    [MMM-Remote-Control] Can not access remote control module
    76 Posts 21 Posters 80.0k Views 19 Watching
    • F Offline
      fox
      first of all, thank you for this module.
      I have whitelisted my iPs. But i get:
      Cannot GET /remote.html
      Issues With MMM-WatchDog known?
      https://forum.magicmirror.builders/post/29827
      Useful for PIR-Sensor: https://forum.magicmirror.builders/post/21299
      • O Offline
        ostfilinchen @fox
        @fox Do you have added the whitelistsection to the config?
        • F Offline
          fox
          Yes. I get also the whole screen in browser with
          192.168.188.50:8080
          • O Offline
            ostfilinchen @fox
            @fox can u Post the whitelistsection?
            • F Offline
              fox
              @ostfilinchen
              ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:192.168.188.42", "::ffff:192.168.188.48", "::ffff:192.168.188.35"],
              • O Offline
                ostfilinchen @fox
                @fox i see, that the ip 192.168.188.50 isn’t a Part of the ipwhitelist
                • F Offline
                  fox
                  @ostfilinchen
                  i thought the whitelistened IPs are from the caller devices…
                  this
                   "::ffff:192.168.188.1/24",
                  gives me the whole local network, is that correct?
                  • O Offline
                    ostfilinchen @fox
                    @fox yeah. That’s right.
                    F 1 Reply Last reply Reply Quote 1
                    • F Offline
                      fox @ostfilinchen
                      @ostfilinchen said in MMM-Remote-Control:
                      i solved it. The access rights were the problem:
                      chmod -R 777 MMM-Remote-Control/
                      B 1 Reply Last reply Reply Quote 2
                        Burner911 @fox
                        @fox I also have this issue, but using this line of code did not appear to solve my issue. I assume I run this in the /modules folder? Thank you for your help.
                          Jopyth Moderator @Burner911
                          @Burner911 Have you installed restarted the mirror after installation (i.e. pm2 restart mm)?
                          Edit: Did you install in the correct directory?
                            Burner911 @Jopyth
                            @Jopyth Yes I have it working now! Still not sure why only some modules can be hidden though
                            • mpiresM Offline
                              mpires
                                pepemujica
                                  pepemujica
                                  Hi @fox , where you able to access from other device? A smartphone for example. Because I can access from the browser where the MM is installed, but not from other devices.
                                  My whitelist is empty [ ]
                                  • - Offline
                                    -DUS-
                                    I’m also having issues connecting to the remote module on my PC through Chrome and IE. The page can’t be reached. The module is active and the link to use is shown on my magic mirror.
                                    My IP whitelist which cotains my PC IP:
                                    ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:192.168.0.2"],
                                    I also tried below based on on on the comments in this topic:
                                    cd ~/MagicMirror/modules/
                                    but that just tells me that it can’t access /MagicMirror/modules/, the file or folder doesn’t exist.
                                    Another topic mentioned changing;
                                    address: "localhost",
                                    to;
                                    address: "0.0.0.0",
                                    Should I try that?
                                    Update: I changed to 0.0.0.0. and that I got a responce but it told me my PC is not autorized although my IP is added in the whitelist, so I just removed the whole whitelist for the time being, and now I’m able to acces the remote module.
                                      PaulB
                                      Hi fellow MM-builders,
                                      the same problem occured with my build but instead a 192.168.xxx.xxx I use 10.12.0.135:8080.html
                                      Unfortunately it shows following message:
                                      ‘This device is not allowed to access your mirror.
                                      Please check your config.js or config.js.sample to change this’
                                      My steps to solve this issue were:
                                      1. change ipWhitelist to ipWhitelist:[ ]
                                      2. change ipWhitelist to ipWhitelist: [0.0.0.0]
                                        3.change ipWhitelist to the specific IP adresses of my devices.
                                      Unfortunately, none of this steps solved the error.
                                      Maybe you guys have a tip or trick on how to solve that.
                                      Thank you in advance :)
                                        Mykle1 Project Sponsor Module Developer @PaulB
                                        @PaulB
                                        ipWhitelist: [],
                                        address: "0.0.0.0",
                                          PaulB
                                          Dear @Mykle1,
                                          my config.js file looks like this:
                                          var config = {
                                                  adress: "0.0.0.0",
                                                  port: 8080,
                                                  ipWhitelist: [],
                                                  language: 'de',
                                                  timeFormat: 24,
                                                  units: 'metric',
                                          Unfortunately, my screen went black after I 've changed the config file and rebooted.
                                          Could you make a guess, where the problem is located?
                                            @PaulB said in [MMM-Remote-Control] Can not access remote control module:
                                            adress: “0.0.0.0”,
                                            You spelled address wrong. :-/
                                            • 1 / 4
