    Weatherunderground - currently - hourly - daily - configurable
    182 Posts 47 Posters 403.8k Views 51 Watching
    • K Offline
      kasperb @RedNax
      @RedNax I’ve tried changing this in the main MMM-WunderGround CSS and custom CSS, but neither seem to affect the font size. (note that my goal is to increase the font size):
      .MMM-WunderGround .smaller {
          font-size: 80%;
      and
      .MMM-WunderGround .smaller { font-size: 80%; }
      Any guidance would be appreciated.
      • strawberry 3.141S Offline
        strawberry 3.141 Project Sponsor Module Developer @kasperb
        @kasperb only the wind direction icon is using the class smaller, so with your selector you would only change this specific icon.
          DeanoAus
          Hey guys, Is there any way to troubleshoot this? I’m stuck on “Loading…”
          Installed the latest module, config is below. My api works as I’ve tested it with another module.
          I’m stuck!
          		    module: 'MMM-WunderGround',
          		    position: 'top_left',
          		        apikey: 'blah',
                  pws: 'pws:INSWTHEO3',
          			hourly: '1',
          		        fctext: '1',
          		        fcdaycount: "9",
          		        fcdaystart: "1",
          		        hourlyinterval: "3",
          		        hourlycount: "3",
          		        alerttime: 30000,
          		        alerttruncatestring: "english:",
          			roundTmpDecs: '1',
          		    	layout: "vertical",
          			windunits: "mph",
          			coloricon: true,
          		    	sysstat: 0
          • K Offline
            kasperb @DeanoAus
            @DeanoAus The only thing I can think of is adding the " " to coloricon value:
            coloricon: "true",
              DeanoAus @kasperb
              @kasperb Thanks mate, I restarted the pi and it just randomly started working. Nothing in logs to indicate why. shrugs
              • KimzerK Offline
                Kimzer
                My temperature isnt changing whatsoever, it stays stuck on 17.3 degrees, what could be the issue here? Anyone?
                • bheplerB Offline
                  bhepler Module Developer @Kimzer
                  @Kimzer Most likely, it’s a problem with the Weather Underground database. If something is preventing them from receiving an update from the weather station they use to provide you with conditions, then they’ll just stay there until they resolve the issue.
                  You could try shifting the forecast to another location just to verify that the temperature does change over time. If other locations update, then the problem is on their end. If it doesn’t update temperature at all, then come back and we’ll see what we can find.
                    cyberphox
                    Mine is stuck on 20.0 degrees for a few weeks now…haven’t had time to troubleshoot it either…
                      Mykle1 Project Sponsor Module Developer @cyberphox
                      @cyberphox said in Weatherunderground - currently - hourly - daily - configurable:
                      Try what @bhepler suggested. Try a different pws: to see if that’s the problem. Here is mine if you want to test with that. It’s working normally.
                      pws: 'pws:KNYNEWYO103',
                      • KimzerK Offline
                        Kimzer
                        Using a different pws worked for me. Now its all good.
                        Only wondering how i can change the colors of the temperature and the weather forecast text, anyone got some custom css for it? =)
                          j.e.f.f Project Sponsor Module Developer @Kimzer
                          @Kimzer which part are you looking to change? The big temperature in current conditions? Or the min/max temps in the forecast table? Same question for the forecast text – is this the current day’s forecast (i.e.: grey text above the large current temperature) or the text within the forecast table? Also, are you using the vertical or horizontal layout? If I recall correctly, the class names change slightly with the layout. Let me know and I can get you started with the CSS.
                          • KimzerK Offline
                            Kimzer
                            alt text
                            The parts marked in red is what i want to change color on (Y)
                            Thanks for helping j.e.f.f :)
                              @Kimzer Try these. Adjust the color values as you like.
                              For the large temperature display:
                              .MMM-WunderGround .large .bright {
                                color: #FFFFCC;
                              The human-readable text forecast:
                              .MMM-WunderGround table.small tr:first-child td {
                                color: #FFFFCC;
                              The hours in the forecast table:
                              .MMM-WunderGround .hourv {
                                color: #FFFFCC;
                              I applied these style to the MMM-WunderGround module and you can see how these three items are coloured the buttery colour I specified:
                              • KimzerK Offline
                                Kimzer
                                Perfect! Thanks alot! :D
                                • F Offline
                                  Fonfon @j.e.f.f
                                  @j.e.f.f How you make a table style ? i love it !
                                    j.e.f.f Project Sponsor Module Developer @Fonfon
                                    @Fonfon That’s the default for MMM-WunderGround, using the custom styles I posted above. Here’s my config:
                                            position: 'top_right',
                                                apikey: 'my_api_key', // private; don't share!
                                                pws: 'pws:IONTORON421',
                                                hourly: '1',
                                                fctext: '1',
                                                fcdaycount: "5",
                                                fcdaystart: "0",
                                                hourlycount: "2",
                                                alerttime: 10000,
                                                roundTmpDecs: 1,
                                                UseCardinals: 0,
                                                layout: "vertical",
                                                sysstat: 0,
                                                coloricon: true,
                                    • F Offline
                                      Fonfon @j.e.f.f
                                      @j.e.f.f ok layout change i’m in a horizontale style not verticale
                                      thanks man ;)
                                      • F Offline
                                        fredall
                                        Hi is it possible to combine the horizontal view for the hourly forecast and vertical for daily ?
                                          maestro82
                                          What variables control the size of the large current weather icon and the small forecast icons? I was trying to make the current icon slightly smaller and have somehow managed to make the forecast icon micro sized. Can’t seem to get it back now.
                                          Thanks,
                                            maestro82 @maestro82
                                            @maestro82 Got it, a little trail and error.
                                            • 10
                                            • 8 / 10
