    Complete Walkthrough - Install MagicMirror on a PC - Windows 7/10
    324 Posts 55 Posters 855.8k Views 59 Watching
      djniuss @sdetweil
      @sdetweil yep did reboot a few time. it does not seem that i have more thant one mingw32 running or electron browser.
      the only error i have in the log is regardin the polution ( NOAA3 weather updated… next update in 1 hour
      fr
      Whoops! There was an uncaught exception…
      TypeError: Cannot read property ‘pollution’ of undefined)
      if this helps
      C:\WINDOWS\system32>netstat -aon | findstr 8080
      TCP 127.0.0.1:8080 0.0.0.0:0 LISTENING 5216
      TCP 127.0.0.1:8080 127.0.0.1:53407 ESTABLISHED 5216
      TCP 127.0.0.1:53407 127.0.0.1:8080 ESTABLISHED 5216
        djniuss
        just found out that if i enter 0.0.0.0 i can acces from other computer via Chrome. but the computer that runs MM as a black screen.
        and by mistake : on the computer that as the MM running i had the black screen so i opend up the chrmome browser wit the local host add . i was about the drag the top bar on the desktop in order to have a MM browser chrome link on the desktop … i droped it on the black screen ( electron) and automatically the MM showed up.
          sdetweil @djniuss
          @djniuss sorry, I don’t understand what you said.
          if u have black screen, ctrl-shift-i to open the developers env, and then select the console tab and scroll to find errors (red text)…
          most of the UI errors like this, will kill the UI (and result in a black screen)
            jelbear
            Thanks for this guide its been really helpful, it has enabled me to install MM on a win7 VM acting as a node serveronly on an always on machine, which helps to release some resources on a Pi zero attached to a display.
            Everything seems to run OK, other than any module that pulls images from a path e.g. MMM-Wallpaper, MMM-Backgroundslideshow, even when the config is left to use the default paths to the module’s examples, there is an ENOENT error shown in the Git Bash window. Doesn’t matter if they are url link images i.e. bing or locally stored images.
            Using the exact same config script when installed on a Pi the background images show.
            Anyone got any ideas about how this can be fixed, as I’m not using it as a mirror, but as a family kitchen dashboard so the images are fairly important.
            a “npm run config:check” command says that there are no syntax errors in the config file
            I believe it has to to with path syntax between windows and linux but that is about all I can come up with
            { Error: ENOENT: no such file or directory, scandir '/modules/MMM-BackgroundSlid
            eshow/exampleImages'
                at Object.readdirSync (fs.js:785:3)
                at Class.getFiles (C:\Users\Admin\MagicMirror\modules\MMM-BackgroundSlidesho
            w\node_helper.js:71:45)
                at Class.gatherImageList (C:\Users\Admin\MagicMirror\modules\MMM-BackgroundS
            lideshow\node_helper.js:60:12)
                at Class.socketNotificationReceived (C:\Users\Admin\MagicMirror\modules\MMM-
            BackgroundSlideshow\node_helper.js:92:28)
                at Socket.<anonymous> (C:\Users\Admin\MagicMirror\modules\node_modules\node_
            helper\index.js:113:11)
                at Socket.emit (events.js:189:13)
                at C:\Users\Admin\MagicMirror\node_modules\socket.io\lib\socket.js:528:12
                at process._tickCallback (internal/process/next_tick.js:61:11)
              errno: -4058,
              syscall: 'scandir',
              code: 'ENOENT',
              path: '/modules/MMM-BackgroundSlideshow/exampleImages' }
            MagicMirror will not quit, but it might be a good idea to check why this happene
            d. Maybe no internet connection?
            If you think this really is an issue, please open an issue on GitHub: https://gi
            thub.com/MichMich/MagicMirror/issues
            justjim1220J lavolp3L 2 Replies Last reply Reply Quote 0
            • justjim1220J Offline
              justjim1220 Module Developer @jelbear
              @jelbear
              Just to be sure… You do have a folder named exampleImages within you MMM-BackgroundSlideshow directory???
              I just installed and ran this module on my Windows device and it works just fine.
