    MMM-EventHorizon
    Scheduled Pinned Locked Moved Fun & Games
    41 Posts 8 Posters 33.0k Views 8 Watching
      MrNonoss
      Hi Mykle1,
      Mike always, nice module.
      I’m looking for something very similar. In fact, I’d like not a countdown, but something to count days, hours, minutes and seconds passed from a specific date (my son birth day).
      Could this module be granted with this possibility ? Or maybe it is easy to change ?
      What do you think ?
      Thank you.
        Mykle1 Project Sponsor Module Developer @MrNonoss
        @mrnonoss said in MMM-EventHorizon:
        What do you think ?
        Yes, I think that won’t be too much trouble. Just give me a little time to finish up what I am working on now and I’ll get right to it.
          @mrnonoss
          Well, I got to it sooner than I thought. You can now choose if you want to “count up” or not.
          Do a git pull in the MMM-EventHorizon directory or install as per the readme.
          https://github.com/mykle1/MMM-EventHorizon
            MrNonoss @Mykle1
            @mykle1 oh man, you’re awsome.
            I’ll give it à try when I go home.
            Really, tank you à lot ! 👍
            Will you update the readme for the synthax to be used ?
              The update includes an amended readme. There is an addition to the config entry sample. countUp: "yes", (or no)
              • H Offline
                Hein-Jan
                @Mykle1
                It feels like the timer is not indicating the correct time. It is set for 09:00:00. Current time is 21:40. Count down says we still have 17 hrs and 19 minutes to go. I think it should be 11 hrs and 21 minutes.
                I am on Central European time. Could that be a contributing factor? Does the module vector in time-zone influences?
                Hein-Jan
                  Mykle1 Project Sponsor Module Developer @Hein-Jan
                  @hein-jan
                  It never dawned on me that the timezsone was specific to the url being used in the module. The url itself is rather cryptic so I can’t determine what part is responsible for the timezone. Thus, I can’t make an option for timezones, unless someone wants to help determine that for me.
                  I have a work around if you are interested. You can go to https://www.timeanddate.com/clocks/freecountdown.html and create your own timer. You will be given a url when you are done. That url can be inserted into your copy of the module, with some minor modification and it will work.
                  This problem arises because the module is simply in an iFrame and not data from an API
                    @hein-jan said in MMM-EventHorizon:
                    I went and got a url for Central European time. Replace line 41 in the MMM-EventHorizon.js file with the following line.
                    iframe.src = "http://free.timeanddate.com/countdown/i6f8ps4b/n48/cf12/cm0/cu4/ct0/cs0/ca0/cr0/ss0/cac0ff/cpc0ff/pc000/tcfff/fs100/szw320/szh135/tat" + this.config.text1 + "/tac0ff/tpt" + this.config.endText1 + "/tpc0ff/mat" + this.config.text2 + "/mpt" + this.config.endText2 + "/mpc0ff/iso" + this.config.date + "T" + this.config.time;
                    This will only work when these two config.js options are as follows:
                    module: 'MMM-EventHorizon',
                                position: 'bottom_left',
                                    size: "medium", // small, medium or large
                                    countUp: "yes", // yes or no (count up after timer is done)
                    The other config options will work as intended
                    • H Offline
                      Hein-Jan
                      Mykle1
                      Thanks for your reply and confirming that it is a time-zone issues.
                      Instead of messing around with the code, I think I will simply off-set my event deadline time.
                      That way I am at least robust against updates.
                      Thanks for the work with the CET link.
                      Hein-Jan
                        @hein-jan
                        You could do that or you could make it your own. Feel free to make any edits that please you. Ah, the beauty of open source. :-) Have fun.
                          Update:
                          [card:mykle1/MMM-EventHorizon]
                          Version 1.0.1
                          Thanks to @spitzlbergerj for taking the initiative here. He posted an issue at the repo which included the modificatons so I wanted him to get the credit and my thanks.
                          Now you can color text line by line AND use any city you like as the timezone.
                          git pull or install as per the readme
                            Update:
                            Version update 1.0.2
                            Added an option for unit designation
                            1. No units
                            2. D H M S
                            3. Day Hr Min Sec
                            4. Days Hrs Mins Secs
                            5. Days Hours Minutes Seconds (Full names)
                            Example of option 1 and 2
                            0_1548380952908_Screenshot from 2019-01-24 19-13-00.png - 0_1548381184316_wert.png
                            swvalentiS 1 Reply Last reply Reply Quote 2
                            • swvalentiS Offline
                              swvalenti Project Sponsor @Mykle1
                              @Mykle1 Any way to add years to this? I retire in 2515 days, but would like to know years then days. HA! I keep having to fn pull out the calculator to convert.
                              Thanks ahead if this can be done!
                              Regards, Scott
                              Mykle1M 3 Replies Last reply Reply Quote 0
                                Mykle1 Project Sponsor Module Developer @swvalenti
                                @swvalenti
                                Scott,
                                I’m terribly sorry but this module doesn’t use a conventional api data source which would have allowed me to do the computations on the data. Thus, converting all those days to years. It’s simply using an iFrame and tapping in to this web site. You can see on the site that “days” is not an option. My apologies.
                                Peace!
                                  @swvalenti
                                  Hey Scott,
                                  You could try this module. It shows just the days remaining.
                                  https://forum.magicmirror.builders/topic/1846/mmm-doomsday-the-countdown-module
                                  swvalentiS 1 Reply Last reply Reply Quote 0
                                    @Mykle1 said in MMM-EventHorizon:
                                    @swvalenti
                                    Hey Scott,
                                    I will give that a go thank you sir.
                                      @swvalenti
                                      Upon further inspection of the site I found that “Show Days Only” is an option. Sorry I missed it the first time. If you would not mind trying it out and reporting back to me I would be grateful. I updated the repo. Note: New config option.
                                        Update:
                                        Version update 1.0.3
                                        Added an option to display only days remaining, as per request by @swvalenti.
                                        swvalentiS 1 Reply Last reply Reply Quote 1
                                          @Mykle1 doing something wrong when added justDays, now a config error shows…ideas?
                                          	disabled: false,
                                          	position: 'top_left',
                                              	timezone: "n2268",                     // See Timezone chart at bottom
                                          	justDays: “yes”,
                                              	size: "large",                        // small, medium or large
                                              	countUp: "yes",                       // Count up after timer ends
                                              	date: "2026-09-04",                   // YYYY-MM-DD format ONLY
                                              	time: "23:59:59",                     // (HH:MM:SS)    Exact time you want timer to end
                                              	text1: "Until Retirement",         // 2 lines of text during timer
                                              	text2: "Bitches!",               // 2 lines of text during timer
                                              	text1Color: "4169E1",                 // Hex color codes
                                              	text2Color: "C0C0C0",                 // Hex color codes
                                              	timerColor: "FFFFFF",                 // Hex color codes
                                              	endText1: "When timer ends",          // 2 lines of text when timer ends
                                              	endText2: "Say something here",       // 2 lines of text when timer ends
                                              	endText1Color: "FFFFFF",              // Hex color codes
                                              	endText2Color: "62FF00",              // Hex color codes
                                              	timerUpColor: "FFFFFF",               // Hex color codes
                                              	colorpc: "000",                       // color of the background 000 = black, t = transparent
                                            sdetweil @swvalenti
                                            @swvalenti Wrong double quote characters. Type it from the keyboard, not cut/paste
