @Mykle1
            @Mykle1 Nothing solved it but a complete rm -rf and than a reinstall now it works fine
            thank you
            D
            • Mykle1M
              @richland007
              :thumbsup:
                DDE12
                How do you change the size of the font in the module?
                  sdetweil @DDE12
                  @DDE12 custom.css, like always
                  look to see if it has a css file which would tell u the class names used,
                  then use custom.css to override those settings
                  D 1 Reply Last reply
                    DDE12 @sdetweil
                    @sdetweil There are two of them: MMM-Gas.css and MMM-Gas1.css. MMM-Gas did not seem to do anything and I was able to make some changes with MMM-Gas1 but not to the font size. Both css files have:
                    .MMM-Gas .xxsmall{
                    	font-size: 12px;
                    Changing it has no effect.
                    In dev mode, changing
                    .xsmall {
                        font-size: var(--font-size-xsmall);
                    from main.css does change the font size. I assume that this will affect any other module that uses the xsmall font.
                    Is there a way through my css to set the font size for this module only?
                      sdetweil @DDE12
                      @DDE12 yes, prefix the class with the module name
                      ..modulename .xsmall {
                      this is the documented way to use custom.css
                        DDE12 @sdetweil
                        @sdetweil That fixed it! Thank you! Looking back, I see that the module css has .xxsmall and the font size is determined by .xsmall. My brain glossed over that extra ‘x’. Maybe’s it’s a typo in the css because changing it does not seem to affect anything?
                          sdetweil @DDE12
                          @DDE12 sorry, don’t know the module…
                            DDE12
                            I recently noticed that the MMM-Gas module is not showing/working. All of my other modules are working. I removed all the modules except MMM-Gas from config.js and disabled the default modules and am just getting a black screen. There is no Loading or Undefined message. I deleted the module and reinstalled but got the same results. MM is installed on a Raspberry Pi. Please let me know what further info I can provide or steps to take to troubleshoot further. Thank you!
                              sdetweil @DDE12
                              @DDE12 can you show the mesages from npm start
                              if using pm2 to auto launch, then
                              pm2 logs --lines=???
                              ??? is some number of lines, default 15
                                DDE12 @sdetweil
                                admin@raspberrypi:~/Desktop/MagicMirror $ npm run start
                                > magicmirror@2.28.0 start
                                [2024-09-28 14:20:56.806] [LOG]   Starting MagicMirror: v2.28.0
                                [2024-09-28 14:20:56.892] [LOG]   Loading config ...
                                [2024-09-28 14:20:56.899] [LOG]   config template file not exists, no envsubst
                                [2024-09-28 14:20:56.909] [LOG]   Loading module helpers ...
                                [2024-09-28 14:20:59.198] [LOG]   Initializing new module helper ...
                                [2024-09-28 14:20:59.201] [LOG]   Module helper loaded: MMM-Gas
                                [2024-09-28 14:20:59.202] [LOG]   All module helpers loaded.
                                [2024-09-28 14:20:59.224] [LOG]   Starting server on port 8080 ...
                                [2024-09-28 14:21:00.473] [LOG]   Server started ...
                                [2024-09-28 14:21:00.479] [LOG]   Connecting socket for: MMM-Gas
                                [2024-09-28 14:21:00.482] [LOG]   Starting module: MMM-Gas
                                [2024-09-28 14:21:00.485] [LOG]   Sockets connected & modules started ...
                                [2024-09-28 14:21:02.543] [LOG]   Launching application.
                                [2024-09-28 14:21:07.261] [INFO]  System information:
                                ### SYSTEM:   manufacturer: Raspberry Pi Foundation; model: Raspberry Pi 2 Model B Rev 1.2; raspberry: [object Object]; virtual: false
                                ### OS:       platform: linux; distro: Raspbian GNU/Linux; release: 11; arch: arm; kernel: 6.1.21-v7+
                                ### VERSIONS: electron: 31.1.0; used node: 20.14.0; installed node: 20.11.0; npm: 10.2.4; pm2: 5.4.1
                                ### OTHER:    timeZone: America/New_York; ELECTRON_ENABLE_GPU: undefined
                                It doesn’t look like it is fetching the gas prices. ??
                                  JohnGalt
                                  @cowboysdude - We have a car that only takes premium, and a car that only requires regular. Is it possible to show prices for multiple grades of fuel in a single instance of the module? {Obviously I could install one instance, rename a bunch of stuff and then install a 2nd instance, but I’m wondering whether it can do it natively? Thanks in advance.
                                    sdetweil @JohnGalt
                                    @JohnGalt it cannot do it natively
                                    J 1 Reply Last reply
                                      JohnGalt @sdetweil
                                      @sdetweil Sam - thanks for the confirmation. I posted the question before installing it, and went ahead and installed just to see how it might look.
