    690 Posts 77 Posters 3.0m Views 70 Watching
      mac0178
      Nice Module, really love it.
      Unfortunately i have a problem with another module (mmm-traffic) while NOAA is active. The font there should be colored but now it´s background is completely colored. While NOAA is disabled, everything is fine.
      Any clue?
      thx,
      Mac
      • cowboysdudeC Offline
        cowboysdude Module Developer @mac0178
        @mac0178 Let me take a look perhaps a css tag is similar :) Ahhhhhh yes perhaps this is it…
        In the NOAA css file there is this:
        .red{
        	background:#f00;
        .green{
        	background:#0f0;
        .blue{
        	background:#00f;
        and in the MMM-Traffic module there is this:
        .green {
          color: #83FFB3;
        .yellow {
          color: yellow;
        .red {
          color: #FF4C4C;
        So I’m going to update the css file and you can try it again :)
        Just go to the MagicMirror/modules/MMM-NOAA dir and type
        git pull
        that should update the css file :)
          mac0178
          Yeah, that´s it!
          Thank you very much, great support!
          Mykle1M cowboysdudeC 2 Replies Last reply Reply Quote 1
            Mykle1 Project Sponsor Module Developer @mac0178
            @mac0178 said in MMM-NOAA - Another Weather Module:
            Yeah, he’s a guru! :-)
              @mac0178 glad it worked! :)
              • ChrisC Offline
                Chris
                I tried to install this module but I can not make it work.
                instead of the module on the magic mirror screen, it says: “weather info”
                I attach to this post my config file:
                			module: 'MMM-NOAA',
                			position: 'top_right',
                				apiKey: "a3cXXXXX",    // https://www.wunderground.com/weather/api  select the middle plan...
                				useAir: true,             // set to false if you do not want to use Air Quality Index
                				airKey: "Z4pXXXXXXX",    // IF you want Air Quality Index
                				pws: "pws:I93SEVRA3",         // go here to find your pws: https://www.wunderground.com/wundermap
                				lat: "48.919XXX",        // need this for sunrise/sunset  if left blank none will show  -- find them here: http://www.latlong.net/
                				lon: "2.533XXX",       // need this for sunrise/sunset  if left blank none will showshowClock: true,           // Hides or shows clock
                				dformat: false,             // for M/D/YYYY format, false for D/M/YYYY
                				format: "24",              // 12 or 24 hour format.. will default to 12 hour if none selected.
                				ampm: false,                // to show AM and PM on Sunrise/Sunset time
                				showGreet: false,          // deafult is false - to show greeting under clock and above date
                				name: "",                  // Your name
                				showWind: true,
                				showDate: false,
                				showForecast: true,         //show bottom 3 day forecast
                				flash: true,                 //Today in forecast flashes halo
                				showUV: true,               //show UV index
                				showBar: true,             // show Barometer
                				showHum: true,              //show Humidity level
                				position: 'top_right',       //whatever you have in above position must also be here
                				alert: true                //show weather alerts default is true
                By contrast, weather underground works properly so I think it does not come from the API key.
                Does anyone have an idea? Thank you
                  cowboysdude Module Developer @Chris
                  @Chris start the mirror like this
                  npm start dev
                  in that window let me know what if any errors you’re getting :)
                  • ChrisC Offline
                    Chris
                    Thank you for your prompt response,
                    here is what is indicated at startup:
                    > magicmirror@2.2.1 start /home/pi/MagicMirror
                    > sh run-start.sh "dev"
                    Starting MagicMirror: v2.2.1
                    Loading config ...
                    Loading module helpers ...
                    No helper found for module: calendar_monthly.
                    Module helper loaded: MMM-MyCommute
                    Module helper loaded: MMM-SoccerLiveScore
                    Module helper loaded: MMM-soccer
                    No helper found for module: MMM-Globe.
                    Module helper loaded: MMM-Remote-Control
                    Module helper loaded: mmm-suncalc
                    Module helper loaded: MMM-NOAA
                    No helper found for module: mmm-wu-moonphase.
                    Module helper loaded: MMM-Tools
                    No helper found for module: MMM-Snow.
                    All module helpers loaded.
                    Server started ...
                    Connecting socket for: MMM-MyCommute
                    ====================== Starting node_helper for module [MMM-MyCommute]
                    Connecting socket for: MMM-SoccerLiveScore
                    MMM-SoccerLiveScore helper started...
                    Connecting socket for: MMM-soccer
                    Starting module: MMM-soccer
                    Connecting socket for: MMM-Remote-Control
                    Starting node helper for: MMM-Remote-Control
                    Connecting socket for: mmm-suncalc
                    Starting node_helper for mmm-suncalc:
                    Connecting socket for: MMM-NOAA
                    Starting module: MMM-NOAA
                    Connecting socket for: MMM-Tools
                    Starting module: newsfeed
                    Launching application.