              Looking at the error you posted above, it looks as if your exampeImages folder is missing.
              Jim Hallock - 1995
                jelbear
                I can confirm that the folder is there
                Modules were installed using git clone command while in the MagicMirror/modules folder.
                Is there anything different you have to do when installing modules under a windows system
                Currently I’m just doing the above command and then adding the required code to the config file
                justjim1220J B 2 Replies Last reply Reply Quote 0
                  @jelbear
                  Not that I can think of
                  I’m not using a RasPi either.
                  If I had one, I would try it to se if any difference.
                  Sorry.
                  Jim Hallock - 1995
                    bhepler Module Developer @jelbear
                    @jelbear - To my knowledge, the only difference between Windows and Linux systems is that you may have to specify the file paths slightly differently. Windows requires you to put any folder with a space in the name in quotes. This can get tricky when you’re passing in a string which is surrounded by quotes and also contains quotes.
                    Is there a space in any part of your path to the exampleImages folder?
                    • lavolp3L Offline
                      lavolp3 Module Developer @jelbear
                        jelbear
                        it somehow seems to have resolved itself
                        i deleted the folder and redid the git clone and it is working, not sure what happened, but it is working now,
                        many thanks for taking the time to reply
                          brandonbrown
                          @Mykle1 said in Complete Walkthrough - Install MagicMirror on a PC - Windows 7/10:
                          Install MagicMirror on a PC Windows 7/10 - Complete walkthrough
                          Thank you so much for this post! I’m new to the Pi and MagicMirror. Working on the PI remotely was a bit of pain and this allowed me to run MagicMirror on my main machine with VMWare Workstation.
                          First off let me say these instructions were ‘spot-on’ and I was up and running immediately.
                          As I added modules, I noticed some of them were not working, a.k.a. not loading any data. They would activate, say “loading…” and nothing else.
                          I researched a few of the modules I was using and found one step that needs to be on your list:
                          ‘npm install request’
                          After that, the modules in question began updating with data.
                          Thank you again for giving me a better dev environment to work in!
                          Brandon
                            Mykle1 Project Sponsor Module Developer @brandonbrown
                            @brandonbrown said in Complete Walkthrough - Install MagicMirror on a PC - Windows 7/10:
                            Well, the modules that require that package should tell you in their respective readme files but thanks for the headsup. I’m glad you found the tutorial helpful. :-)
                              dstoianovici
                              Hello, I had an EACCESS error thrown when launching the MM as directed in this thread. I was able to fix this error by changing the port number from 8080 to 9000 in config.js
                                sdetweil @dstoianovici
                                @dstoianovici yes,if some other app is using 8080 then u have to change it… mine is on 8086. 8080-8085 are in use
                                  CliffordW
                                  It should probably be easy, but I can’t seem to find it. What is the command I can use to start MM on Windows 10 startup?
                                    CliffordW
                                    Thanks for a great guide, got me up and running quickly. Can you guide me where do I insert the commands to rotate the display to portrait mode?
                                      bdream
                                      @Mykle1 Many thanks for this description!
                                      Just got it run under Windows 7. That will help to play and learn how to get own modules :nerd_face:
                                      Two questions I have.
                                      My MM is version 2.6.0. I planned to run updatescript from @sdetweil but failed. Yahe you any idea?
                                      Is there an option to run MM in a window being able to shrink and move over the desktop?
                                      cheers, bdream
                                      S Mykle1M 3 Replies Last reply Reply Quote 0
                                        sdetweil @bdream
                                        @bdream come talk in the Updated Installer topic
                                        https://forum.magicmirror.builders/topic/10171/anyone-want-to-try-updated-installer
                                          sdetweil @bdream
                                          @bdream F11 will take a window from full screen to not
                                            Mykle1 Project Sponsor Module Developer @bdream
                                            @bdream said in Complete Walkthrough - Install MagicMirror on a PC - Windows 7/10:
                                            Your F11 key should toggle between full screen MM and MM in a window
                                            • 16
                                            • 17
                                            • 4 / 17
