    [Remote-Control] Shutdown, Configure and Update your MagicMirror
    274 Posts 78 Posters 872.3k Views 77 Watching
      Jopyth Moderator
      Description:
      This module for the Magic Mirror² allows you to quickly shutdown your mirror through a web browser. The website should work fine on any device (desktop, smart phone, tablet, …). Additionally you can hide and show modules on your mirror, send alerts and do more cool stuff in the future.
      Screenshots:
      The Main Menu The Power Menu Hide and Show a Module
      Download:
      [card:Jopyth/MMM-Remote-Control]
      FAQ:
      Can not access the remote website (and the MagicMirror in general) at all (MagicMirror Version > 2.1.3)
      Possible solution: Change address in config
      White screen issues (after updating)?
      Possible solution: Run npm install
      Error: Cannot GET /remote.html
      Possible solution: [MMM-Remote-Control] Can not access remote control module
      “This device is not allowed to access your mirror. Please check your config.js or config.js.sample to change this.”
      Solution: ipWhitelist HowTo
      Changelog
      [2.1.0] - 2020-11-01
      Hello! Ezequiel here. Just wanted to say thanks for trust in me, in the past days I made a lot of changes into the code, adding some functions that’ll surely be in a future release, and also putting everything together in my fork. I answered almost every issue raised, and tried to help every person that use this module. Today, I’m glad to be able to share everything I learned to all of you. I apologize for some fast and uncommented commits, I just thinked that some things needed to be fixed ASAP.
      See you in future commits, issues and PRs :D
      Fixed
      • A typo in es translation
      • A few typos in README.md (#134 and #149) and API/README.md (#179)
      • Delayed commands should now work (#190)
      • Typo on remote_action (#184)
      • IP now showing (#194)
      • MM restart button don’t just stop anymore (#126)
      • Saving config should work as expected now (#153)
      • installer.sh now detects where’s the node instalation (#222)
      Added
      • Danish translation (#157)
      • Italian translation (#162)
      • Port now showing according to config.js (#98)
      • Custom commands for shutdown and reboot
      Changed
      • Overwrite of local changes when updating from a repository
      • Now requires MagicMirror version 2.12
      [2.0.1] - 2020-10-28
      Huge thanks to @ezeholz who has offered to maintain the module fron now on!
      Credit for this (and future) versions and releases goes to @ezeholz (unless noted otherwise).
      Now requires MagicMirror version 2.7.
      Fixed
      • Path to font awesome icons
      • A few typos in ca and es translations
      • Updates to remote.html to support new basePath feature in MM config.js, follow up to this MM issue, related to #185
      [2.0.0] - 2019-02-21
      Huge shoutout to shbatm for his work on this new major version, which brings a new API, custom menus and commands and lots of other stuff:
      Added
      • REST API interface for controlling all aspects of the MagicMirror from HTTP RESTful-style GET and POST calls, based on principles from MMM-Api
        • Full API Documentation at API/README.md
      • Live daily updates of modules.json from the MagicMirror wiki, based on principles from MMM-Remote-Control-Repository.
      • Incorporated some features found in MMM-OnScreenMenu that were not originally in this module.
        • Monitor (Connected Screen) On-Off Status and Toggle
        • Delayed calls (“DELAYED” Query option and .../delay API paths)
        • If using Electron: Open Dev Tools, Minimize, Toggle Fullscreen
      • Configuration Option to send custom shell commands to use. Currently, only custom monitor on/off/status commands are supported.
      • Module Control menu - Automatically generated from the API to control the different modules you have installed, based on their notificationReceived function.
      • Custom menu items. See Custom Menu Items in README
      • Norsk bokmål translation
      Changed
      • Updates to remote.html and the node_helper.js to use direct SocketIO communication back and forth instead of separate HTTP calls.
        • Future framework for following PM2 logs and more live update options.
      • General clean-up and standardization of status reporting for GET and POST calls, to original URLs and to new API URLs.
      • Updated to ES2015 (ES Version 6) function calls in most locations.
      • Added USER_PRESENCE controls from AgP42
      • Added/updated french translations from BKeyport and Mysh3ll
      • Added SHOW/HIDE/TOGGLE ALL modules option per request from Rene1709
      Upcoming Changes
      • Add additional MMM-OnScreenMenu features:
        • Moving modules’ positions
      • PM2 Log Follower / Terminal Window
      • Added Notification Echo option to config to echo all Module Notifications to the remote’s DevTools console for debugging.
      • Allow for text input in the Module Controls menu to be able to provide a notification payload.
