    MMM-voice
    voice control
    329 Posts 55 Posters 1.1m Views 50 Watching
    • E
      ealfaror
      The module works very good! I’m Spanish and I have had to modify some words to improve the results.
      But, I’ve a question:
      I want use only the VOICE module. It’s possible to predefine that module when MagicMirror starts?
      Thanks!
      • strawberry 3.141S
        strawberry 3.141 Project Sponsor Module Developer @ealfaror
        @ealfaror Currently it’s not supported. If you want to change it https://github.com/fewieden/MMM-voice/blob/f9eb4cd4bde5c64ef894e8625250c4092aa0d4a7/node_helper.js#L18 this is were you need to change it mode: "VOICE". But keep in mind that manual changes can make trouble by a module update
        • E
          ealfaror @strawberry 3.141
          @strawberry-3.141 Thanks! I’ve changed it and it works!
          I hope I’ll remember it when the module updates. :)
          • A
            Allred
            I am not sure what I am missing/doing wrong. I have gotten everything installed and working after several attempts. I enabled debugging so I could see what it was capturing. Magic mirror activated microphone just fine. I could see the text below it that it was recognising, but if I said hide, or hide modules. It won’t hide any modules.
            • strawberry 3.141S
              strawberry 3.141 Project Sponsor Module Developer @Allred
              @Allred sounds like you didn’t enter the voice mode first
              MAGIC MIRROR VOICE HIDE MODULES will activate the microphone, switch to voice mode and performs the task hide modules.
              For every following command in the voice mode you have to say
              MAGIC MIRROR SHOW MODULES or when the microphone is already active just SHOW MODULES until you switch into another mode, then you would have to say voice again
              Mykle1M 1 Reply Last reply Reply Quote -1
              • Mykle1M
                Mykle1 Project Sponsor Module Developer @strawberry 3.141
                @strawberry-3.141
                What do I need?
                Do I need a specific microphone?
                If I get a webcam with a built in microphone, will that work?
                If the webcam microphone will work, which webcam do you recommend?
                I just want to have everything I need before I try anything, thanks.
                • strawberry 3.141S
                  strawberry 3.141 Project Sponsor Module Developer @Mykle1
                  @Mykle1 i’m just using a usb microphone, never tried a buil in mic of a webcam because i don’t have one
                  • Mykle1M
                    @strawberry-3.141 said in MMM-voice:
                    i’m just using a usb microphone, never tried a buil in mic of a webcam because i don’t have one.
                    I actually got it working on a laptop with Ubuntu so I am now trying it on the Pi 3 with MMM-voice and a Logitech USB microphone. It loads with “Initializing” next to the microphone and for a second it shows “Ready, choose a mode.” but then it changes to Error. I tried to make it the default in Audio Device Settings on the Pi3 but it keeps going back to "bcm2835 (ALSA mixer) (Default). It won’t keep the “AK5370 (Alsa mixer)” as default.
                     0 [ALSA           ]: bcm2835 - bcm2835 ALSA
                                          bcm2835 ALSA
                     1 [AK5370         ]: USB-Audio - AK5370
                                          AKM AK5370 at usb-3f980000.usb-1.2, full speed
                    I’m going to bed!
                    • strawberry 3.141S
                      @Mykle1 just set the config to microphone: 1
                      • Mykle1M
                        I guess I should have mentioned that I already have that setting. I was tired. Does this mean that microphone is not compatible?
                        • strawberry 3.141S
                          @Mykle1 if you want i can have a look via remote desktop session
                          • Mykle1M
                            That would be great but I have to run to work for a few hours. I’ll be back in about 4 hours. So, perhaps later if you are available. I’d appreciate that.
                            • Mykle1M
                              Mykle1 Project Sponsor Module Developer @Mykle1
                              I’m here for a while if you should come around
                              • Mykle1M
                                @strawberry-3.141
                                I tested my microphone on the Pi by doing this:
                                pi@Pi3:~ $ arecord -D plughw:1,0 test.wav
                                Recording WAVE 'test.wav' : Unsigned 8 bit, Rate 8000 Hz, Mono
                                ^CAborted by signal Interrupt...
                                pi@Pi3:~ $
                                That gave me this: 0_1489005574631_soundfile.JPG
                                Which sounds ok. Clear, and not too much white noise.
                                As long as my Audio Device Settings looks like this:0_1489005776320_audiodevicesettings.JPG
                                I am not in debug mode
                                     			module: 'MMM-voice',
                                     			position: 'top_right',
                                         		microphone: 1,
                                			keyword: 'MAGIC MIRROR', // UPPERCASE ONLY
                                			timeout: 15
                                However, I am getting this: 0_1489006683272_fairest.JPG
                                At least we got it working
                                strawberry 3.141S johnnyboyJ 2 Replies Last reply Reply Quote 0
                                • strawberry 3.141S
                                  @Mykle1 the second line is in debug mode only
                                  • Mykle1M
                                    So, can I remove that from showing?
                                    • strawberry 3.141S
                                      @Mykle1 it shouldn’t be there when you not added debug flag in the config
                                      Mykle1M 3 Replies Last reply Reply Quote 0
                                      • Mykle1M
                                        @strawberry-3.141
                                        I’ll try debug: false and see what happens
                                        • Mykle1M
                                          @strawberry-3.141
                                          You’re right again. I had config.js opened twice. One with debug and one without. I removed debug and saved and closed both. Now it’s fine. One last thing, if you don’t mind, I’d like to align everything in MMM-voice to the right margin. Please and thank you. :thumbsup_tone1:
                                          • Mykle1M
                                            @strawberry-3.141 Oh, and I can change the 'MAGIC MIRROR" activation phrase to something else?
                                            • 16
                                            • 17
                                            • 4 / 17
