    • tbbearT Offline
      tbbear Module Developer @Peter
      @Peter The translation for the alerts depends on google translate, so at the moment we cant change this
      Robert the Bear
        Peter @tbbear
        @tbbear thanks!
        Peter
          mac0178
          Nice Module, really love it.
          Unfortunately i have a problem with another module (mmm-traffic) while NOAA is active. The font there should be colored but now it´s background is completely colored. While NOAA is disabled, everything is fine.
          Any clue?
          thx,
          Mac
          • cowboysdudeC Offline
            cowboysdude Module Developer @mac0178
            @mac0178 Let me take a look perhaps a css tag is similar :) Ahhhhhh yes perhaps this is it…
            In the NOAA css file there is this:
            .red{
            	background:#f00;
            .green{
            	background:#0f0;
            .blue{
            	background:#00f;
            and in the MMM-Traffic module there is this:
            .green {
              color: #83FFB3;
            .yellow {
              color: yellow;
            .red {
              color: #FF4C4C;
            So I’m going to update the css file and you can try it again :)
            Just go to the MagicMirror/modules/MMM-NOAA dir and type
            git pull
            that should update the css file :)
              mac0178
              Yeah, that´s it!
              Thank you very much, great support!
              Mykle1M cowboysdudeC 2 Replies Last reply Reply Quote 1
                Mykle1 Project Sponsor Module Developer @mac0178
                @mac0178 said in MMM-NOAA - Another Weather Module:
                Yeah, he’s a guru! :-)
                  @mac0178 glad it worked! :)
                  • ChrisC Offline
                    Chris
                    I tried to install this module but I can not make it work.
                    instead of the module on the magic mirror screen, it says: “weather info”
                    I attach to this post my config file:
                    			module: 'MMM-NOAA',
                    			position: 'top_right',
                    				apiKey: "a3cXXXXX",    // https://www.wunderground.com/weather/api  select the middle plan...
                    				useAir: true,             // set to false if you do not want to use Air Quality Index
                    				airKey: "Z4pXXXXXXX",    // IF you want Air Quality Index
                    				pws: "pws:I93SEVRA3",         // go here to find your pws: https://www.wunderground.com/wundermap
                    				lat: "48.919XXX",        // need this for sunrise/sunset  if left blank none will show  -- find them here: http://www.latlong.net/
                    				lon: "2.533XXX",       // need this for sunrise/sunset  if left blank none will showshowClock: true,           // Hides or shows clock
                    				dformat: false,             // for M/D/YYYY format, false for D/M/YYYY
                    				format: "24",              // 12 or 24 hour format.. will default to 12 hour if none selected.
                    				ampm: false,                // to show AM and PM on Sunrise/Sunset time
                    				showGreet: false,          // deafult is false - to show greeting under clock and above date
                    				name: "",                  // Your name
                    				showWind: true,
                    				showDate: false,
                    				showForecast: true,         //show bottom 3 day forecast
                    				flash: true,                 //Today in forecast flashes halo
                    				showUV: true,               //show UV index
                    				showBar: true,             // show Barometer
                    				showHum: true,              //show Humidity level
                    				position: 'top_right',       //whatever you have in above position must also be here
                    				alert: true                //show weather alerts default is true
                    By contrast, weather underground works properly so I think it does not come from the API key.
                    Does anyone have an idea? Thank you
                      cowboysdude Module Developer @Chris
                      @Chris start the mirror like this
                      npm start dev
                      in that window let me know what if any errors you’re getting :)
                      • ChrisC Offline
                        Chris
                        Thank you for your prompt response,
                        here is what is indicated at startup:
                        > magicmirror@2.2.1 start /home/pi/MagicMirror
                        > sh run-start.sh "dev"
                        Starting MagicMirror: v2.2.1
                        Loading config ...
                        Loading module helpers ...
                        No helper found for module: calendar_monthly.
                        Module helper loaded: MMM-MyCommute
                        Module helper loaded: MMM-SoccerLiveScore
                        Module helper loaded: MMM-soccer
                        No helper found for module: MMM-Globe.
                        Module helper loaded: MMM-Remote-Control
                        Module helper loaded: mmm-suncalc
                        Module helper loaded: MMM-NOAA
                        No helper found for module: mmm-wu-moonphase.
                        Module helper loaded: MMM-Tools
                        No helper found for module: MMM-Snow.
                        All module helpers loaded.
                        Server started ...
                        Connecting socket for: MMM-MyCommute
                        ====================== Starting node_helper for module [MMM-MyCommute]
                        Connecting socket for: MMM-SoccerLiveScore
                        MMM-SoccerLiveScore helper started...
