    Hello-Lucy
    Scheduled Pinned Locked Moved Fun & Games
    285 Posts 27 Posters 753.3k Views 27 Watching
    • NathanWilcoxN
      NathanWilcox
      @Mykle1
      Great module have been using for some time while developing the mirror.
      I apologise if you have covered this else where but I simply cannot find it, Is there a way to automatically show modules on MagicMirror start as appose to them being hidden and only shown when prompted.
      • Mykle1M
        Mykle1 Project Sponsor Module Developer @NathanWilcox
        @NathanWilcox said in Hello-Lucy:
        If you’re not gun shy about modifying the files yourself, you can find this in the MMM-voice.js file and comment it out. You’ll find it at about line 277. I assume you know that every module you have loading will be displayed. :-)
             if (notification === 'DOM_OBJECTS_CREATED') {
                 MM.getModules().enumerate((module) => {
                        module.hide(1000);
        • NathanWilcoxN
          NathanWilcox
          @Mykle1
          That’s exactly what I was looking for. Yes I did realise it would show all.
          I’m trying to demonstrate to the other half the different ways we can have the mirror and she wasn’t too enthusiastic with booting a “blank screen”
          • Mykle1M
            @NathanWilcox
            Sound of whip snapping
              maxbachmann
              Will give Snips a try when I get my microphone array. Seems like the just released ther German automated speech recognition a few days ago
              Seems pretty easy in general (I guess the hardest thing will be talking to the modules since snips uses python and here it’s java script while I am usually only using c++ lmao)
              Edit: Just realised there is already a mqtt module for MagicMirror2 that should make it quite a bit easier
                djsunrise19
                @mykle1: Very nice module! Works really good, and it’s easy to add more and more modules. unfortunately, with one of them, I have a problem: https://github.com/eouia/MMM-CalendarExt.
                I found the wrapper part, but it doesn’t work. The other modules are still working. Do you have an idea?
                  getDom: function() {
                    if (this.isInit) {
                      R = new Render ()
                      R.drawViews(
                        this.CurrentConfigs,
                        this.getEventsToDraw()
                    var wrapper = null
                    wrapper = document.createElement("div")
                    wrapper.id = 'CALEXT_proxy'
                    wrapper.className = 'proxy'
                    return wrapper
                    notificationReceived: function(notification, payload) {
                        if (notification === 'HIDE_WORK') {
                            this.hide(1000);
                        }  else if (notification === 'SHOW_WORK') {
                            this.show(1000);
                Thank you!
                • Mykle1M
                  Mykle1 Project Sponsor Module Developer @djsunrise19
                  @djsunrise19
                  That looks right.
                  Have you made the other changes that you need to make, according to the readme? That is not the only modification you need to perform.
                  If you issue the “SHOW MODULES” command, does it show then?
                  Is there another " notificationReceived: function" within the MMM-CalendarExt.js file?
                    djsunrise19 @Mykle1
                    @Mykle1 said in Hello-Lucy:
                    @djsunrise19
                    That looks right.
                    Yes, all other Lucy / Voice modules are still working. I made all changes (accordingly your read me). Within the MMM-CalendarExt.js file are more than one “notificationReceived: function” functions:
                        var sessionId = moment().valueOf()
                        if (typeof payload !== 'undefined' && payload !== null) {
                          if (typeof payload.sessionId !== 'undefined') {
                            sessionId = payload.sessionId
                        switch (notification) {
                          case 'DOM_OBJECTS_CREATED':
                            if(typeof sender == 'undefined') {
                              this.loadCSS()
                              this.initAfterLoading()
                            break
                          case 'CHANGED_PROFILE':
                            this.showing = 0
                            this.isInit = 0
                            this.initAfterLoading(payload.to)
                            this.sendNotification('CALEXT_SAYS_PROFILE_CHANGED', payload)
                            break
                          case 'CALEXT_ADD_EVENT':
                            if(typeof payload.event !== 'undefined') {
                              this.addInstantEvent(payload.event, sender.name, sessionId)
                            break
                          case 'CALEXT_REMOVE_EVENT':
                            if(typeof payload.uid !== 'undefined') {
                              this.removeInstantEvent(payload.uid, sender.name, sessionId)
                            break
                          case 'CALEXT_TELL_SCHEDULE':
                            if(typeof payload.filter !== 'undefined') {
                              this.saySchedule(payload.filter, sender.name, sessionId)
                            break
                          case 'CALEXT_MODIFY_CONFIG':
                            this.modifyConfiguration(payload.config, sender.name, sessionId)
                          case 'CALENDAR_MODIFIED':
                            this.sendNotification("CALEXT_SAYS_CALENDAR_MODIFIED")
                            this.events = payload
                            this.makeIndex()
                            this.draw()
                            break
                          case 'READY_TO_ADD_CALENDAR':
                            this.addCalendars()
                            break;
                    Should I put your function after one of these?
