    MMM-DarkSkyForecast - Yet ANOTHER weather module
    334 Posts 67 Posters 942.5k Views 74 Watching
    • lavolp3L
      lavolp3 Module Developer @Cr4z33
      @cr4z33 it is shown if you include
      concise: false
      into the config.
      That’s the way to show more info.
      If you want to ONLY show the wind direction you would have to manipulate the .js file manually in line 429
            windSpeed: Math.round(speed) + " " + this.getUnit("windSpeed") + (!this.config.concise ? " " + this.getOrdinal(bearing) : ""),
      into
            windSpeed: Math.round(speed) + " " + this.getUnit("windSpeed") + " " + this.getOrdinal(bearing),
      In my case this unfortunately messes up the layout a bit. But it seems to work.
      How to troubleshoot modules
      MMM-soccer v2, MMM-AVStock
      Cr4z33C J 2 Replies Last reply
      • Cr4z33C
        Cr4z33 @lavolp3
        @lavolp3 said in MMM-DarkSkyForecast - Yet ANOTHER weather module:
        concise: false
        into the config.
        That’s already perfect thanks! :thumbs_up_medium-light_skin_tone:
          j.e.f.f Project Sponsor Module Developer @richland007
          @richland007 said in MMM-DarkSkyForecast - Yet ANOTHER weather module:
          @j-e-f-f Thank you for your reply.
          Do you want my entire MM config.js file or just the MMM-DarkSkyForecast part of it??
          D
          Just the dark sky portion.
            jackoliver361
            Hey i have your module working but when i also add the MMM-Awsome-alexa module it moves to this location even though ive set it to display in the top_right. It goes into the right location when mmm-awesome-alexa is removed. Any ideas ? 0_1548268916774_problem.JPG
            J 1 Reply Last reply
              j.e.f.f Project Sponsor Module Developer @lavolp3
              Or you can write rules to hide things in your custom.css file. That way your change doesn’t get overwritten by a module update. I’ve wrapped everything in a css class, so you can pick and choose what is displayed. Start MM in dev mode and you can use the inspector to figure out the class names, or examine MMM-DarkSkyForecast.njk to see the HTML layout and the classes applied.
              For example, let’s say you wanted the wind direction, but not the max wind speed. First set concise: false in the module’s config. Then hide the max speed as follows:
              MMM-DarkSkyForecast .wrapper.tiled .forecast-container .forecast-item .wind-gusts {
                  display: none;
              Make sure to take a look at .MMM-DarkSkyForecast.css to see hoe specific the existing rule is. Yours needs to be at least as specific if you want it to override the default. For example, this would not have worked:
              MMM-DarkSkyForecast .wind-gusts {
                  display: none;
              since the existing rule is more specific:
                  display: block;
                j.e.f.f Project Sponsor Module Developer @jackoliver361
                @jackoliver361 said in MMM-DarkSkyForecast - Yet ANOTHER weather module:
                This is strange behaviour… Does this happen regardless of where you specify awesome-alexa to be? For example if you specify that it should be bottom_center does it still mess up Dark Sky?
                  btorres79
                  Sorry for this noob question but is it possible to change the temperature display from celsius to farenheit?
                  • N
                    nobita @j.e.f.f
                    from your info " …this module requires MagicMirror version 2.2.0 or later…"
                    so How can I know my version of Magic Mirror?
                    Thanks so much
                      j.e.f.f Project Sponsor Module Developer @btorres79
                      @btorres79 said in MMM-DarkSkyForecast - Yet ANOTHER weather module:
                      yep. Set units: "us" in your config.
                      B 1 Reply Last reply
                        btorres79 @j.e.f.f
                        @j-e-f-f Thanks for the info. I will give it a go. Thanks for creating an awesome module.
                          robiv8
                          and how can I doit this for german?
                          and when you say “…Set units: “us” in your config.”
                          where comes this in the config?