                        Connecting socket for: MMM-soccer
                        Starting module: MMM-soccer
                        Connecting socket for: MMM-Remote-Control
                        Starting node helper for: MMM-Remote-Control
                        Connecting socket for: mmm-suncalc
                        Starting node_helper for mmm-suncalc:
                        Connecting socket for: MMM-NOAA
                        Starting module: MMM-NOAA
                        Connecting socket for: MMM-Tools
                        Starting module: newsfeed
                        Launching application.
                        Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/XXXX/basic.ics - Interval: 300000
                        Get league table for url http://api.football-data.org/v1/competitions/450/leagueTable
                        Create new news fetcher for url: http://www.leparisien.fr/actualites-a-la-une.rss.xml#xtor=RSS-1481423633 - Interval: 300000
                        TypeError: Cannot read property 'observation_location' of undefined
                            at Request.request [as _callback] (/home/pi/MagicMirror/modules/MMM-NOAA/node_helper.js:26:49)
                            at Request.self.callback (/home/pi/MagicMirror/node_modules/request/request.js:186:22)
                            at emitTwo (events.js:106:13)
                            at Request.emit (events.js:191:7)
                            at Request. (/home/pi/MagicMirror/node_modules/request/request.js:1163:10)
                            at emitOne (events.js:96:13)
                            at Request.emit (events.js:188:7)
                            at IncomingMessage. (/home/pi/MagicMirror/node_modules/request/request.js:1085:12)
                            at IncomingMessage.g (events.js:286:16)
                            at emitNone (events.js:91:20)
                        Thanks for your help
                          @Chris said in MMM-NOAA - Another Weather Module:
                          Cannot read property ‘observation_location’ of undefined
                          Not seeing your location…
                          ChrisC 1 Reply Last reply Reply Quote 0
                          • ChrisC Offline
                            Chris @cowboysdude
                            @cowboysdude said in MMM-NOAA - Another Weather Module:
                            I corrected the pws value and it works. I made a mistake in the way of writing it.
                            instead of
                            pws: "I93SEVRA3",
                            Sorry to have bothered you for so little
                            Thank you very much for your help
                              @Chris Hahhahaahha it happens :) Glad you got it working!!! You didn’t bother me!!
                                Peter
                                First: this is a beautiful module, I like it very much!
                                But sometimes it does strange things: today is thursday and normally the module would show today, friday, saturday, etc.
                                But sometimes the module suddenly shows wednesday (yesterday) only.
                                After restarting (or from itself) the module is normal again.
                                Somebody any idea?
                                Peter
                                cruunnerrC 1 Reply Last reply Reply Quote 0
                                • cruunnerrC Offline
                                  cruunnerr @Peter
                                  @Peter
                                  It sounds like your whole MagicMirror instance freezes. But you can only see this at the NOAA module, because once the modules have loaded their informations they will show (without updated informations) their stuff.
                                  So the other modules freezes, too but u can’t recognize it because u normally see no refreshing data. But on the NOAA module u expect a change of the shown data.
                                  Sorry, my english is bad. Hope u could understand.
                                  please check your log files and post the content
                                    Peter @cruunnerr
                                    @cruunnerr your english is good to understand.
                                    I think my MM is freezing indeed (see my other thread “something is wrong”).
                                    But I do not understand why NOAA gives yesterdays weather while freezing.
                                    If it gave only todays wheather I would understand.
                                    I suspect one of the other modules making my MM freeze.
                                    But which one …
                                    Peter
                                      cruunnerr
                                      if u use pm2, u should check pm2 logs and check the errors. Other way is to start MM with develop mode: npm start dev or with ssh: DISPLAY=:0 npm start dev
                                      Or start it with Firefox on your pc and use Firebug
                                        Peter @cruunnerr
                                        @cruunnerr , I am very sorry and it sounds stupid, but I have no idea how my MM starts.
                                        I had a lot problems to make its start automatically, but now it works.
                                        I cannot stop MM, only minimalise it with CRTL-M.
                                        SSH does not work (for some reason) VNC works well.
                                        Peter
                                          Peter
                                          After every update of MMM-NOAA the current weather is back in english again.
                                          Translation of the current weather is not in the Dutch translation file.
                                          Any idea how to fix this definitely?
                                          Peter
                                            Mykle1 Project Sponsor Module Developer @Peter
                                            @Peter said in MMM-NOAA - Another Weather Module:
                                            Isn’t the nl.json file Dutch translations? If not, you can help. How does that sound? :-)
                                            • Take any one of the translation files that you find in the tranaslations folder of the MMM-NOAA folder.
                                            • Make a copy of the file and rename the copy
                                            • Edit the copy . Don’t edit the left side which are the English words.
                                            • Edit the right side words so that they are the correct translations in Dutch for English words on the left side.
                                            • Save the file and submit it to the author
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 34
                                            • 35
                                            • 13 / 35
