    Hello-Lucy
    Scheduled Pinned Locked Moved Fun & Games
    285 Posts 27 Posters 763.0k Views 27 Watching
      maxbachmann @Mykle1
      @Mykle1 said in Hello-Lucy:
      @yawns said in Hello-Lucy:
      System performance is awesome, not comparable to the pi at all.
      Exactly.
      After show modules the screen is crowded.
      SHOW MODULES by default will show ALL modules. So, if you have several pages employed it can get busy real fast. Still, it was intentional to have the ability to hide/show all modules, individual modules and pages of modules.
      Ah thats what I Thought :)
      • cowboysdudeC
        cowboysdude Module Developer @cruunnerr
        @cruunnerr said in Hello-Lucy:
        @cowboysdude
        U need a touch screen, bro ^^
        It’s running like hell ^^Very nice
        It is a touch screen already ;)
        • cowboysdudeC
          cowboysdude Module Developer @yawns
          After show modules the screen is crowded. Is this an error as it is not looking like in the beginning of your video? Or did you hide some modules before starting your video?
          Touch hardware is not yet implemented, is it? Would love to see this in action regarding latency and reliability :)
          NO that’s just what happens because when you blanket show modules it shows all pages at once. That’s not a bug it’s just how it works :)
          • NathanWilcoxN
            NathanWilcox
            @Mykle1
            Great module have been using for some time while developing the mirror.
            I apologise if you have covered this else where but I simply cannot find it, Is there a way to automatically show modules on MagicMirror start as appose to them being hidden and only shown when prompted.
            Mykle1M 1 Reply Last reply
            • Mykle1M
              Mykle1 Project Sponsor Module Developer @NathanWilcox
              @NathanWilcox said in Hello-Lucy:
              If you’re not gun shy about modifying the files yourself, you can find this in the MMM-voice.js file and comment it out. You’ll find it at about line 277. I assume you know that every module you have loading will be displayed. :-)
                   if (notification === 'DOM_OBJECTS_CREATED') {
                       MM.getModules().enumerate((module) => {
                              module.hide(1000);
              Reply Quote 2
              • NathanWilcoxN
                NathanWilcox
                @Mykle1
                That’s exactly what I was looking for. Yes I did realise it would show all.
                I’m trying to demonstrate to the other half the different ways we can have the mirror and she wasn’t too enthusiastic with booting a “blank screen”
                • Mykle1M
                  @NathanWilcox
                  Sound of whip snapping
                    maxbachmann
                    Will give Snips a try when I get my microphone array. Seems like the just released ther German automated speech recognition a few days ago
                    Seems pretty easy in general (I guess the hardest thing will be talking to the modules since snips uses python and here it’s java script while I am usually only using c++ lmao)
                    Edit: Just realised there is already a mqtt module for MagicMirror2 that should make it quite a bit easier
                      djsunrise19
                      @mykle1: Very nice module! Works really good, and it’s easy to add more and more modules. unfortunately, with one of them, I have a problem: https://github.com/eouia/MMM-CalendarExt.
                      I found the wrapper part, but it doesn’t work. The other modules are still working. Do you have an idea?
                        getDom: function() {
                          if (this.isInit) {
                            R = new Render ()
                            R.drawViews(
                              this.CurrentConfigs,
                              this.getEventsToDraw()
                          var wrapper = null
                          wrapper = document.createElement("div")
                          wrapper.id = 'CALEXT_proxy'
                          wrapper.className = 'proxy'
                          return wrapper
                          notificationReceived: function(notification, payload) {
                              if (notification === 'HIDE_WORK') {
                                  this.hide(1000);
                              }  else if (notification === 'SHOW_WORK') {
                                  this.show(1000);
                      Thank you!
                      • Mykle1M
                        Mykle1 Project Sponsor Module Developer @djsunrise19
                        @djsunrise19
                        That looks right.
                        Have you made the other changes that you need to make, according to the readme? That is not the only modification you need to perform.
                        If you issue the “SHOW MODULES” command, does it show then?
                        Is there another " notificationReceived: function" within the MMM-CalendarExt.js file?
                        D 1 Reply Last reply
                          djsunrise19 @Mykle1
                          @djsunrise19
                          That looks right.
