    MMM-EventHorizon
    Scheduled Pinned Locked Moved Fun & Games
    41 Posts 8 Posters 34.1k Views 8 Watching
    • Mykle1M
      Mykle1 Project Sponsor Module Developer @Hein-Jan
      @hein-jan
      It never dawned on me that the timezsone was specific to the url being used in the module. The url itself is rather cryptic so I can’t determine what part is responsible for the timezone. Thus, I can’t make an option for timezones, unless someone wants to help determine that for me.
      I have a work around if you are interested. You can go to https://www.timeanddate.com/clocks/freecountdown.html and create your own timer. You will be given a url when you are done. That url can be inserted into your copy of the module, with some minor modification and it will work.
      This problem arises because the module is simply in an iFrame and not data from an API
      • Mykle1M
        @hein-jan said in MMM-EventHorizon:
        I am on Central European time.
        I went and got a url for Central European time. Replace line 41 in the MMM-EventHorizon.js file with the following line.
        iframe.src = "http://free.timeanddate.com/countdown/i6f8ps4b/n48/cf12/cm0/cu4/ct0/cs0/ca0/cr0/ss0/cac0ff/cpc0ff/pc000/tcfff/fs100/szw320/szh135/tat" + this.config.text1 + "/tac0ff/tpt" + this.config.endText1 + "/tpc0ff/mat" + this.config.text2 + "/mpt" + this.config.endText2 + "/mpc0ff/iso" + this.config.date + "T" + this.config.time;
        This will only work when these two config.js options are as follows:
        module: 'MMM-EventHorizon',
                    position: 'bottom_left',
                        size: "medium", // small, medium or large
                        countUp: "yes", // yes or no (count up after timer is done)
        The other config options will work as intended
        • H
          Hein-Jan
          Mykle1
          Thanks for your reply and confirming that it is a time-zone issues.
          Instead of messing around with the code, I think I will simply off-set my event deadline time.
          That way I am at least robust against updates.
          Thanks for the work with the CET link.
          Hein-Jan
          Mykle1M 1 Reply Last reply
          • Mykle1M
            @hein-jan
            You could do that or you could make it your own. Feel free to make any edits that please you. Ah, the beauty of open source. :-) Have fun.
            • Mykle1M
              Update:
              [card:mykle1/MMM-EventHorizon]
              Version 1.0.1
              Thanks to @spitzlbergerj for taking the initiative here. He posted an issue at the repo which included the modificatons so I wanted him to get the credit and my thanks.
              Now you can color text line by line AND use any city you like as the timezone.
              git pull or install as per the readme
              • Mykle1M
                Update:
                Version update 1.0.2
                Added an option for unit designation
                1. No units
                2. D H M S
                3. Day Hr Min Sec
                4. Days Hrs Mins Secs
                5. Days Hours Minutes Seconds (Full names)
                Example of option 1 and 2
                0_1548380952908_Screenshot from 2019-01-24 19-13-00.png - 0_1548381184316_wert.png
                swvalentiS 1 Reply Last reply
                Reply Quote 2
                • swvalentiS
                  swvalenti Project Sponsor @Mykle1
                  @Mykle1 Any way to add years to this? I retire in 2515 days, but would like to know years then days. HA! I keep having to fn pull out the calculator to convert.
                  Thanks ahead if this can be done!
                  Regards, Scott
                  Mykle1M 3 Replies Last reply
                  • Mykle1M
                    Mykle1 Project Sponsor Module Developer @swvalenti
                    @swvalenti
                    Scott,
                    I’m terribly sorry but this module doesn’t use a conventional api data source which would have allowed me to do the computations on the data. Thus, converting all those days to years. It’s simply using an iFrame and tapping in to this web site. You can see on the site that “days” is not an option. My apologies.
                    Peace!
                    • Mykle1M
                      @swvalenti
                      Hey Scott,
                      You could try this module. It shows just the days remaining.
                      https://forum.magicmirror.builders/topic/1846/mmm-doomsday-the-countdown-module
                      • swvalentiS
                        @Mykle1 said in MMM-EventHorizon:
                        @swvalenti
                        Hey Scott,
                        I will give that a go thank you sir.
                        • Mykle1M
                          @swvalenti
                          Upon further inspection of the site I found that “Show Days Only” is an option. Sorry I missed it the first time. If you would not mind trying it out and reporting back to me I would be grateful. I updated the repo. Note: New config option.
                          • Mykle1M
                            Update:
                            Version update 1.0.3
                            Added an option to display only days remaining, as per request by @swvalenti.
                            Do a git pull in the MMM-EventHorizon directory or install as per the readme.
                            • swvalentiS
                              @Mykle1 doing something wrong when added justDays, now a config error shows…ideas?
                              	disabled: false,
                              	position: 'top_left',
                                  	timezone: "n2268",                     // See Timezone chart at bottom
                              	justDays: “yes”,
                                  	size: "large",                        // small, medium or large
                                  	countUp: "yes",                       // Count up after timer ends
                                  	date: "2026-09-04",                   // YYYY-MM-DD format ONLY
                                  	time: "23:59:59",                     // (HH:MM:SS)    Exact time you want timer to end
                                  	text1: "Until Retirement",         // 2 lines of text during timer
                                  	text2: "Bitches!",               // 2 lines of text during timer
                                  	text1Color: "4169E1",                 // Hex color codes
                                  	text2Color: "C0C0C0",                 // Hex color codes
                                  	timerColor: "FFFFFF",                 // Hex color codes
                                  	endText1: "When timer ends",          // 2 lines of text when timer ends
                                  	endText2: "Say something here",       // 2 lines of text when timer ends
                                  	endText1Color: "FFFFFF",              // Hex color codes
                                  	endText2Color: "62FF00",              // Hex color codes
                                  	timerUpColor: "FFFFFF",               // Hex color codes
                                  	colorpc: "000",                       // color of the background 000 = black, t = transparent
                                sdetweil @swvalenti
                                @swvalenti Wrong double quote characters. Type it from the keyboard, not cut/paste
                                Reply Quote 2
                                • swvalentiS
                                  swvalenti Project Sponsor @sdetweil
                                  @sdetweil said in MMM-EventHorizon:
                                  I’m an idiot thank you sir that fixed it. Thanks @Mykle1 for the quick update! You guys rock.
                                  • Mykle1M
                                    @swvalenti said in MMM-EventHorizon:
                                    You’re welcome, mate. Turned out to be a rather easy update. I’m glad you suggested it because now the module has more, better options and should appeal to more users.
                                    • Mykle1M
                                      Ok, I meant there was no “YEARS” option. justDays option was the best I could do for you as the site does not offer that option.
                                      • BKeyportB
                                        BKeyport Module Developer
                                        Hey, Mykle,
                                        I’ve got EventHorizon jumping out of it’s box when it’s grouped with other modules.
                                        When it’s by itself, It’s fine.
                                        Any clues?
                                        • Mykle1M
                                          Mykle1 Project Sponsor Module Developer @BKeyport
                                          @BKeyport said in MMM-EventHorizon:
                                          Any clues?
                                          css? I think I set that up that way for my personal use. Give the css file a look.
                                          BKeyportB 1 Reply Last reply
                                          • BKeyportB
                                            BKeyport Module Developer @Mykle1
                                            @Mykle1 Yeah, it was the right-margin.
                                            it was set to -120px, and in my case I need to have it at -40px.
                                            thanks for the clue.
