    Hello-Lucy
    Scheduled Pinned Locked Moved Fun & Games
    285 Posts 27 Posters 753.4k Views 27 Watching
      pepebc @cowboysdude
      @cowboysdude
      OK, great work !!
      • Mykle1M
        Mykle1 Project Sponsor Module Developer @yawns
        @yawns said in Hello-Lucy:
        System performance is awesome, not comparable to the pi at all.
        Exactly.
        After show modules the screen is crowded.
        SHOW MODULES by default will show ALL modules. So, if you have several pages employed it can get busy real fast. Still, it was intentional to have the ability to hide/show all modules, individual modules and pages of modules.
        @cowboysdude has done an excellent job of implementing Hello-Lucy
        Y M 2 Replies Last reply Reply Quote 1
        • Y
          yawns Moderator @Mykle1
          @Mykle1 said in Hello-Lucy:
          I see, thanks for clarification Mykle!
            maxbachmann @Mykle1
            Exactly.
            Ah thats what I Thought :)
            • cowboysdudeC
              cowboysdude Module Developer @cruunnerr
              @cruunnerr said in Hello-Lucy:
              @cowboysdude
              U need a touch screen, bro ^^
              It’s running like hell ^^Very nice
              It is a touch screen already ;)
              • cowboysdudeC
                cowboysdude Module Developer @yawns
                After show modules the screen is crowded. Is this an error as it is not looking like in the beginning of your video? Or did you hide some modules before starting your video?
                Touch hardware is not yet implemented, is it? Would love to see this in action regarding latency and reliability :)
                NO that’s just what happens because when you blanket show modules it shows all pages at once. That’s not a bug it’s just how it works :)
                • NathanWilcoxN
                  NathanWilcox
                  @Mykle1
                  Great module have been using for some time while developing the mirror.
                  I apologise if you have covered this else where but I simply cannot find it, Is there a way to automatically show modules on MagicMirror start as appose to them being hidden and only shown when prompted.
                  • Mykle1M
                    Mykle1 Project Sponsor Module Developer @NathanWilcox
                    @NathanWilcox said in Hello-Lucy:
                    If you’re not gun shy about modifying the files yourself, you can find this in the MMM-voice.js file and comment it out. You’ll find it at about line 277. I assume you know that every module you have loading will be displayed. :-)
                         if (notification === 'DOM_OBJECTS_CREATED') {
                             MM.getModules().enumerate((module) => {
                                    module.hide(1000);
                    • NathanWilcoxN
                      NathanWilcox
                      @Mykle1
                      That’s exactly what I was looking for. Yes I did realise it would show all.
                      I’m trying to demonstrate to the other half the different ways we can have the mirror and she wasn’t too enthusiastic with booting a “blank screen”
                      • Mykle1M
                        @NathanWilcox
                        Sound of whip snapping
                          maxbachmann
                          Will give Snips a try when I get my microphone array. Seems like the just released ther German automated speech recognition a few days ago
                          Seems pretty easy in general (I guess the hardest thing will be talking to the modules since snips uses python and here it’s java script while I am usually only using c++ lmao)
                          Edit: Just realised there is already a mqtt module for MagicMirror2 that should make it quite a bit easier
                            djsunrise19
                            @mykle1: Very nice module! Works really good, and it’s easy to add more and more modules. unfortunately, with one of them, I have a problem: https://github.com/eouia/MMM-CalendarExt.
                            I found the wrapper part, but it doesn’t work. The other modules are still working. Do you have an idea?
                              getDom: function() {
                                if (this.isInit) {
                                  R = new Render ()
                                  R.drawViews(
                                    this.CurrentConfigs,
                                    this.getEventsToDraw()
                                var wrapper = null
                                wrapper = document.createElement("div")
                                wrapper.id = 'CALEXT_proxy'
                                wrapper.className = 'proxy'
                                return wrapper
                                notificationReceived: function(notification, payload) {
                                    if (notification === 'HIDE_WORK') {
                                        this.hide(1000);
                                    }  else if (notification === 'SHOW_WORK') {
                                        this.show(1000);
                            Thank you!