      [1.1.5] - 2018-05-14
      Added
      • French translation
      Fixed
      • Updated documentation to new MagicMirror version
      • Fix error on updating MagicMirror
      [1.1.4] - 2017-09-17
      Added
      • Dutch translation
      • Updating a module tries to install dependencies with npm install
      • Module identifier is shown if a module is locked with lock strings
      • Confirmation dialog before restart and shutdown
      Fixed
      • Internal save file format and mistakenly hiding modules which were hidden by other modules
      • Restart should work for new installations
      Changed
      • German translation for power menu changed from “Ausschalten” to “Energieoptionen”
      [1.1.3] - 2017-04-23
      Added
      • Portuguese translation
      • Indonesian translation
      • Support for iOS Icon and Webapp
      Changed
      • Installation no longer needs a temporary file
      Fixed
      • Icon paths adapted to changes in Magic Mirror² 2.1.0
      [1.1.2] - 2017-02-01
      Note: Since version 1.1.0 this module uses (new) dependencies, check the Updating section in the README.md.
      Added
      • Swedish translation
      Changed
      • Installation process updated in README.md
      • Automatic installer/updater includes hint to restart Magic Mirror²
      Fixed
      • Issues with not applying shown and hidden status correctly to modules
      • Issues where lockstrings were missing
      • Modules sometimes did not show correctly in the UI as hidden or shown:
        • This is due to a bug in Magic Mirror²
        • PR #659 to fix this was made in the project, will be released in the next version
      [1.1.0] - 2017-01-26
      Added
      • First version of installer script
      • Menu to send Alerts and/or Notifications to your mirror
      • Menu to update your MagicMirror installation and your modules (through git pull)
      • Menu to change the config.js
        • Modules can be installed, added, removed, configured
        • There will be backups of the five last versions of the config.js in the config folder
        • Some of these parts are hidden behind an “exprimental” warning, do not ignore that warning
      • NOTIFICATION action, see README.md for details
      Changed
      • Menu structure
        • Old “Edit” and “Settings” are now under “Edit view”
      • Smaller font sizes in lists
      Fixed
      • Issues coming from disabled modules since MM version 2.1.0
      [1.0.0] - 2016-10-24
      Added
      • Changelog
      • New buttons in user interface
        • Hide/show all modules
        • Link to MagicMirror² homepage
        • Option to adapt brightness (making the mirror brighter than 100% can be limited to certain modules)
      • Contributing hints
      • Internal versioning of saved config (current version: 1)
      • Added action MODULE_DATA to return module data in JSON format
      Changed
      • Internal timeout for commands increased from 5 to 8 seconds
      • Symbols for display on and off
      • Internal changes in preparation for Magic Mirror version 2.1.0
      R Cr4z33C 2 Replies Last reply Reply Quote 13
        rvdgeer @Jopyth
        @Jopyth I think this is a really cool module! Thank you!
        [EDIT: Nevermind… Wrong thread and I didn’t restart. Works great!]
          Jopyth Moderator @rvdgeer
          @rvdgeer Glad you like it. :)
          By the way I am also looking for new ideas, if anyone wants to a do a certain thing via this interface, I would happy to add it, if it is possible.
          R cowboysdudeC N 3 Replies Last reply Reply Quote 1
          • cruunnerrC Offline
            cruunnerr
            Really nice. I used a physical Button to shutdown the pi before, but this is much more easier. Thank you for creating this cool module ;)
              d3r
              This is awesome. No more commenting modules out when I do not need them. This is way more convenient.
              • Mr.MeeseeksM Offline
                Mr.Meeseeks
                Ideas:
                Perhaps ablity to turn off HDMI ‘sleep’, then maybe also can turn down and up brightness aka CSS white color.
                CAAAAN DOO!👍
                  rvdgeer @Jopyth
                  @Jopyth It would be great to be able to disable a module on startup, so you can enable it later with the remote control. Or even better: have a ‘save settings’ option on the remote control, so you can make the disabled modules stick after a reboot/reload.
                    Jopyth Moderator @Mr.Meeseeks
                    @Mr.Meeseeks You mean like with a PIR sensor? Fiddling with CSS would be possible I think, I will look into that.
                    @rvdgeer good idea I wanted something similar like this too.
                    Mr.MeeseeksM 1 Reply Last reply Reply Quote 0
                    • cowboysdudeC Offline
                      cowboysdude Module Developer @Jopyth
                      @Jopyth said in MMM-Remote-Control:
                      How about the ability to send a message to display on the mirror? It would be funny if someone was standing in front of it and it said Hi and their name LOL Just throwing it out there…
                      • KirAsh4K Offline
                        KirAsh4 Moderator
                        @cowboysdude, evil, just pure evil.
                        Unsuspecting friend visits, friend goes to bathroom, you whip out phone and “text” the mirror … friend comes running out screaming.
                        • 27
                        • 28
                        • 1 / 28
