    MMM-EventHorizon
    Scheduled Pinned Locked Moved Fun & Games
    41 Posts 8 Posters 34.0k Views 8 Watching
    • Mykle1M
      Description:
      MMM-EventHorizon
      Simple countdown timer for events. Birthdays, weddings, anniversaries, vacations, etc.
      Extremely small footprint won’t crowd your mirror
      Examples:
      • Small, medium or large display options.
      Download:
      [card:mykle1/MMM-EventHorizon]
      Version 1.0.0
      Reply Quote 4
      • A
        AnduriI
        Hi @Mykle1,
        great module! Is it also possible to show only the days left? It’s kind of useless to show for example seconds until a specific date (vacation, birthday,…) :-)
        Maybe you could add an option in the config to display only dd or dd:hh or dd:hh:mm.
        Mykle1M 1 Reply Last reply
        • Mykle1M
          Mykle1 Project Sponsor Module Developer @AnduriI
          @andurii
          I wanted it to be a countdown timer. @broberg has a module that displays as you’ve described. Just the days.
          https://forum.magicmirror.builders/topic/1846/mmm-doomsday-the-countdown-module
            MrNonoss
            Hi Mykle1,
            Mike always, nice module.
            I’m looking for something very similar. In fact, I’d like not a countdown, but something to count days, hours, minutes and seconds passed from a specific date (my son birth day).
            Could this module be granted with this possibility ? Or maybe it is easy to change ?
            What do you think ?
            Thank you.
            Mykle1M 2 Replies Last reply
            • Mykle1M
              Mykle1 Project Sponsor Module Developer @MrNonoss
              @mrnonoss said in MMM-EventHorizon:
              What do you think ?
              Yes, I think that won’t be too much trouble. Just give me a little time to finish up what I am working on now and I’ll get right to it.
              • Mykle1M
                @mrnonoss
                Well, I got to it sooner than I thought. You can now choose if you want to “count up” or not.
                Do a git pull in the MMM-EventHorizon directory or install as per the readme.
                https://github.com/mykle1/MMM-EventHorizon
                  MrNonoss @Mykle1
                  @mykle1 oh man, you’re awsome.
                  I’ll give it à try when I go home.
                  Really, tank you à lot ! 👍
                  Will you update the readme for the synthax to be used ?
                  • Mykle1M
                    The update includes an amended readme. There is an addition to the config entry sample. countUp: "yes", (or no)
                    • H
                      Hein-Jan
                      @Mykle1
                      It feels like the timer is not indicating the correct time. It is set for 09:00:00. Current time is 21:40. Count down says we still have 17 hrs and 19 minutes to go. I think it should be 11 hrs and 21 minutes.
                      I am on Central European time. Could that be a contributing factor? Does the module vector in time-zone influences?
                      Hein-Jan
                      • Mykle1M
                        Mykle1 Project Sponsor Module Developer @Hein-Jan
                        @hein-jan
                        It never dawned on me that the timezsone was specific to the url being used in the module. The url itself is rather cryptic so I can’t determine what part is responsible for the timezone. Thus, I can’t make an option for timezones, unless someone wants to help determine that for me.
                        I have a work around if you are interested. You can go to https://www.timeanddate.com/clocks/freecountdown.html and create your own timer. You will be given a url when you are done. That url can be inserted into your copy of the module, with some minor modification and it will work.
                        This problem arises because the module is simply in an iFrame and not data from an API
                        • Mykle1M
                          @hein-jan said in MMM-EventHorizon:
                          I went and got a url for Central European time. Replace line 41 in the MMM-EventHorizon.js file with the following line.
                          iframe.src = "http://free.timeanddate.com/countdown/i6f8ps4b/n48/cf12/cm0/cu4/ct0/cs0/ca0/cr0/ss0/cac0ff/cpc0ff/pc000/tcfff/fs100/szw320/szh135/tat" + this.config.text1 + "/tac0ff/tpt" + this.config.endText1 + "/tpc0ff/mat" + this.config.text2 + "/mpt" + this.config.endText2 + "/mpc0ff/iso" + this.config.date + "T" + this.config.time;
                          This will only work when these two config.js options are as follows:
                          module: 'MMM-EventHorizon',
                                      position: 'bottom_left',
                                          size: "medium", // small, medium or large
                                          countUp: "yes", // yes or no (count up after timer is done)
                          The other config options will work as intended
                          • H
                            Hein-Jan
                            Mykle1
                            Thanks for your reply and confirming that it is a time-zone issues.
                            Instead of messing around with the code, I think I will simply off-set my event deadline time.
                            That way I am at least robust against updates.
                            Thanks for the work with the CET link.
                            Hein-Jan
                            • Mykle1M
                              @hein-jan
                              You could do that or you could make it your own. Feel free to make any edits that please you. Ah, the beauty of open source. :-) Have fun.
                              • Mykle1M
                                Update:
                                Version 1.0.1
                                Thanks to @spitzlbergerj for taking the initiative here. He posted an issue at the repo which included the modificatons so I wanted him to get the credit and my thanks.
                                Now you can color text line by line AND use any city you like as the timezone.
                                git pull or install as per the readme
                                • Mykle1M
                                  Update:
                                  Version update 1.0.2
                                  Added an option for unit designation
                                  1. No units
                                  2. D H M S
                                  3. Day Hr Min Sec
                                  4. Days Hrs Mins Secs
                                  5. Days Hours Minutes Seconds (Full names)
                                  Example of option 1 and 2
                                  0_1548380952908_Screenshot from 2019-01-24 19-13-00.png - 0_1548381184316_wert.png
                                  swvalentiS 1 Reply Last reply
                                  Reply Quote 2
                                  • swvalentiS
                                    swvalenti Project Sponsor @Mykle1
                                    @Mykle1 Any way to add years to this? I retire in 2515 days, but would like to know years then days. HA! I keep having to fn pull out the calculator to convert.
                                    Thanks ahead if this can be done!
                                    Regards, Scott
                                    Mykle1M 3 Replies Last reply
                                    • Mykle1M
                                      Mykle1 Project Sponsor Module Developer @swvalenti
                                      @swvalenti
                                      Scott,
                                      I’m terribly sorry but this module doesn’t use a conventional api data source which would have allowed me to do the computations on the data. Thus, converting all those days to years. It’s simply using an iFrame and tapping in to this web site. You can see on the site that “days” is not an option. My apologies.
                                      Peace!
                                      • Mykle1M
                                        @swvalenti
                                        Hey Scott,
                                        You could try this module. It shows just the days remaining.
                                        • swvalentiS
                                          @Mykle1 said in MMM-EventHorizon:
                                          @swvalenti
                                          Hey Scott,
                                          I will give that a go thank you sir.
                                          • Mykle1M
                                            @swvalenti
                                            Upon further inspection of the site I found that “Show Days Only” is an option. Sorry I missed it the first time. If you would not mind trying it out and reporting back to me I would be grateful. I updated the repo. Note: New config option.
