    690 Posts 77 Posters 3.1m Views 70 Watching
      rezocharly @tbbear
      @tbbear I live in a windy area. Today Force 5/6.
      As you can see with this screenshot the O doesn’t appear. Even if the config.js is well setup to display this information (as you can see on the post above)
      Capture_d_e_cran_2017_12_14_a_17_46_39
      tbbearT cowboysdudeC 2 Replies Last reply Reply Quote 0
      • tbbearT Offline
        tbbear Module Developer @rezocharly
        @rezocharly ok, so its another problem.
        First the lines “ALERT” and the “Warning Level:” are parts of ur language translation file. So add them their and it will show in the correct language. Here my de.json file from translation dir.
        "***ALERT***":"*** Wetterwarnungen ***",
        "Warning Level: ":"Warnstufe: ",
        Second ur wind problem. This module depends on wunderground which is a network of personal wheaterstations. NOT every person who has a PWS has also a wind sensor. Maybe u try to select another
        StationID which has one. (i had the same problem too)
        Third with alerts: false i have this in my config.js just before the line position: … and it works.
        Robert the Bear
        • cowboysdudeC Offline
          cowboysdude Module Developer @rezocharly
          @rezocharly said in MMM-NOAA - Another Weather Module:
          Just add this to your custom css
          .MMM-NOAA .set {
          float: left;
            rezocharly @tbbear
            @tbbear
            Thanks a lot for this information I got it but unfortunately nobody have a wind sensor around me :)
            I confirm, just before the line position, alerts are not displayed anymore.
              @rezocharly just disable that in the config like this:
              showWind: false
              As for the alerts I’m gonna let @tbbear chime in on this one…he rewrote the alerts :)
                Peter
                This module works perfect … almost …
                Is it possible to change CET in alerts to MET ( I use the Dutch translation)?
                Peter
                tbbearT 1 Reply Last reply Reply Quote 0
                • tbbearT Offline
                  tbbear Module Developer @Peter
                  @Peter The translation for the alerts depends on google translate, so at the moment we cant change this
                  Robert the Bear
                    Peter @tbbear
                    @tbbear thanks!
                    Peter
                      mac0178
                      Nice Module, really love it.
                      Unfortunately i have a problem with another module (mmm-traffic) while NOAA is active. The font there should be colored but now it´s background is completely colored. While NOAA is disabled, everything is fine.
                      Any clue?
                      thx,
                      Mac
                        cowboysdude Module Developer @mac0178
                        @mac0178 Let me take a look perhaps a css tag is similar :) Ahhhhhh yes perhaps this is it…
                        In the NOAA css file there is this:
                        .red{
                        	background:#f00;
                        .green{
                        	background:#0f0;
                        .blue{
                        	background:#00f;
                        and in the MMM-Traffic module there is this:
                        .green {
                          color: #83FFB3;
                        .yellow {
                          color: yellow;
                        .red {
                          color: #FF4C4C;
                        So I’m going to update the css file and you can try it again :)
                        Just go to the MagicMirror/modules/MMM-NOAA dir and type
                        git pull
                        that should update the css file :)
                          mac0178
                          Yeah, that´s it!
                          Thank you very much, great support!
                          Mykle1M cowboysdudeC 2 Replies Last reply Reply Quote 1
                            Mykle1 Project Sponsor Module Developer @mac0178
                            @mac0178 said in MMM-NOAA - Another Weather Module:
                            Yeah, he’s a guru! :-)
                              @mac0178 glad it worked! :)
                              • ChrisC Offline
                                Chris
                                I tried to install this module but I can not make it work.
                                instead of the module on the magic mirror screen, it says: “weather info”
                                I attach to this post my config file:
                                			module: 'MMM-NOAA',
                                			position: 'top_right',
                                				apiKey: "a3cXXXXX",    // https://www.wunderground.com/weather/api  select the middle plan...
                                				useAir: true,             // set to false if you do not want to use Air Quality Index
                                				airKey: "Z4pXXXXXXX",    // IF you want Air Quality Index
                                				pws: "pws:I93SEVRA3",         // go here to find your pws: https://www.wunderground.com/wundermap
                                				lat: "48.919XXX",        // need this for sunrise/sunset  if left blank none will show  -- find them here: http://www.latlong.net/
                                				lon: "2.533XXX",       // need this for sunrise/sunset  if left blank none will showshowClock: true,           // Hides or shows clock
                                				dformat: false,             // for M/D/YYYY format, false for D/M/YYYY
                                				format: "24",              // 12 or 24 hour format.. will default to 12 hour if none selected.
