    690 Posts 77 Posters 3.1m Views 70 Watching
      Peter @tbbear
      @tbbear thanks!
      Peter
        mac0178
        Nice Module, really love it.
        Unfortunately i have a problem with another module (mmm-traffic) while NOAA is active. The font there should be colored but now it´s background is completely colored. While NOAA is disabled, everything is fine.
        Any clue?
        thx,
        Mac
        • cowboysdudeC Offline
          cowboysdude Module Developer @mac0178
          @mac0178 Let me take a look perhaps a css tag is similar :) Ahhhhhh yes perhaps this is it…
          In the NOAA css file there is this:
          .red{
          	background:#f00;
          .green{
          	background:#0f0;
          .blue{
          	background:#00f;
          and in the MMM-Traffic module there is this:
          .green {
            color: #83FFB3;
          .yellow {
            color: yellow;
          .red {
            color: #FF4C4C;
          So I’m going to update the css file and you can try it again :)
          Just go to the MagicMirror/modules/MMM-NOAA dir and type
          git pull
          that should update the css file :)
            mac0178
            Yeah, that´s it!
            Thank you very much, great support!
            Mykle1M cowboysdudeC 2 Replies Last reply Reply Quote 1
              Mykle1 Project Sponsor Module Developer @mac0178
              @mac0178 said in MMM-NOAA - Another Weather Module:
              Yeah, he’s a guru! :-)
                @mac0178 glad it worked! :)
                • ChrisC Offline
                  Chris
                  I tried to install this module but I can not make it work.
                  instead of the module on the magic mirror screen, it says: “weather info”
                  I attach to this post my config file:
                  			module: 'MMM-NOAA',
                  			position: 'top_right',
                  				apiKey: "a3cXXXXX",    // https://www.wunderground.com/weather/api  select the middle plan...
                  				useAir: true,             // set to false if you do not want to use Air Quality Index
                  				airKey: "Z4pXXXXXXX",    // IF you want Air Quality Index
                  				pws: "pws:I93SEVRA3",         // go here to find your pws: https://www.wunderground.com/wundermap
                  				lat: "48.919XXX",        // need this for sunrise/sunset  if left blank none will show  -- find them here: http://www.latlong.net/
                  				lon: "2.533XXX",       // need this for sunrise/sunset  if left blank none will showshowClock: true,           // Hides or shows clock
                  				dformat: false,             // for M/D/YYYY format, false for D/M/YYYY
                  				format: "24",              // 12 or 24 hour format.. will default to 12 hour if none selected.
                  				ampm: false,                // to show AM and PM on Sunrise/Sunset time
                  				showGreet: false,          // deafult is false - to show greeting under clock and above date
                  				name: "",                  // Your name
                  				showWind: true,
                  				showDate: false,
                  				showForecast: true,         //show bottom 3 day forecast
                  				flash: true,                 //Today in forecast flashes halo
                  				showUV: true,               //show UV index
                  				showBar: true,             // show Barometer
                  				showHum: true,              //show Humidity level
                  				position: 'top_right',       //whatever you have in above position must also be here
                  				alert: true                //show weather alerts default is true
                  By contrast, weather underground works properly so I think it does not come from the API key.
                  Does anyone have an idea? Thank you
                    cowboysdude Module Developer @Chris
                    @Chris start the mirror like this
                    npm start dev
                    in that window let me know what if any errors you’re getting :)
                    • ChrisC Offline
                      Chris
                      Thank you for your prompt response,
                      here is what is indicated at startup:
                      > magicmirror@2.2.1 start /home/pi/MagicMirror
                      > sh run-start.sh "dev"
                      Starting MagicMirror: v2.2.1
                      Loading config ...
                      Loading module helpers ...
                      No helper found for module: calendar_monthly.
                      Module helper loaded: MMM-MyCommute
                      Module helper loaded: MMM-SoccerLiveScore
                      Module helper loaded: MMM-soccer
                      No helper found for module: MMM-Globe.
                      Module helper loaded: MMM-Remote-Control
                      Module helper loaded: mmm-suncalc
                      Module helper loaded: MMM-NOAA
                      No helper found for module: mmm-wu-moonphase.
                      Module helper loaded: MMM-Tools
                      No helper found for module: MMM-Snow.
                      All module helpers loaded.
                      Server started ...
                      Connecting socket for: MMM-MyCommute
                      ====================== Starting node_helper for module [MMM-MyCommute]
                      Connecting socket for: MMM-SoccerLiveScore
                      MMM-SoccerLiveScore helper started...
                      Connecting socket for: MMM-soccer
                      Starting module: MMM-soccer
                      Connecting socket for: MMM-Remote-Control
                      Starting node helper for: MMM-Remote-Control
                      Connecting socket for: mmm-suncalc
                      Starting node_helper for mmm-suncalc:
                      Connecting socket for: MMM-NOAA
                      Starting module: MMM-NOAA
                      Connecting socket for: MMM-Tools
                      Starting module: newsfeed
                      Launching application.