                          please take a look at my sample config
                            module: "MMM-DarkSkyForecast",
                            header: "Weather",
                            classes: "default everyone",
                            disabled: false,
                              apikey: "SUPER SECRET!!!",
                              latitude: "51.506130",
                              longitude: "-0.090270",
                              iconset: "4c",
                              concise: false,
                              forecastLayout: "table",
                              units: "auto", < - - #### is this so right for german?
                              language: "de" < - - #### is this so right for german?
                            j.e.f.f Project Sponsor Module Developer @robiv8
                            @robiv8 said in MMM-DarkSkyForecast - Yet ANOTHER weather module:
                              header: "Weather",
                              disabled: false,
                                iconset: "4c",
                                concise: false,
                            My module doesn’t support the auto parameter for units, even though it’s valid for calling Dark Sky’s API directly. My thinking was that it’s ambiguous as to what you might get, and everyone will know exactly which units of measure they want. So you need to specify one of the four explicit options for units:
                            si : metric units. (temp in Celcius, wind measured in m/s)
                            ca: same as si but wind measured in km/h
                            uk2: same as si, but wind measured in mph
                            us : imperial units. (temp in Farhenheit, wind in mph)
                            If you specify anything else or omit the units config, the module defaults to ca. (Oh Canada!)
                            As for the language config, this is independent of units. This will determine editorial content that the API returns such as the weather summary, and eventually when I get around to adding it, weather alerts. If you leave it blank, it will use the language config for MagicMirror, so if you’ve already got MM configured for German, then you don’t need to set the language parameter to get this content in German. The parameter is there in case for some reason you want a language other than what you have MM configured for, or maybe MM doesn’t support your preferred language, but Dark Sky does, for example x-pig-latin for Pig Latin. (Seriously… try it!)
                            • swvalentiS
                              swvalenti Project Sponsor
                              When I installed this module it did not import current region settings etc based on pi software install as I had to change them all in the config. I just thought I was an idiot and did something wrong when installing module and didn’t want to look like a fool posting an issue. HA!
                                robiv8
                                Thanks for the explanation.
                                Without extra entries in the config, the weather and the text is in German.
                                But the time on US like 7pm 1pm and so on …
                                How can I change that and where?
                                  j.e.f.f Project Sponsor Module Developer @nobita
                                  @nobita said in MMM-DarkSkyForecast - Yet ANOTHER weather module:
                                  Thanks so much
                                  Two ways you can tell… When you start MM with npm start you’ll see the version number of MagicMirror. Otherwise, just try running the module. If you get weird gibberish on the screen that looks like default non-specific module content then you need to upgrade. Otherwise, if you see weather content, then you’re fine.
                                  If you’ve installed Magic Mirror somewhat recently, then likely your version is adequate.
                                    In the README file there are a few config options you’ll be interested in:
                                    label_maximum
                                    label_high
                                    label_low
                                    label_timeFormat
                                    label_days
                                    label_ordinals
                                    These can be used to customize text to your exact liking.
                                    Read about all of the config parameters here:
                                    https://github.com/jclarke0000/MMM-DarkSkyForecast/blob/master/README.md
                                      jackoliver361 @j.e.f.f
                                      @j-e-f-f 0_1548845698182_problem.JPG it still does it even though alexa is in bottom center, here is my config file.
                                        robiv8
                                        Thanks for the tip. Now it working in German.
                                        • N
                                          nobita @lavolp3
                                          @lavolp3 ,after install DarkSkyForecast only “Loading…” display and use " npm start dev"
                                          Error happen like this
                                          someone help me please,how to solve it
                                          Mykle1M S 2 Replies Last reply
                                          • Mykle1M
                                            Mykle1 Project Sponsor Module Developer @nobita
                                            @nobita
                                            You have to cd into the MagicMirror directory first, then run npm start dev
                                            pop@HPEu:~$ cd MagicMirror/
                                            pop@HPEu:~/MagicMirror$ npm start dev
                                            N 1 Reply Last reply
                                            • 16
                                            • 17
                                            • 6 / 17