                                      It gave me some warnings on install regarding deprecated dependencies, then displayed… nothing. I tried to manually pull the gas price data using the url in code in the github repository but that just comes back as a 404, and the site map doesn’t give any hint that the site serves up this data.
                                      The odd part is I don’t see any error specific to this module in the pm2 logs [see below]. At this point I have removed the module folder and config.js code and life goes on. If there happens to be a way to get it to work, great - but let’s not spend a lot of time on it.
                                      Partial output from pm2 logs:
                                      PM2            | Change detected on path config/config.js for app MagicMirror - restarting
                                      PM2            | Stopping app:MagicMirror id:0
                                      0|MagicMirror  | /home/pi/MagicMirror/node_modules/electron/dist/electron exited with signal SIGINT
                                      PM2            | pid=28762 msg=failed to kill - retrying in 100ms
                                      PM2            | App [MagicMirror:0] exited with code [0] via signal [SIGINT]
                                      PM2            | pid=28762 msg=process killed
                                      PM2            | App [MagicMirror:0] starting in -fork mode-
                                      PM2            | App [MagicMirror:0] online
                                      0|MagicMirror  | > magicmirror@2.28.0 start
                                      0|MagicMirror  | > DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
                                      0|MagicMirror  | [2024-09-29 17:35:29.657] [LOG]   Starting MagicMirror: v2.28.0
                                      0|MagicMirror  | [2024-09-29 17:35:29.716] [LOG]   Loading config ...
                                      0|MagicMirror  | [2024-09-29 17:35:29.720] [LOG]   config template file not exists, no envsubst
                                      0|MagicMirror  | [2024-09-29 17:35:29.726] [LOG]   Loading module helpers ...
                                      0|MagicMirror  | [2024-09-29 17:35:29.727] [LOG]   No helper found for module: alert.
                                      0|MagicMirror  | [2024-09-29 17:35:29.737] [LOG]   Initializing new module helper ...
                                      0|MagicMirror  | [2024-09-29 17:35:29.739] [LOG]   Module helper loaded: MMM-WeatherAlerts
                                      0|MagicMirror  | [2024-09-29 17:35:29.743] [LOG]   Initializing new module helper ...
                                      0|MagicMirror  | [2024-09-29 17:35:29.743] [LOG]   Module helper loaded: MMM-WeatherAlerts2
                                      0|MagicMirror  | [2024-09-29 17:35:29.752] [LOG]   Initializing new module helper ...
                                      0|MagicMirror  | [2024-09-29 17:35:29.752] [LOG]   Module helper loaded: updatenotification
                                      0|MagicMirror  | [2024-09-29 17:35:29.754] [LOG]   No helper found for module: clock.
                                      0|MagicMirror  | [2024-09-29 17:35:29.755] [LOG]   No helper found for module: MMM-Worldclock.
                                      0|MagicMirror  | [2024-09-29 17:35:29.924] [LOG]   Initializing new module helper ...
                                      0|MagicMirror  | [2024-09-29 17:35:29.925] [LOG]   Module helper loaded: calendar
                                      0|MagicMirror  | [2024-09-29 17:35:29.926] [LOG]   Initializing new module helper ...
                                      0|MagicMirror  | [2024-09-29 17:35:29.927] [LOG]   Module helper loaded: calendar
                                      0|MagicMirror  | [2024-09-29 17:35:29.996] [LOG]   Initializing new module helper ...
                                      0|MagicMirror  | [2024-09-29 17:35:29.996] [LOG]   Module helper loaded: MMM-Tools
                                      0|MagicMirror  | [2024-09-29 17:35:29.997] [LOG]   No helper found for module: MMM-Multimonth.
                                      0|MagicMirror  | [2024-09-29 17:35:30.017] [LOG]   Initializing new module helper ...
                                      0|MagicMirror  | [2024-09-29 17:35:30.017] [LOG]   Module helper loaded: MMM-OpenWeatherMapForecast
                                      0|MagicMirror  | [2024-09-29 17:35:30.280] [LOG]   Initializing new module helper ...
                                      0|MagicMirror  | [2024-09-29 17:35:30.281] [LOG]   Module helper loaded: MMM-Pollen
                                      0|MagicMirror  | [2024-09-29 17:35:30.283] [LOG]   No helper found for module: weather.
                                      0|MagicMirror  | [2024-09-29 17:35:30.391] [LOG]   Initializing new module helper ...
                                      0|MagicMirror  | [2024-09-29 17:35:30.392] [LOG]   Module helper loaded: newsfeed
                                      0|MagicMirror  | [2024-09-29 17:35:30.398] [LOG]   Initializing new module helper ...
                                      0|MagicMirror  | [2024-09-29 17:35:30.399] [LOG]   Module helper loaded: MMM-DynamicWeather
                                      0|MagicMirror  | [2024-09-29 17:35:30.401] [LOG]   All module helpers loaded.