                                				ampm: false,                // to show AM and PM on Sunrise/Sunset time
                                				showGreet: false,          // deafult is false - to show greeting under clock and above date
                                				name: "",                  // Your name
                                				showWind: true,
                                				showDate: false,
                                				showForecast: true,         //show bottom 3 day forecast
                                				flash: true,                 //Today in forecast flashes halo
                                				showUV: true,               //show UV index
                                				showBar: true,             // show Barometer
                                				showHum: true,              //show Humidity level
                                				position: 'top_right',       //whatever you have in above position must also be here
                                				alert: true                //show weather alerts default is true
                                By contrast, weather underground works properly so I think it does not come from the API key.
                                Does anyone have an idea? Thank you
                                  cowboysdude Module Developer @Chris
                                  @Chris start the mirror like this
                                  npm start dev
                                  in that window let me know what if any errors you’re getting :)
                                  • ChrisC Offline
                                    Chris
                                    Thank you for your prompt response,
                                    here is what is indicated at startup:
                                    > magicmirror@2.2.1 start /home/pi/MagicMirror
                                    > sh run-start.sh "dev"
                                    Starting MagicMirror: v2.2.1
                                    Loading config ...
                                    Loading module helpers ...
                                    No helper found for module: calendar_monthly.
                                    Module helper loaded: MMM-MyCommute
                                    Module helper loaded: MMM-SoccerLiveScore
                                    Module helper loaded: MMM-soccer
                                    No helper found for module: MMM-Globe.
                                    Module helper loaded: MMM-Remote-Control
                                    Module helper loaded: mmm-suncalc
                                    Module helper loaded: MMM-NOAA
                                    No helper found for module: mmm-wu-moonphase.
                                    Module helper loaded: MMM-Tools
                                    No helper found for module: MMM-Snow.
                                    All module helpers loaded.
                                    Server started ...
                                    Connecting socket for: MMM-MyCommute
                                    ====================== Starting node_helper for module [MMM-MyCommute]
                                    Connecting socket for: MMM-SoccerLiveScore
                                    MMM-SoccerLiveScore helper started...
                                    Connecting socket for: MMM-soccer
                                    Starting module: MMM-soccer
                                    Connecting socket for: MMM-Remote-Control
                                    Starting node helper for: MMM-Remote-Control
                                    Connecting socket for: mmm-suncalc
                                    Starting node_helper for mmm-suncalc:
                                    Connecting socket for: MMM-NOAA
                                    Starting module: MMM-NOAA
                                    Connecting socket for: MMM-Tools
                                    Starting module: newsfeed
                                    Launching application.
                                    Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/XXXX/basic.ics - Interval: 300000
                                    Get league table for url http://api.football-data.org/v1/competitions/450/leagueTable
                                    Create new news fetcher for url: http://www.leparisien.fr/actualites-a-la-une.rss.xml#xtor=RSS-1481423633 - Interval: 300000
                                    TypeError: Cannot read property 'observation_location' of undefined
                                        at Request.request [as _callback] (/home/pi/MagicMirror/modules/MMM-NOAA/node_helper.js:26:49)
                                        at Request.self.callback (/home/pi/MagicMirror/node_modules/request/request.js:186:22)
                                        at emitTwo (events.js:106:13)
                                        at Request.emit (events.js:191:7)
                                        at Request. (/home/pi/MagicMirror/node_modules/request/request.js:1163:10)
                                        at emitOne (events.js:96:13)
                                        at Request.emit (events.js:188:7)
                                        at IncomingMessage. (/home/pi/MagicMirror/node_modules/request/request.js:1085:12)
                                        at IncomingMessage.g (events.js:286:16)
                                        at emitNone (events.js:91:20)
                                    Thanks for your help
                                      @Chris said in MMM-NOAA - Another Weather Module:
                                      Cannot read property ‘observation_location’ of undefined
                                      Not seeing your location…
                                      ChrisC 1 Reply Last reply Reply Quote 0
                                      • ChrisC Offline
                                        Chris @cowboysdude
                                        @cowboysdude said in MMM-NOAA - Another Weather Module:
                                        I corrected the pws value and it works. I made a mistake in the way of writing it.
                                        instead of
                                        pws: "I93SEVRA3",
                                        Sorry to have bothered you for so little
                                        Thank you very much for your help
                                          @Chris Hahhahaahha it happens :) Glad you got it working!!! You didn’t bother me!!
                                            Peter
                                            First: this is a beautiful module, I like it very much!
                                            But sometimes it does strange things: today is thursday and normally the module would show today, friday, saturday, etc.
                                            But sometimes the module suddenly shows wednesday (yesterday) only.
                                            After restarting (or from itself) the module is normal again.
                                            Somebody any idea?
                                            Peter
                                            cruunnerrC 1 Reply Last reply Reply Quote 0
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 34
                                            • 35
                                            • 13 / 35
