    Weatherunderground - currently - hourly - daily - configurable
    182 Posts 47 Posters 427.7k Views 51 Watching
    • N
      nevint
      Noob issue here. How do I update the program? I get an alert saying to update wunderground, but I don’t know how to do that!
      • cowboysdudeC
        cowboysdude Module Developer @nevint
        @nevint said in Weatherunderground - currently - hourly - daily - configurable:
        In a terminal window go to :
        MagicMirror/modules/wunderground
        Then type:
        git pull
        That should update it.
        • K
          kasperb @RedNax
          @RedNax I’ve tried changing this in the main MMM-WunderGround CSS and custom CSS, but neither seem to affect the font size. (note that my goal is to increase the font size):
          .MMM-WunderGround .smaller {
              font-size: 80%;
          and
          .MMM-WunderGround .smaller { font-size: 80%; }
          Any guidance would be appreciated.
          • strawberry 3.141S
            strawberry 3.141 Project Sponsor Module Developer @kasperb
            @kasperb only the wind direction icon is using the class smaller, so with your selector you would only change this specific icon.
              DeanoAus
              Hey guys, Is there any way to troubleshoot this? I’m stuck on “Loading…”
              Installed the latest module, config is below. My api works as I’ve tested it with another module.
              I’m stuck!
              		    module: 'MMM-WunderGround',
              		    position: 'top_left',
              		        apikey: 'blah',
                      pws: 'pws:INSWTHEO3',
              			hourly: '1',
              		        fctext: '1',
              		        fcdaycount: "9",
              		        fcdaystart: "1",
              		        hourlyinterval: "3",
              		        hourlycount: "3",
              		        alerttime: 30000,
              		        alerttruncatestring: "english:",
              			roundTmpDecs: '1',
              		    	layout: "vertical",
              			windunits: "mph",
              			coloricon: true,
              		    	sysstat: 0
              K 1 Reply Last reply
              • K
                kasperb @DeanoAus
                @DeanoAus The only thing I can think of is adding the " " to coloricon value:
                coloricon: "true",
                D 1 Reply Last reply
                  DeanoAus @kasperb
                  @kasperb Thanks mate, I restarted the pi and it just randomly started working. Nothing in logs to indicate why. shrugs
                  • KimzerK
                    Kimzer
                    My temperature isnt changing whatsoever, it stays stuck on 17.3 degrees, what could be the issue here? Anyone?
                    bheplerB 1 Reply Last reply
                    • bheplerB
                      bhepler Module Developer @Kimzer
                      @Kimzer Most likely, it’s a problem with the Weather Underground database. If something is preventing them from receiving an update from the weather station they use to provide you with conditions, then they’ll just stay there until they resolve the issue.
                      You could try shifting the forecast to another location just to verify that the temperature does change over time. If other locations update, then the problem is on their end. If it doesn’t update temperature at all, then come back and we’ll see what we can find.
                      Reply Quote 2
                        cyberphox
                        Mine is stuck on 20.0 degrees for a few weeks now…haven’t had time to troubleshoot it either…
                        Mykle1M 1 Reply Last reply
                        • Mykle1M
                          Mykle1 Project Sponsor Module Developer @cyberphox
                          @cyberphox said in Weatherunderground - currently - hourly - daily - configurable:
                          Try what @bhepler suggested. Try a different pws: to see if that’s the problem. Here is mine if you want to test with that. It’s working normally.
                          pws: 'pws:KNYNEWYO103',
                          • KimzerK
                            Kimzer
                            Using a different pws worked for me. Now its all good.
                            Only wondering how i can change the colors of the temperature and the weather forecast text, anyone got some custom css for it? =)
                            J 1 Reply Last reply
                              j.e.f.f Project Sponsor Module Developer @Kimzer
                              @Kimzer which part are you looking to change? The big temperature in current conditions? Or the min/max temps in the forecast table? Same question for the forecast text – is this the current day’s forecast (i.e.: grey text above the large current temperature) or the text within the forecast table? Also, are you using the vertical or horizontal layout? If I recall correctly, the class names change slightly with the layout. Let me know and I can get you started with the CSS.
                              • KimzerK
                                Kimzer
                                alt text
                                The parts marked in red is what i want to change color on (Y)
                                Thanks for helping j.e.f.f :)
                                  @Kimzer Try these. Adjust the color values as you like.
                                  For the large temperature display:
                                  .MMM-WunderGround .large .bright {
                                    color: #FFFFCC;
                                  The human-readable text forecast:
                                  .MMM-WunderGround table.small tr:first-child td {
                                    color: #FFFFCC;
                                  The hours in the forecast table:
                                  .MMM-WunderGround .hourv {
                                    color: #FFFFCC;
                                  I applied these style to the MMM-WunderGround module and you can see how these three items are coloured the buttery colour I specified:
                                  F 1 Reply Last reply
                                  • KimzerK
                                    Kimzer
                                    Perfect! Thanks alot! :D
                                    • F
                                      Fonfon @j.e.f.f
                                      @j.e.f.f How you make a table style ? i love it !
                                        j.e.f.f Project Sponsor Module Developer @Fonfon
                                        @Fonfon That’s the default for MMM-WunderGround, using the custom styles I posted above. Here’s my config:
                                                position: 'top_right',
                                                    apikey: 'my_api_key', // private; don't share!
                                                    pws: 'pws:IONTORON421',
                                                    hourly: '1',
                                                    fctext: '1',
                                                    fcdaycount: "5",
                                                    fcdaystart: "0",
                                                    hourlycount: "2",
                                                    alerttime: 10000,
                                                    roundTmpDecs: 1,
                                                    UseCardinals: 0,
                                                    layout: "vertical",
                                                    sysstat: 0,
                                                    coloricon: true,
                                        • F
                                          Fonfon @j.e.f.f
                                          @j.e.f.f ok layout change i’m in a horizontale style not verticale
                                          thanks man ;)
                                          • F
                                            fredall
                                            Hi is it possible to combine the horizontal view for the hourly forecast and vertical for daily ?
                                            • 10
                                            • 8 / 10
