    MMM-voice
    voice control
    329 Posts 55 Posters 1.1m Views 50 Watching
      dogfeet
      hi guys, i’m a little over my head here, really not familiar with coding very much but i’ve got voice working and been able to tweak a few things.
      what i want to do is probably very easy but i just can’t get it to work. i want to have mmm-voice control the default compliments module such that compliments begins hidden by default and i can say “how do i look” and the mirror will show the compliments module for 10 seconds then hide it again.
      i could change the compliments to have appropriate responses and then when the user says “how do i look” the mirror will appear to answer them.
      i was thinking of setting “HOW DO” as the mode command to control the compliments module and then “I LOOK” could be the command within that mode to show a compliment for 10 seconds.
      what do you think? is this a simple task?
      • strawberry 3.141S Offline
        strawberry 3.141 Project Sponsor Module Developer @dogfeet
        @dogfeet cannot tell if it is an easy task for you, it depends on your knowledge about JS and MagicMirror
        I assume you read the documentation here
        1. in your compliments module you need to register your commands
        2. then you need to check for your command
        notificationReceived: function (notification, payload, sender) {
            // 1. register module
            if(notification === "ALL_MODULES_STARTED"){
                this.sendNotification("REGISTER_VOICE_MODULE", {
                    mode: "HOW DO",
                    sentences: [
                        "I LOOK"
            // 2. react on command
            if(notification === "VOICE_HOW DO" && sender.name === "MMM-voice"){
                if(/(LOOK)/g.test(payload)){
                    // unhide the module,
                    // set a 10 sec timeout
                    // hide your module
        That’s all you need to connect your module to MMM-voice. Now you have to implement the comments
          cyberphox
          @strawberry-3.141 said in MMM-voice:
          https:
          Tried installing this today on a Dell Latitude E5500 running Ubuntu.
          Seemed to install ok. Said my microphone was labelled 0
          so entered that in config.js
          Not getting any errors on running, but not getting a microphone icon anywhere on screen?
          strawberry 3.141S Mykle1M 2 Replies Last reply Reply Quote 0
            strawberry 3.141 Project Sponsor Module Developer @cyberphox
            @cyberphox never put it on an ubuntu machine @cowboysdude and @Mykle1 did, maybe they can assist you here.
            If the error log is empty, you can also set debug: true in the config and check the debug log file
              Mykle1 Project Sponsor Module Developer @cyberphox
              @cyberphox said in MMM-voice:
              Message me and I’ll try to help you out
                cyberphox @Mykle1
                @Mykle1 thanks man! helpful as always…it was Hello Lucy that inspired me to build another project with a little more power than my RP3…
                  @cyberphox
                  No problem. See your chat messages so we don’t take up any room in this topic
                  • justjim1220J Offline
                    justjim1220 Module Developer
                    @Mykle1, got any suggestions or pointers on how to get Alexa (or any voice assisted module) to work on Windows 10???
                    Jim Hallock - 1995
                      Mykle1 Project Sponsor Module Developer @justjim1220
                      @justjim1220 said in MMM-voice:
                      A while back, I halfheartedly tried to get MMM-voice to run under Windows 7. The problem is the dependencies that are required, finding them for your platform (Windows 7). It may be possible but it just wasn’t worth the effort to me when success was not guaranteed.
                      On the other hand, MM runs beautifully under ubuntu. In fact, I wouldn’t use (or recommend) anything else.
                        cyberphox
                        thanks @mykle1 for the assist to get it to show up!!
                          @cyberphox
                          You’re welcome.
                            dogfeet @strawberry 3.141
                            @strawberry-3.141 thanks so much for replying. i’ve been tackling it for a while, and yes i had read that documentation file several times but i’m such a noob that i didn’t even know what file to put that code into. you’re correct that what’s easy for some is difficult for me.
                            in any case, i’ve got your code implemented and after some trial and error, it’s somewhat functional. i’m able to successfully go back and forth between 2 modes that i’ve set, one of which is the “how do” mode. now, when i say “i look” it’s recognized by the mirror but it doesn’t seem to be executing any code. i’m taking this in baby steps as i learn how to make changes so i’m trying just to simply hide the compliments module. i have the following code which i think should hide the module but it doesn’t hide.
                                        mode: "HOW DO",
                                        sentences: [
                                            "I LOOK"
                                        this.hide(1000);
                                        this.updateDom(300);
                                        // hide your module
                            i’m sorry for needing this spoon-fed to me, i have been trying, but i’m stuck on this.
                              @dogfeet try to set some logs, to see if you get the desired data or not,
                                  console.log(notification, payload)
                              then see if you get notification === "VOICE_HOW DO" and the payload contains look
                                @strawberry-3.141 thanks. i put the log command in like so…
                                    console.log(notification, payload);
                                            mode: "HOW DO",
                                            sentences: [
                                                "I LOOK"
                                            this.hide(1000);
                                            // hide your module
                                so i ran this with npm start dev and found this at the bottom of the console tab…
                                it looks like it’s recognizing the command belongs to the compliments module, but the text isn’t exactly as you described. is this correct?
                                • 4lice4 Offline
                                  4lice @Mykle1
                                  @Mykle1 youre awesome :*
                                    @dogfeet i don’t know why it is FALL instead of VOICE in your case?
                                    this is the code https://github.com/fewieden/MMM-voice/blob/master/MMM-voice.js#L203-L217
                                    the important parts are if (notification === 'VOICE') and this.sendNotification(${notification}_${payload.mode}, payload.sentence);
                                    how can notification be voice and a few lines later it is fall? did you modify any files?
                                      @strawberry-3.141 yes i did modify mmm-voice.js to suit my needs. to explain, i have a total of 5 commands. “fall” is the first mode and is native to the voice module, under which i have 2 commands, “asleep” and “wake up”. so i say “hey mirror” (my listen command), then “fall asleep” and it cuts out the monitor, then since it’s already in “fall” mode i just say “wake up” and it turns the display back on. the final commands are for the compliments module and they are “how do” (the mode) and “i look” which is where i’m having problems. fall asleep and wake up are working perfectly.
                                      so yes, i modified the lines that you highlighted such that the 2 places where it used to say ‘VOICE’ it now says ‘FALL’.
                                      should i not have done that? it seems to work. i had to make other minor changes of course to keep it working.
                                        @dogfeet if you changed that, then you also have to apply your renamin here
                                        if(notification === "FALL_HOW DO" && sender.name === "MMM-voice"){
                                                    this.hide(1000);
                                                    // hide your module
                                          @strawberry-3.141 i feel so stupid :facepalm:
                                            dmwilsonkc
                                            So I must say the MMM-voice module (also with Mykle’s Hello-Lucy enhancements) works perfectly on my mirror… when I don’t have my Mycroft AI running at start as well. It’s an Error: resource busy/unavailable referring to the Microphone. When I stop Mycroft/restart mirror it works perfectly, but then Mycroft gets the same error. Any suggestions?
                                            I am thinking about building a MagicMirror skill for Mycroft, but Mycroft is Python not Java, and not a module. Would it be possible to send the same commands as Hello-Lucy (i.e. ‘HIDE_CLOCK’ for example) only use Websocket-client for Mycroft and send commands to the MagicMirror via socket.io?
                                            If so, what would handle the socketmessage? Would it be communicated to the right module/s. Would I also need to create a fork of the MMM-voice module with code to handle the socketmessages from Mycroft?
                                            Any guidance would be much appreciated!
                                            Sorry, I should have also said my mirror is running on a RPi 3b running Debian Jessie on a 16gb sd.
                                            strawberry 3.141S 1 Reply Last reply Reply Quote 1
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 15 / 17