                    • Mykle1M
                      @djsunrise19
                      I haven’t tested this because I don’t use CalendarExt. Couldn’t get it to work for me :-/
                      However, please remove the entry you made after the return wrapper and make the entry as I have shown below
                                  this.hide(1000);
                                  this.show(1000);
                        djsunrise19 @Mykle1
                        @Mykle1 That’s it! Thank you! Again :)!
                        • Mykle1M
                          @djsunrise19 said in Hello-Lucy:
                          You’re welcome, my friend. I’m glad that you find Lucy useful. I don’t think I could live without it now. :-)
                          • cowboysdudeC
                            https://www.youtube.com/watch?v=Ez8axz9bwUg&feature=youtu.be
                            Thanks Lucy for the to-do list :)
                            • Mykle1M
                              @cowboysdude
                              No, thank you my friend. I am honored that you use something of mine when you are capable of such greatness.
                              • Mykle1M
                                Added 4 new modules to the Hello-Lucy defaults.
                                • https://github.com/mykle1/MMM-URHere
                                • https://github.com/mykle1/MMM-Sudoku
                                • https://github.com/mykle1/MMM-EventHorizon
                                • https://github.com/mykle1/MMM-ISS
                                • Mykle1M
                                  So, all the credit for this goes to @cowboysdude. I immediately added it to my “must have” list. Yesterday, I had the movie “Predator” playing fullscreen as my live desktop on my MM. The possibilities are endless. Just amazing. Modules look amazing on top of it. This is like “Shock and awe” for MM. Kudos bro!
                                  https://youtu.be/M3QvF-ctZEA
                                  E D 2 Replies Last reply Reply Quote 2
                                  • E
                                    E3V3A @Mykle1
                                    @Mykle1 Whats that rotating planet? (Is it earth? – No, the module?)
                                    “Everything I do (here) is for free – altruism is the way!”
                                    • E
                                      E3V3A
                                      It’s this one: https://github.com/mykle1/MMM-EARTH
                                      Very nice!
                                      But the one on the video seemspinning much faster. @Mykle1 what are your config setting for that?
                                        Damian @Mykle1
                                        @cowboysdude
                                        Please tell me this live desktop will be published? Appreciate it will only suit those of us who use a PC MM, but I would agree this is “Shock and awe” and above all, full praise to both of you who have emerged yourselves fully into the MM to produce so much, in such a short space of time. You two, are truly Brothers in Arms :-) Well done to both.
                                        • Mykle1M
                                          Mykle1 Project Sponsor Module Developer @E3V3A
                                          @E3V3A said in Hello-Lucy:
                                          Very nice!
                                          No, that’s not MMM-EARTH. See my next answer
                                          • Mykle1M
                                            Mykle1 Project Sponsor Module Developer @Damian
                                            @Damian said in Hello-Lucy:
                                            You would have to ask @cowboysdude about that. It’s not mine to give. He made the magic happen. If there is an underrated module developer here, it’s him.
                                            D 1 Reply Last reply Reply Quote 2
                                            • 14
                                            • 15
                                            • 4 / 15