                      Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/XXXX/basic.ics - Interval: 300000
                      Get league table for url http://api.football-data.org/v1/competitions/450/leagueTable
                      Create new news fetcher for url: http://www.leparisien.fr/actualites-a-la-une.rss.xml#xtor=RSS-1481423633 - Interval: 300000
                      TypeError: Cannot read property 'observation_location' of undefined
                          at Request.request [as _callback] (/home/pi/MagicMirror/modules/MMM-NOAA/node_helper.js:26:49)
                          at Request.self.callback (/home/pi/MagicMirror/node_modules/request/request.js:186:22)
                          at emitTwo (events.js:106:13)
                          at Request.emit (events.js:191:7)
                          at Request. (/home/pi/MagicMirror/node_modules/request/request.js:1163:10)
                          at emitOne (events.js:96:13)
                          at Request.emit (events.js:188:7)
                          at IncomingMessage. (/home/pi/MagicMirror/node_modules/request/request.js:1085:12)
                          at IncomingMessage.g (events.js:286:16)
                          at emitNone (events.js:91:20)
                      Thanks for your help
                        @Chris said in MMM-NOAA - Another Weather Module:
                        Cannot read property ‘observation_location’ of undefined
                        Not seeing your location…
                        ChrisC 1 Reply Last reply Reply Quote 0
                        • ChrisC Offline
                          Chris @cowboysdude
                          @cowboysdude said in MMM-NOAA - Another Weather Module:
                          I corrected the pws value and it works. I made a mistake in the way of writing it.
                          instead of
                          pws: "I93SEVRA3",
                          Sorry to have bothered you for so little
                          Thank you very much for your help
                            @Chris Hahhahaahha it happens :) Glad you got it working!!! You didn’t bother me!!
                              Peter
                              First: this is a beautiful module, I like it very much!
                              But sometimes it does strange things: today is thursday and normally the module would show today, friday, saturday, etc.
                              But sometimes the module suddenly shows wednesday (yesterday) only.
                              After restarting (or from itself) the module is normal again.
                              Somebody any idea?
                              Peter
                              cruunnerrC 1 Reply Last reply Reply Quote 0
                              • cruunnerrC Offline
                                cruunnerr @Peter
                                @Peter
                                It sounds like your whole MagicMirror instance freezes. But you can only see this at the NOAA module, because once the modules have loaded their informations they will show (without updated informations) their stuff.
                                So the other modules freezes, too but u can’t recognize it because u normally see no refreshing data. But on the NOAA module u expect a change of the shown data.
                                Sorry, my english is bad. Hope u could understand.
                                please check your log files and post the content
                                  Peter @cruunnerr
                                  @cruunnerr your english is good to understand.
                                  I think my MM is freezing indeed (see my other thread “something is wrong”).
                                  But I do not understand why NOAA gives yesterdays weather while freezing.
                                  If it gave only todays wheather I would understand.
                                  I suspect one of the other modules making my MM freeze.
                                  But which one …
                                  Peter
                                    cruunnerr
                                    if u use pm2, u should check pm2 logs and check the errors. Other way is to start MM with develop mode: npm start dev or with ssh: DISPLAY=:0 npm start dev
                                    Or start it with Firefox on your pc and use Firebug
                                      Peter @cruunnerr
                                      @cruunnerr , I am very sorry and it sounds stupid, but I have no idea how my MM starts.
                                      I had a lot problems to make its start automatically, but now it works.
                                      I cannot stop MM, only minimalise it with CRTL-M.
                                      SSH does not work (for some reason) VNC works well.
                                      Peter
                                        Peter
                                        After every update of MMM-NOAA the current weather is back in english again.
                                        Translation of the current weather is not in the Dutch translation file.
                                        Any idea how to fix this definitely?
                                        Peter
                                          Mykle1 Project Sponsor Module Developer @Peter
                                          @Peter said in MMM-NOAA - Another Weather Module:
                                          Isn’t the nl.json file Dutch translations? If not, you can help. How does that sound? :-)
                                          • Take any one of the translation files that you find in the tranaslations folder of the MMM-NOAA folder.
                                          • Make a copy of the file and rename the copy
                                          • Edit the copy . Don’t edit the left side which are the English words.
                                          • Edit the right side words so that they are the correct translations in Dutch for English words on the left side.
                                          • Save the file and submit it to the author
                                            Peter @Mykle1
                                            @Mykle1 thanks.
                                            I did something like that.
                                            This part is missing in the nl.json:
                                            "OVERCAST": "Overcast",
                                            "CLOUDY": "Cloudy",
                                            "RAIN": "Rain",
                                            "CLEAR": "Clear",
                                            "PARTLY_CLOUDY": "Partly Cloudy",
                                            So, I copied this from the en.json, pasted it in the nl.json and translated the right side, like this:
                                            "OVERCAST": "Grotendeels bewolkt",
                                            "CLOUDY": "Bewolkt",
                                            "RAIN": "Regen",
                                            "CLEAR": "Helder",
                                            "PARTLY_CLOUDY": "Gedeeltelijk bewolkt",
                                            After restarting MM it shows: Overcast …
                                            Strange about this: in the older version of NOAA the same part is missing in nl.json, but the translation is ok.
                                            So I presume the translation is somewhere else …
                                            Peter
                                            tbbearT 1 Reply Last reply Reply Quote 0
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 34
                                            • 35
                                            • 13 / 35