                          Yes, all other Lucy / Voice modules are still working. I made all changes (accordingly your read me). Within the MMM-CalendarExt.js file are more than one “notificationReceived: function” functions:
                              var sessionId = moment().valueOf()
                              if (typeof payload !== 'undefined' && payload !== null) {
                                if (typeof payload.sessionId !== 'undefined') {
                                  sessionId = payload.sessionId
                              switch (notification) {
                                case 'DOM_OBJECTS_CREATED':
                                  if(typeof sender == 'undefined') {
                                    this.loadCSS()
                                    this.initAfterLoading()
                                  break
                                case 'CHANGED_PROFILE':
                                  this.showing = 0
                                  this.isInit = 0
                                  this.initAfterLoading(payload.to)
                                  this.sendNotification('CALEXT_SAYS_PROFILE_CHANGED', payload)
                                  break
                                case 'CALEXT_ADD_EVENT':
                                  if(typeof payload.event !== 'undefined') {
                                    this.addInstantEvent(payload.event, sender.name, sessionId)
                                  break
                                case 'CALEXT_REMOVE_EVENT':
                                  if(typeof payload.uid !== 'undefined') {
                                    this.removeInstantEvent(payload.uid, sender.name, sessionId)
                                  break
                                case 'CALEXT_TELL_SCHEDULE':
                                  if(typeof payload.filter !== 'undefined') {
                                    this.saySchedule(payload.filter, sender.name, sessionId)
                                  break
                                case 'CALEXT_MODIFY_CONFIG':
                                  this.modifyConfiguration(payload.config, sender.name, sessionId)
                                case 'CALENDAR_MODIFIED':
                                  this.sendNotification("CALEXT_SAYS_CALENDAR_MODIFIED")
                                  this.events = payload
                                  this.makeIndex()
                                  this.draw()
                                  break
                                case 'READY_TO_ADD_CALENDAR':
                                  this.addCalendars()
                                  break;
                          Should I put your function after one of these?
                          • Mykle1M
                            @djsunrise19
                            I haven’t tested this because I don’t use CalendarExt. Couldn’t get it to work for me :-/
                            However, please remove the entry you made after the return wrapper and make the entry as I have shown below
                                        this.hide(1000);
                                        this.show(1000);
                              djsunrise19 @Mykle1
                              @Mykle1 That’s it! Thank you! Again :)!
                              • Mykle1M
                                @djsunrise19 said in Hello-Lucy:
                                You’re welcome, my friend. I’m glad that you find Lucy useful. I don’t think I could live without it now. :-)
                                • cowboysdudeC
                                  https://www.youtube.com/watch?v=Ez8axz9bwUg&feature=youtu.be
                                  Thanks Lucy for the to-do list :)
                                  Reply Quote 2
                                  • Mykle1M
                                    @cowboysdude
                                    No, thank you my friend. I am honored that you use something of mine when you are capable of such greatness.
                                    Reply Quote 2
                                    • Mykle1M
                                      Added 4 new modules to the Hello-Lucy defaults.
                                      • https://github.com/mykle1/MMM-URHere
                                      • https://github.com/mykle1/MMM-Sudoku
                                      • https://github.com/mykle1/MMM-EventHorizon
                                      • https://github.com/mykle1/MMM-ISS
                                      Reply Quote 2
                                      • Mykle1M
                                        So, all the credit for this goes to @cowboysdude. I immediately added it to my “must have” list. Yesterday, I had the movie “Predator” playing fullscreen as my live desktop on my MM. The possibilities are endless. Just amazing. Modules look amazing on top of it. This is like “Shock and awe” for MM. Kudos bro!
                                        https://youtu.be/M3QvF-ctZEA
                                        E D 2 Replies Last reply
                                        Reply Quote 2
                                        • E
                                          E3V3A @Mykle1
                                          @Mykle1 Whats that rotating planet? (Is it earth? – No, the module?)
                                          “Everything I do (here) is for free – altruism is the way!”
                                          • E
                                            E3V3A
                                            It’s this one: https://github.com/mykle1/MMM-EARTH
                                            Very nice!
                                            But the one on the video seemspinning much faster. @Mykle1 what are your config setting for that?
                                            • 14
                                            • 15
                                            • 4 / 15