                    Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/XXXX/basic.ics - Interval: 300000
                    Get league table for url http://api.football-data.org/v1/competitions/450/leagueTable
                    Create new news fetcher for url: http://www.leparisien.fr/actualites-a-la-une.rss.xml#xtor=RSS-1481423633 - Interval: 300000
                    TypeError: Cannot read property 'observation_location' of undefined
                        at Request.request [as _callback] (/home/pi/MagicMirror/modules/MMM-NOAA/node_helper.js:26:49)
                        at Request.self.callback (/home/pi/MagicMirror/node_modules/request/request.js:186:22)
                        at emitTwo (events.js:106:13)
                        at Request.emit (events.js:191:7)
                        at Request. (/home/pi/MagicMirror/node_modules/request/request.js:1163:10)
                        at emitOne (events.js:96:13)
                        at Request.emit (events.js:188:7)
                        at IncomingMessage. (/home/pi/MagicMirror/node_modules/request/request.js:1085:12)
                        at IncomingMessage.g (events.js:286:16)
                        at emitNone (events.js:91:20)
                    Thanks for your help
                      @Chris said in MMM-NOAA - Another Weather Module:
                      Cannot read property ‘observation_location’ of undefined
                      Not seeing your location…
                      ChrisC 1 Reply Last reply Reply Quote 0
                      • ChrisC Offline
                        Chris @cowboysdude
                        @cowboysdude said in MMM-NOAA - Another Weather Module:
                        I corrected the pws value and it works. I made a mistake in the way of writing it.
                        instead of
                        pws: "I93SEVRA3",
                        Sorry to have bothered you for so little
                        Thank you very much for your help
                          @Chris Hahhahaahha it happens :) Glad you got it working!!! You didn’t bother me!!
                            Peter
                            First: this is a beautiful module, I like it very much!
                            But sometimes it does strange things: today is thursday and normally the module would show today, friday, saturday, etc.
                            But sometimes the module suddenly shows wednesday (yesterday) only.
                            After restarting (or from itself) the module is normal again.
                            Somebody any idea?
                            Peter
                            cruunnerrC 1 Reply Last reply Reply Quote 0
                            • cruunnerrC Offline
                              cruunnerr @Peter
                              @Peter
                              It sounds like your whole MagicMirror instance freezes. But you can only see this at the NOAA module, because once the modules have loaded their informations they will show (without updated informations) their stuff.
                              So the other modules freezes, too but u can’t recognize it because u normally see no refreshing data. But on the NOAA module u expect a change of the shown data.
                              Sorry, my english is bad. Hope u could understand.
                              please check your log files and post the content
                                Peter @cruunnerr
                                @cruunnerr your english is good to understand.
                                I think my MM is freezing indeed (see my other thread “something is wrong”).
                                But I do not understand why NOAA gives yesterdays weather while freezing.
                                If it gave only todays wheather I would understand.
                                I suspect one of the other modules making my MM freeze.
                                But which one …
                                Peter
                                  cruunnerr
                                  if u use pm2, u should check pm2 logs and check the errors. Other way is to start MM with develop mode: npm start dev or with ssh: DISPLAY=:0 npm start dev
                                  Or start it with Firefox on your pc and use Firebug
                                    Peter @cruunnerr
                                    @cruunnerr , I am very sorry and it sounds stupid, but I have no idea how my MM starts.
                                    I had a lot problems to make its start automatically, but now it works.
                                    I cannot stop MM, only minimalise it with CRTL-M.
                                    SSH does not work (for some reason) VNC works well.
                                    Peter
                                      Peter
                                      After every update of MMM-NOAA the current weather is back in english again.
                                      Translation of the current weather is not in the Dutch translation file.
                                      Any idea how to fix this definitely?
                                      Peter
                                        Mykle1 Project Sponsor Module Developer @Peter
                                        @Peter said in MMM-NOAA - Another Weather Module:
                                        Isn’t the nl.json file Dutch translations? If not, you can help. How does that sound? :-)
                                        • Take any one of the translation files that you find in the tranaslations folder of the MMM-NOAA folder.
                                        • Make a copy of the file and rename the copy
                                        • Edit the copy . Don’t edit the left side which are the English words.
                                        • Edit the right side words so that they are the correct translations in Dutch for English words on the left side.
                                        • Save the file and submit it to the author
                                          Peter @Mykle1
                                          @Mykle1 thanks.
                                          I did something like that.
                                          This part is missing in the nl.json:
                                          "OVERCAST": "Overcast",
                                          "CLOUDY": "Cloudy",
                                          "RAIN": "Rain",
                                          "CLEAR": "Clear",
                                          "PARTLY_CLOUDY": "Partly Cloudy",
                                          So, I copied this from the en.json, pasted it in the nl.json and translated the right side, like this:
                                          "OVERCAST": "Grotendeels bewolkt",
                                          "CLOUDY": "Bewolkt",
                                          "RAIN": "Regen",
                                          "CLEAR": "Helder",
                                          "PARTLY_CLOUDY": "Gedeeltelijk bewolkt",
                                          After restarting MM it shows: Overcast …
                                          Strange about this: in the older version of NOAA the same part is missing in nl.json, but the translation is ok.
                                          So I presume the translation is somewhere else …
                                          Peter
                                          tbbearT 1 Reply Last reply Reply Quote 0
                                          • tbbearT Offline
                                            tbbear Module Developer @Peter
                                            @Peter Hello Peter, i found the Problem since a few Versions of NOAA the translation comes directly from wunderground and during the last Change from @cowboysdude he made a small mistake. We will fix this soon.
                                            Robert the Bear
                                            P Mykle1M N 3 Replies Last reply Reply Quote 0
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 34
                                            • 35
                                            • 13 / 35
