    [Remote-Control] Shutdown, Configure and Update your MagicMirror
    274 Posts 78 Posters 946.6k Views 77 Watching
    • K
      KirAsh4 Moderator
      @cowboysdude, evil, just pure evil.
      Unsuspecting friend visits, friend goes to bathroom, you whip out phone and “text” the mirror … friend comes running out screaming.
      • cowboysdudeC
        cowboysdude Module Developer @KirAsh4
        @KirAsh4 said in MMM-Remote-Control:
        Yes but funny none the less LOL
        • K
          KirAsh4 Moderator
          “Hey [NAME], you did not wash your hands.”
          “Turn the damn fan on!”
          cowboysdudeC 1 Reply Last reply Reply Quote 3
          • cowboysdudeC
            LOL
              Mr.Meeseeks @Jopyth
              @Jopyth ya like what the pir sensor does but just as a manual toggle, so you can turn it ‘off’ at night. I currently don’t have pir sensor yet.
              CAAAAN DOO!👍
                Mr.Meeseeks
                I might try to tinker in a config editor and maybe even a command to git clone modules remotely.
                CAAAAN DOO!👍
                  Bangee Module Developer
                  Ok, that’s a nice modul :-)
                  I’ve insert an restart function for the MM app and the ability to turn you monitor on and off:
                  insert in node_helper.js at line 54:
                  				if (query.action === 'RESTART')
                  					res.send({'status': 'success'});
                  					exec('pm2 restart mm', function(error, stdout, stderr){ callback(stdout); });
                  					return;
                  				if (query.action === 'MONITORON')
                  					exec('/opt/vc/bin/tvservice -p', function(error, stdout, stderr){ callback(stdout); });
                  					return;
                  				if (query.action === 'MONITOROFF')
                  					exec('/opt/vc/bin/tvservice -o', function(error, stdout, stderr){ callback(stdout); });
                  					return;
                  in remote.js on line 131:
                      'restart-mm-button': function () {
                          Remote.getWithStatus("action=RESTART");
                      'monitor-on-button': function () {
                          Remote.getWithStatus("action=MONITORON");
                      'monitor-off-button': function () {
                          Remote.getWithStatus("action=MONITOROFF");
                  in remote.html on line 40:
                  <!-- MagicMirror menu -->
                  		<div id="restart-mm-button" class="menu-button power-menu">
                                      <span class="fa fa-recycle" aria-hidden="true"></span>
                                      <span class="text">%%TRANSLATE:RESTARTMM%%</span>
                                  </div>
                  		<div id="monitor-on-button" class="menu-button power-menu">
                                      <span class="fa fa-toggle-on" aria-hidden="true"></span>
                                      <span class="text">%%TRANSLATE:MONITORON%%</span>
                                  </div>
                                  <div id="monitor-off-button" class="menu-button power-menu">
                                      <span class="fa fa-toggle-off" aria-hidden="true"></span>
                                      <span class="text">%%TRANSLATE:MONITOROFF%%</span>
                                  </div>
                  and the translations/en.json and de.json on line 8 ff:
                      "RESTARTMM": "Restart MagicMirror2",
                      "MONITORON": "Turn monitor ON",
                      "MONITOROFF": "Turn monitor OFF",
                      "RESTARTMM": "Starte MagicMirror2 neu",
                      "MONITORON": "Bildschirm einschalten",
                      "MONITOROFF": "Bildschirm ausschalten",
                  I think thats it.
                  The evil this is a must for my mirror… so thats next. I think we can do this like the IFTTT module does it.
                  Install modules remotly will be the next big thing… :-)
                  J M 2 Replies Last reply Reply Quote 2
                    Jopyth Moderator @Bangee
                    @Bangee can you make a pull request also? Would be nice.
                    Edit: Otherwise I will add it to the base module, with your permission, when I get back from vacation.
                      Jopyth Moderator @cowboysdude
                      @cowboysdude This is what I am doing with my Trello module basically. :)
                        @Jopyth I never did this before but I’ll try ;-)
                          ceerix
                          Hello everyone,
                          actually i’m building my first Magic Mirror and i have installed the Remote Control Modul which works very well and i also have implemented the changes from Bangee. Everything works fine.
                          Now i want to use this modul for interacting with my home automation systen “homematic”. Therefore i need to call the URLs directly.
                          Can anybody help me which i URL i have to call? I already have tried
                          http://192.168.xxx.xxx:8080/remote.html?action=RESTART
                          but it doesnt work :-(
                          Thanks in advance for your help :)
                            @ceerix can you try this:
                            http://192.168.XXX.XXX:8080/remote?action=RESTART
                            @Jopyth the pull request is online. :-)
                            https://github.com/Bangee44/MMM-Remote-Control
                              Jopyth Moderator @ceerix
                              @ceerix How are you going to interact? With custom notifications between the modules? Or are you connecting this differently?
                              I am asking because I was thinking, if it is possible to give other modules a simple way of hooking up to my module, and how this could happen. So a first example, on how you would like to do it, might be a good starting point.
                                ceerix
                                @Bangee thank you for your help this works! :)
                                @Jopyth i simply call the URL for the action which i want. For example shutdown the Raspberry when i’m leaving the house.
                                A example is the link which Bangee have written:
                                If you need any further information i will help you :)
                                  Mr.Meeseeks @Bangee
                                  @Bangee @Jopyth thanks again, this is great!
                                  CAAAAN DOO!👍
                                    @ceerix Ok, I see. Thanks!
                                      Jopyth Moderator
                                      The module has received a medium update, see the new version on Github.
                                      Changes:
                                      • Added: Save as default, which saves the hidden/shown status of your modules (Note: If you change your config, the settings will most likely not load correctly, you might have to change and save them again.)
                                      • Added: Restart MagicMirror application and switching display on and off, thanks to @Bangee
                                      • Changed: status indicator appears on top right, instead of the bottom
                                      • Updated: fixed-width icons, text should be more aligned now
                                      • Updated: error sign will show (error will appear in server log), if a command fails, e.g. no sudo rights
                                      • Fixed: style error, which most likely made the remote control look completely different from the preview for anyone except me
                                        d3r
                                        New update is sick. Really like the turn display on/off feature.
                                        • cowboysdudeC
                                          Another module that should be in the core :) Man this mirror is growing Thanks to great people!
                                          Thanks @Jopyth
                                            ceerix
                                            I had an idea in the morning. Would it be possible to develop a new menu in this modul for changing the place of a displayed modul? For example moving it from the top to the middle of the screen with a button?
                                            Do you understand what i mean? :)
                                            • 13
                                            • 14
                                            • 1 / 14