                                      0|MagicMirror  | [2024-09-29 17:35:30.415] [LOG]   Starting server on port 8080 ...
                                      0|MagicMirror  | [2024-09-29 17:35:31.199] [LOG]   Server started ...
                                      0|MagicMirror  | [2024-09-29 17:35:31.214] [LOG]   Connecting socket for: MMM-WeatherAlerts
                                      0|MagicMirror  | [2024-09-29 17:35:31.217] [LOG]   Starting module helper: MMM-WeatherAlerts
                                      0|MagicMirror  | [2024-09-29 17:35:31.219] [LOG]   Connecting socket for: MMM-WeatherAlerts2
                                      0|MagicMirror  | [2024-09-29 17:35:31.220] [LOG]   Starting module helper: MMM-WeatherAlerts2
                                      0|MagicMirror  | [2024-09-29 17:35:31.222] [LOG]   Connecting socket for: updatenotification
                                      0|MagicMirror  | [2024-09-29 17:35:31.224] [LOG]   Starting module helper: updatenotification
                                      0|MagicMirror  | [2024-09-29 17:35:31.226] [LOG]   Connecting socket for: calendar
                                      0|MagicMirror  | [2024-09-29 17:35:31.228] [LOG]   Starting node helper for: calendar
                                      0|MagicMirror  | [2024-09-29 17:35:31.230] [LOG]   Connecting socket for: calendar
                                      0|MagicMirror  | [2024-09-29 17:35:31.231] [LOG]   Starting node helper for: calendar
                                      0|MagicMirror  | [2024-09-29 17:35:31.246] [LOG]   Connecting socket for: MMM-Tools
                                      0|MagicMirror  | [2024-09-29 17:35:31.250] [LOG]   [Tools] MMM-Tools Version: 2.1.7
                                      0|MagicMirror  | [2024-09-29 17:35:31.252] [LOG]   Connecting socket for: MMM-OpenWeatherMapForecast
                                      0|MagicMirror  | [2024-09-29 17:35:31.254] [LOG]   Starting node_helper for MMM-OpenWeatherMapForecast
                                      0|MagicMirror  | [2024-09-29 17:35:31.255] [LOG]   Connecting socket for: MMM-Pollen
                                      0|MagicMirror  | [2024-09-29 17:35:31.273] [LOG]   MMM-Pollen helper started ...
                                      0|MagicMirror  | [2024-09-29 17:35:31.275] [LOG]   Connecting socket for: newsfeed
                                      0|MagicMirror  | [2024-09-29 17:35:31.277] [LOG]   Starting node helper for: newsfeed
                                      0|MagicMirror  | [2024-09-29 17:35:31.279] [LOG]   Connecting socket for: MMM-DynamicWeather
                                      0|MagicMirror  | [2024-09-29 17:35:31.281] [LOG]   Sockets connected & modules started ...
                                      0|MagicMirror  | [2024-09-29 17:35:32.168] [LOG]   Launching application.
                                      0|MagicMirror  | [2843:0929/173533.164645:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                                      0|MagicMirror  | [2843:0929/173533.166603:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                                      0|MagicMirror  | [2843:0929/173533.167945:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                                      0|MagicMirror  | [2843:0929/173533.169873:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                                      0|MagicMirror  | [2843:0929/173533.171528:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                                      0|MagicMirror  | [2843:0929/173533.172716:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                                      0|MagicMirror  | [2843:0929/173533.174129:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                                      0|MagicMirror  | [2843:0929/173533.175313:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                                      0|MagicMirror  | [2843:0929/173533.176763:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                                      0|MagicMirror  | [2843:0929/173533.178279:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                                      0|MagicMirror  | [2843:0929/173533.180011:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                                      0|MagicMirror  | [2843:0929/173533.181255:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                                      0|MagicMirror  | [2843:0929/173533.182716:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                                      0|MagicMirror  | [2843:0929/173533.183904:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                                      0|MagicMirror  | [2843:0929/173533.185245:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                                      0|MagicMirror  | [2843:0929/173533.187096:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                                      0|MagicMirror  | [2843:0929/173533.188547:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                                      0|MagicMirror  | [2843:0929/173533.190111:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                                      0|MagicMirror  | [2843:0929/173533.191549:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                                      0|MagicMirror  | [2843:0929/173533.193083:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                                      0|MagicMirror  | [2843:0929/173533.194679:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                                      0|MagicMirror  | [2843:0929/173533.196231:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                                      0|MagicMirror  | [2843:0929/173533.197720:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                                      0|MagicMirror  | [2843:0929/173533.199227:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                                      0|MagicMirror  | [2843:0929/173533.200454:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                                      0|MagicMirror  | [2843:0929/173533.201574:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                                      0|MagicMirror  | [2843:0929/173533.202846:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                                      0|MagicMirror  | [2843:0929/173533.204087:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                                      0|MagicMirror  | [2843:0929/173533.207329:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                                      0|MagicMirror  | [2843:0929/173533.208602:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                                      0|MagicMirror  | [2843:0929/173533.209921:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                                      0|MagicMirror  | [2843:0929/173533.211042:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                                      0|MagicMirror  | [2843:0929/173533.212311:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                                      0|MagicMirror  | [2843:0929/173533.213479:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                                      0|MagicMirror  | [2843:0929/173533.215374:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                                      0|MagicMirror  | [2843:0929/173533.216465:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                                      0|MagicMirror  | [2843:0929/173533.217793:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                                      0|MagicMirror  | [2843:0929/173533.219444:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                                      0|MagicMirror  | [2843:0929/173533.221185:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                                      0|MagicMirror  | [2843:0929/173533.222712:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                                      0|MagicMirror  | [2843:0929/173533.224067:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                                      0|MagicMirror  | [2843:0929/173533.225628:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                                      0|MagicMirror  | [2024-09-29 17:35:36.587] [INFO]  System information:
                                      0|MagicMirror  | ### SYSTEM:   manufacturer: Raspberry Pi Foundation; model: Raspberry Pi 4 Model B Rev 1.1; raspberry: [object Object]; virtual: false
                                      0|MagicMirror  | ### OS:       platform: linux; distro: Raspbian GNU/Linux; release: 11; arch: arm; kernel: 6.1.21-v8+
                                      0|MagicMirror  | ### VERSIONS: electron: 31.1.0; used node: 20.14.0; installed node: 20.9.0; npm: 10.1.0; pm2: 5.4.1
                                      0|MagicMirror  | ### OTHER:    timeZone: America/Los_Angeles; ELECTRON_ENABLE_GPU: undefined
                                        sdetweil @JohnGalt
                                        @JohnGalt i dont see mmm-gas in the loaded modules list
                                        J 2 Replies Last reply
                                          JohnGalt @sdetweil
                                          @sdetweil – True. I’m not sure why that is. I will try reinstalling it.
                                            JohnGalt @sdetweil
                                            @cowboysdude
                                            So i reinstalled this module, and it still does not display on the Magic Mirror. [
                                            It now it does appear to load the module:
                                            0|MagicMirror  | [2024-09-30 16:19:22.987] [LOG]   Connecting socket for: MMM-Gas
                                            0|MagicMirror  | [2024-09-30 16:19:22.988] [LOG]   Starting module: MMM-Gas
                                            And check the status of the module along with others:
                                            0|MagicMirror  | [2024-09-30 16:19:32.585] [INFO]  Newsfeed-Fetcher: Broadcasting 38 items.
                                            0|MagicMirror  | [2024-09-30 16:19:32.936] [INFO]  Checking git for module: MMM-Pollen
                                            0|MagicMirror  | [2024-09-30 16:19:33.379] [INFO]  Checking git for module: MMM-Gas
                                            0|MagicMirror  | [2024-09-30 16:19:33.570] [INFO]  Newsfeed-Fetcher: Broadcasting 30 items.
                                            0|MagicMirror  | [2024-09-30 16:19:33.724] [INFO]  Checking git for module: MMM-DynamicWeather
                                            0|MagicMirror  | [2024-09-30 16:19:34.030] [INFO]  Checking git for module: MagicMirror
                                            But there is still something missing.
                                            Could it has something to do with the dependency issues?
                                            pi@mirror1:~/MagicMirror/modules $ git clone https://github.com/cowboysdude/MMM-Gas
                                            Cloning into 'MMM-Gas'...
                                            remote: Enumerating objects: 135, done.
                                            remote: Counting objects: 100% (6/6), done.
                                            remote: Compressing objects: 100% (6/6), done.
                                            remote: Total 135 (delta 2), reused 0 (delta 0), pack-reused 129 (from 1)
                                            Receiving objects: 100% (135/135), 89.19 KiB | 553.00 KiB/s, done.
                                            Resolving deltas: 100% (67/67), done.
                                            pi@mirror1:~/MagicMirror/modules $ cd MMM-Gas
                                            pi@mirror1:~/MagicMirror/modules/MMM-Gas $ NPM INSTALL
                                            -bash: NPM: command not found
                                            pi@mirror1:~/MagicMirror/modules/MMM-Gas $ npm install
                                            npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
                                            added 67 packages, and audited 68 packages in 12s
                                            17 packages are looking for funding
                                              run `npm fund` for details
                                            2 moderate severity vulnerabilities
                                            Some issues need review, and may require choosing
                                            a different dependency.
                                            Run `npm audit` for details.
                                            • 2 / 3
