    MMM-voice
    voice control
    329 Posts 55 Posters 1.1m Views 50 Watching
    • Mykle1M
      Mykle1 Project Sponsor Module Developer @cyberphox
      @cyberphox said in MMM-voice:
      Tried installing this today on a Dell Latitude E5500 running Ubuntu.
      Message me and I’ll try to help you out
      C 1 Reply Last reply
        cyberphox @Mykle1
        @Mykle1 thanks man! helpful as always…it was Hello Lucy that inspired me to build another project with a little more power than my RP3…
        Mykle1M 1 Reply Last reply
        • Mykle1M
          @cyberphox
          No problem. See your chat messages so we don’t take up any room in this topic
          • justjim1220J
            justjim1220 Module Developer
            @Mykle1, got any suggestions or pointers on how to get Alexa (or any voice assisted module) to work on Windows 10???
            Jim Hallock - 1995
            • Mykle1M
              Mykle1 Project Sponsor Module Developer @justjim1220
              @justjim1220 said in MMM-voice:
              A while back, I halfheartedly tried to get MMM-voice to run under Windows 7. The problem is the dependencies that are required, finding them for your platform (Windows 7). It may be possible but it just wasn’t worth the effort to me when success was not guaranteed.
              On the other hand, MM runs beautifully under ubuntu. In fact, I wouldn’t use (or recommend) anything else.
                cyberphox
                thanks @mykle1 for the assist to get it to show up!!
                • Mykle1M
                  @cyberphox
                  You’re welcome.
                  Reply Quote 2
                    dogfeet @strawberry 3.141
                    @strawberry-3.141 thanks so much for replying. i’ve been tackling it for a while, and yes i had read that documentation file several times but i’m such a noob that i didn’t even know what file to put that code into. you’re correct that what’s easy for some is difficult for me.
                    in any case, i’ve got your code implemented and after some trial and error, it’s somewhat functional. i’m able to successfully go back and forth between 2 modes that i’ve set, one of which is the “how do” mode. now, when i say “i look” it’s recognized by the mirror but it doesn’t seem to be executing any code. i’m taking this in baby steps as i learn how to make changes so i’m trying just to simply hide the compliments module. i have the following code which i think should hide the module but it doesn’t hide.
                    notificationReceived: function (notification, payload, sender) {
                        // 1. register module
                        if(notification === "ALL_MODULES_STARTED"){
                            this.sendNotification("REGISTER_VOICE_MODULE", {
                                mode: "HOW DO",
                                sentences: [
                                    "I LOOK"
                        // 2. react on command
                        if(notification === "VOICE_HOW DO" && sender.name === "MMM-voice"){
                            if(/(LOOK)/g.test(payload)){
                                this.hide(1000);
                                this.updateDom(300);
                                // unhide the module,
                                // set a 10 sec timeout
                                // hide your module
                    i’m sorry for needing this spoon-fed to me, i have been trying, but i’m stuck on this.
                    • strawberry 3.141S
                      strawberry 3.141 Project Sponsor Module Developer @dogfeet
                      @dogfeet try to set some logs, to see if you get the desired data or not,
                          console.log(notification, payload)
                      then see if you get notification === "VOICE_HOW DO" and the payload contains look
                      D 1 Reply Last reply
                        @strawberry-3.141 thanks. i put the log command in like so…
                            console.log(notification, payload);
                                    mode: "HOW DO",
                                    sentences: [
                                        "I LOOK"
                                    this.hide(1000);
                                    // hide your module
                        so i ran this with npm start dev and found this at the bottom of the console tab…
                        it looks like it’s recognizing the command belongs to the compliments module, but the text isn’t exactly as you described. is this correct?
                        • 4lice4
                          4lice @Mykle1
                          @Mykle1 youre awesome :*
                          • strawberry 3.141S
                            @dogfeet i don’t know why it is FALL instead of VOICE in your case?
