    MMM-voice
    voice control
    329 Posts 55 Posters 952.7k Views 50 Watching
      Mykle1 Project Sponsor Module Developer @justjim1220
      @justjim1220 said in MMM-voice:
      @Mykle1, got any suggestions or pointers on how to get Alexa (or any voice assisted module) to work on Windows 10???
      A while back, I halfheartedly tried to get MMM-voice to run under Windows 7. The problem is the dependencies that are required, finding them for your platform (Windows 7). It may be possible but it just wasn’t worth the effort to me when success was not guaranteed.
      On the other hand, MM runs beautifully under ubuntu. In fact, I wouldn’t use (or recommend) anything else.
        cyberphox
        thanks @mykle1 for the assist to get it to show up!!
          Mykle1 Project Sponsor Module Developer @cyberphox
          @cyberphox
          You’re welcome.
            dogfeet @strawberry 3.141
            @strawberry-3.141 thanks so much for replying. i’ve been tackling it for a while, and yes i had read that documentation file several times but i’m such a noob that i didn’t even know what file to put that code into. you’re correct that what’s easy for some is difficult for me.
            in any case, i’ve got your code implemented and after some trial and error, it’s somewhat functional. i’m able to successfully go back and forth between 2 modes that i’ve set, one of which is the “how do” mode. now, when i say “i look” it’s recognized by the mirror but it doesn’t seem to be executing any code. i’m taking this in baby steps as i learn how to make changes so i’m trying just to simply hide the compliments module. i have the following code which i think should hide the module but it doesn’t hide.
            notificationReceived: function (notification, payload, sender) {
                // 1. register module
                if(notification === "ALL_MODULES_STARTED"){
                    this.sendNotification("REGISTER_VOICE_MODULE", {
                        mode: "HOW DO",
                        sentences: [
                            "I LOOK"
                // 2. react on command
                if(notification === "VOICE_HOW DO" && sender.name === "MMM-voice"){
                    if(/(LOOK)/g.test(payload)){
                        this.hide(1000);
                        this.updateDom(300);
                        // unhide the module,
                        // set a 10 sec timeout
                        // hide your module
            i’m sorry for needing this spoon-fed to me, i have been trying, but i’m stuck on this.
            • strawberry 3.141S Offline
              strawberry 3.141 Project Sponsor Module Developer @dogfeet
              @dogfeet try to set some logs, to see if you get the desired data or not,
                  console.log(notification, payload)
              then see if you get notification === "VOICE_HOW DO" and the payload contains look
                @strawberry-3.141 thanks. i put the log command in like so…
                    console.log(notification, payload);
                            mode: "HOW DO",
                            sentences: [
                                "I LOOK"
                            this.hide(1000);
                            // hide your module
                so i ran this with npm start dev and found this at the bottom of the console tab…
                it looks like it’s recognizing the command belongs to the compliments module, but the text isn’t exactly as you described. is this correct?
                • 4lice4 Offline
                  4lice @Mykle1
                  @Mykle1 youre awesome :*
                    @dogfeet i don’t know why it is FALL instead of VOICE in your case?
                    this is the code https://github.com/fewieden/MMM-voice/blob/master/MMM-voice.js#L203-L217
                    the important parts are if (notification === 'VOICE') and this.sendNotification(${notification}_${payload.mode}, payload.sentence);
                    how can notification be voice and a few lines later it is fall? did you modify any files?
                      @strawberry-3.141 yes i did modify mmm-voice.js to suit my needs. to explain, i have a total of 5 commands. “fall” is the first mode and is native to the voice module, under which i have 2 commands, “asleep” and “wake up”. so i say “hey mirror” (my listen command), then “fall asleep” and it cuts out the monitor, then since it’s already in “fall” mode i just say “wake up” and it turns the display back on. the final commands are for the compliments module and they are “how do” (the mode) and “i look” which is where i’m having problems. fall asleep and wake up are working perfectly.
                      so yes, i modified the lines that you highlighted such that the 2 places where it used to say ‘VOICE’ it now says ‘FALL’.
                      should i not have done that? it seems to work. i had to make other minor changes of course to keep it working.
                        @dogfeet if you changed that, then you also have to apply your renamin here
                        if(notification === "FALL_HOW DO" && sender.name === "MMM-voice"){
                                    this.hide(1000);
                                    // hide your module
                        • 27
                        • 28
                        • 29
                        • 30
                        • 31
                        • 32
                        • 33
                        • 29 / 33