                            • Mykle1M
                              Mykle1 Project Sponsor Module Developer @djsunrise19
                              @djsunrise19
                              That looks right.
                              Have you made the other changes that you need to make, according to the readme? That is not the only modification you need to perform.
                              If you issue the “SHOW MODULES” command, does it show then?
                              Is there another " notificationReceived: function" within the MMM-CalendarExt.js file?
                                djsunrise19 @Mykle1
                                @djsunrise19
                                That looks right.
                                Yes, all other Lucy / Voice modules are still working. I made all changes (accordingly your read me). Within the MMM-CalendarExt.js file are more than one “notificationReceived: function” functions:
                                    var sessionId = moment().valueOf()
                                    if (typeof payload !== 'undefined' && payload !== null) {
                                      if (typeof payload.sessionId !== 'undefined') {
                                        sessionId = payload.sessionId
                                    switch (notification) {
                                      case 'DOM_OBJECTS_CREATED':
                                        if(typeof sender == 'undefined') {
                                          this.loadCSS()
                                          this.initAfterLoading()
                                        break
                                      case 'CHANGED_PROFILE':
                                        this.showing = 0
                                        this.isInit = 0
                                        this.initAfterLoading(payload.to)
                                        this.sendNotification('CALEXT_SAYS_PROFILE_CHANGED', payload)
                                        break
                                      case 'CALEXT_ADD_EVENT':
                                        if(typeof payload.event !== 'undefined') {
                                          this.addInstantEvent(payload.event, sender.name, sessionId)
                                        break
                                      case 'CALEXT_REMOVE_EVENT':
                                        if(typeof payload.uid !== 'undefined') {
                                          this.removeInstantEvent(payload.uid, sender.name, sessionId)
                                        break
                                      case 'CALEXT_TELL_SCHEDULE':
                                        if(typeof payload.filter !== 'undefined') {
                                          this.saySchedule(payload.filter, sender.name, sessionId)
                                        break
                                      case 'CALEXT_MODIFY_CONFIG':
                                        this.modifyConfiguration(payload.config, sender.name, sessionId)
                                      case 'CALENDAR_MODIFIED':
                                        this.sendNotification("CALEXT_SAYS_CALENDAR_MODIFIED")
                                        this.events = payload
                                        this.makeIndex()
                                        this.draw()
                                        break
                                      case 'READY_TO_ADD_CALENDAR':
                                        this.addCalendars()
                                        break;
                                Should I put your function after one of these?
                                • Mykle1M
                                  @djsunrise19
                                  I haven’t tested this because I don’t use CalendarExt. Couldn’t get it to work for me :-/
                                  However, please remove the entry you made after the return wrapper and make the entry as I have shown below
                                              this.hide(1000);
                                              this.show(1000);
                                    djsunrise19 @Mykle1
                                    @Mykle1 That’s it! Thank you! Again :)!
                                    • Mykle1M
                                      @djsunrise19 said in Hello-Lucy:
                                      You’re welcome, my friend. I’m glad that you find Lucy useful. I don’t think I could live without it now. :-)
                                      • cowboysdudeC
                                        https://www.youtube.com/watch?v=Ez8axz9bwUg&feature=youtu.be
                                        Thanks Lucy for the to-do list :)
                                        • Mykle1M
                                          @cowboysdude
                                          No, thank you my friend. I am honored that you use something of mine when you are capable of such greatness.
                                          • Mykle1M
                                            Added 4 new modules to the Hello-Lucy defaults.
                                            • https://github.com/mykle1/MMM-URHere
                                            • https://github.com/mykle1/MMM-Sudoku
                                            • https://github.com/mykle1/MMM-EventHorizon
                                            • https://github.com/mykle1/MMM-ISS
                                            • 14
                                            • 15
                                            • 4 / 15