                            this is the code https://github.com/fewieden/MMM-voice/blob/master/MMM-voice.js#L203-L217
                            the important parts are if (notification === 'VOICE') and this.sendNotification(${notification}_${payload.mode}, payload.sentence);
                            how can notification be voice and a few lines later it is fall? did you modify any files?
                              @strawberry-3.141 yes i did modify mmm-voice.js to suit my needs. to explain, i have a total of 5 commands. “fall” is the first mode and is native to the voice module, under which i have 2 commands, “asleep” and “wake up”. so i say “hey mirror” (my listen command), then “fall asleep” and it cuts out the monitor, then since it’s already in “fall” mode i just say “wake up” and it turns the display back on. the final commands are for the compliments module and they are “how do” (the mode) and “i look” which is where i’m having problems. fall asleep and wake up are working perfectly.
                              so yes, i modified the lines that you highlighted such that the 2 places where it used to say ‘VOICE’ it now says ‘FALL’.
                              should i not have done that? it seems to work. i had to make other minor changes of course to keep it working.
                              • strawberry 3.141S
                                @dogfeet if you changed that, then you also have to apply your renamin here
                                if(notification === "FALL_HOW DO" && sender.name === "MMM-voice"){
                                            this.hide(1000);
                                            // hide your module
                                  @strawberry-3.141 i feel so stupid :facepalm:
                                    dmwilsonkc
                                    So I must say the MMM-voice module (also with Mykle’s Hello-Lucy enhancements) works perfectly on my mirror… when I don’t have my Mycroft AI running at start as well. It’s an Error: resource busy/unavailable referring to the Microphone. When I stop Mycroft/restart mirror it works perfectly, but then Mycroft gets the same error. Any suggestions?
                                    I am thinking about building a MagicMirror skill for Mycroft, but Mycroft is Python not Java, and not a module. Would it be possible to send the same commands as Hello-Lucy (i.e. ‘HIDE_CLOCK’ for example) only use Websocket-client for Mycroft and send commands to the MagicMirror via socket.io?
                                    If so, what would handle the socketmessage? Would it be communicated to the right module/s. Would I also need to create a fork of the MMM-voice module with code to handle the socketmessages from Mycroft?
                                    Any guidance would be much appreciated!
                                    Sorry, I should have also said my mirror is running on a RPi 3b running Debian Jessie on a 16gb sd.
                                      dmwilsonkc
                                      • strawberry 3.141S
                                        strawberry 3.141 Project Sponsor Module Developer @dmwilsonkc
                                        @dmwilsonkc Error: resource busy/unavailable referring to the Microphone your microphone cannot be used by multiple processes at a time.
                                        In your case I rather suggest to write an own module for mycroft instead of a fork, as you’re using a complete different stt engine.
                                        If you’re interested in doing it via websockets you could have a look into mmm-mobile where i did something similar
                                          dmwilsonkc
                                          @strawberry-3.141 So I guess I kind of understood what is happening with the MMM-Mobile module of yours. I am very new to all of this and have only been dabbling in writing simple code up to now. It is much easier to build off of existing code that I know already works. If I could figure out a way to continuing to use your MMM-voice module and Mycroft at the same time, I would probably just do that, but as you pointed out both processes can’t use the microphone at the same time. Since Mycroft skills seem pretty straight forward to create, I thought eh… Why not attempt it.
                                          I can create a Mycoft skill that will send ‘HIDE_CLOCK’ for example to socket.io. What happens when the Websocket-client for Mycroft connects to socket.io and sends ‘HIDE_CLOCK’? How would MagicMirror handle that?
                                          Keep in mind, I have already added Mykle’s modifications from Hello-Lucy.
                                          That’s part of what I can’t wrap my head around.
                                          Thank you for responding and helping me!
                                          • strawberry 3.141S
                                            @dmwilsonkc the module has a socket like https://github.com/MichMich/MagicMirror/blob/master/js/socketclient.js#L11, basically its a channel with the module name, if you then send messages, the module doesn#t differentiate if its from mycroft or node_helper, as it isnt aware of multiple entities.
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 15 / 17
