    MMM-DarkSkyForecast - Yet ANOTHER weather module
    334 Posts 67 Posters 942.5k Views 74 Watching
      j.e.f.f Project Sponsor Module Developer @jackoliver361
      @jackoliver361 said in MMM-DarkSkyForecast - Yet ANOTHER weather module:
      Hey i have your module working but when i also add the MMM-Awsome-alexa module it moves to this location even though ive set it to display in the top_right. It goes into the right location when mmm-awesome-alexa is removed. Any ideas ?
      This is strange behaviour… Does this happen regardless of where you specify awesome-alexa to be? For example if you specify that it should be bottom_center does it still mess up Dark Sky?
      J 1 Reply Last reply
        btorres79
        Sorry for this noob question but is it possible to change the temperature display from celsius to farenheit?
        • N
          nobita @j.e.f.f
          from your info " …this module requires MagicMirror version 2.2.0 or later…"
          so How can I know my version of Magic Mirror?
          Thanks so much
            j.e.f.f Project Sponsor Module Developer @btorres79
            @btorres79 said in MMM-DarkSkyForecast - Yet ANOTHER weather module:
            yep. Set units: "us" in your config.
            B 1 Reply Last reply
              btorres79 @j.e.f.f
              @j-e-f-f Thanks for the info. I will give it a go. Thanks for creating an awesome module.
                robiv8
                and how can I doit this for german?
                and when you say “…Set units: “us” in your config.”
                where comes this in the config?
                please take a look at my sample config
                  module: "MMM-DarkSkyForecast",
                  header: "Weather",
                  classes: "default everyone",
                  disabled: false,
                    apikey: "SUPER SECRET!!!",
                    latitude: "51.506130",
                    longitude: "-0.090270",
                    iconset: "4c",
                    concise: false,
                    forecastLayout: "table",
                    units: "auto", < - - #### is this so right for german?
                    language: "de" < - - #### is this so right for german?
                  j.e.f.f Project Sponsor Module Developer @robiv8
                  @robiv8 said in MMM-DarkSkyForecast - Yet ANOTHER weather module:
                    header: "Weather",
                    disabled: false,
                      iconset: "4c",
                      concise: false,
                  My module doesn’t support the auto parameter for units, even though it’s valid for calling Dark Sky’s API directly. My thinking was that it’s ambiguous as to what you might get, and everyone will know exactly which units of measure they want. So you need to specify one of the four explicit options for units:
                  si : metric units. (temp in Celcius, wind measured in m/s)
                  ca: same as si but wind measured in km/h
                  uk2: same as si, but wind measured in mph
                  us : imperial units. (temp in Farhenheit, wind in mph)
                  If you specify anything else or omit the units config, the module defaults to ca. (Oh Canada!)
                  As for the language config, this is independent of units. This will determine editorial content that the API returns such as the weather summary, and eventually when I get around to adding it, weather alerts. If you leave it blank, it will use the language config for MagicMirror, so if you’ve already got MM configured for German, then you don’t need to set the language parameter to get this content in German. The parameter is there in case for some reason you want a language other than what you have MM configured for, or maybe MM doesn’t support your preferred language, but Dark Sky does, for example x-pig-latin for Pig Latin. (Seriously… try it!)
                  • swvalentiS
                    swvalenti Project Sponsor
                    When I installed this module it did not import current region settings etc based on pi software install as I had to change them all in the config. I just thought I was an idiot and did something wrong when installing module and didn’t want to look like a fool posting an issue. HA!
                      robiv8
                      Thanks for the explanation.
                      Without extra entries in the config, the weather and the text is in German.
                      But the time on US like 7pm 1pm and so on …
                      How can I change that and where?
                        j.e.f.f Project Sponsor Module Developer @nobita
                        @nobita said in MMM-DarkSkyForecast - Yet ANOTHER weather module:
                        Thanks so much
                        Two ways you can tell… When you start MM with npm start you’ll see the version number of MagicMirror. Otherwise, just try running the module. If you get weird gibberish on the screen that looks like default non-specific module content then you need to upgrade. Otherwise, if you see weather content, then you’re fine.
                        If you’ve installed Magic Mirror somewhat recently, then likely your version is adequate.
                          In the README file there are a few config options you’ll be interested in:
                          label_maximum
                          label_high
                          label_low
                          label_timeFormat
                          label_days
                          label_ordinals
                          These can be used to customize text to your exact liking.
                          Read about all of the config parameters here:
                          https://github.com/jclarke0000/MMM-DarkSkyForecast/blob/master/README.md
                            jackoliver361 @j.e.f.f
                            @j-e-f-f 0_1548845698182_problem.JPG it still does it even though alexa is in bottom center, here is my config file.
                              robiv8
                              Thanks for the tip. Now it working in German.
                              • N
                                nobita @lavolp3
                                @lavolp3 ,after install DarkSkyForecast only “Loading…” display and use " npm start dev"
                                Error happen like this
                                someone help me please,how to solve it
                                Mykle1M S 2 Replies Last reply
                                • Mykle1M
                                  Mykle1 Project Sponsor Module Developer @nobita
                                  @nobita
                                  You have to cd into the MagicMirror directory first, then run npm start dev
                                  pop@HPEu:~$ cd MagicMirror/
                                  pop@HPEu:~/MagicMirror$ npm start dev
                                  N 1 Reply Last reply
                                    robiv8
                                    You must be in your MagicMirror folder!
                                    and then type: npm start dev
                                    Oh! Sorry @Mykle1
                                    Did not see that you have already answered.
                                    Mykle1M 1 Reply Last reply
                                    • Mykle1M
                                      Mykle1 Project Sponsor Module Developer @robiv8
                                      @robiv8
                                      No worries. I like your answer so much that I’m upvoting it! :thumbsup:
                                        sdetweil @nobita
                                        • N
                                          nobita @Mykle1
                                          @mykle1 Thank so much,Beacuse I’m Beginner and my mistake
                                          • Mykle1M
                                            @nobita
                                            You’re welcome. We all make mistakes. We were all beginners. Can’t we all just get along? :-)
                                            Peace!
                                            • 16
                                            • 17
                                            • 6 / 17
