    [Remote-Control] Shutdown, Configure and Update your MagicMirror
    274 Posts 78 Posters 933.6k Views 77 Watching
      done @Jopyth
      @Jopyth I think I don’t understand the difference? :D
      Or you’re talking about the default sleep time that is already set at start up of the pi?
      So that, no matter what you do, you set a (default) timer of i. e. 15 minutes when the hdmi switches off.
        PaulB
        @strawberry-3-141 @Jopyth Thank you very much for your help.
        My error was following one:
        “https://192.168 …”
        Now, I ve fixed it in “http://192.168 …”
        –> It’s the small things that matter, I guess :D
        Thanks a lot.
        @Jopyth I love it :-) Well done!
          rvdgeer @Jopyth
          @Jopyth Amazing work so far!
          Can’t wait for the ‘finished’ product (read: next major version).
            compoti
            The remote-control works really great, thank you very much for this module!
              Mr.Meeseeks
              Holy smokes @Jopyth you refactored a lot, it’s taking me some time to merge my changes in
              CAAAAN DOO!👍
                Jopyth Moderator @Jopyth
                @Mr.Meeseeks Even though I did not make that properly clear, but that was my intention, behind asking you to make the pull request early, sorry about that. :/ I can help with the merging, though, let me know.
                @Jopyth said in MMM-Remote-Control:
                @Mr.Meeseeks Also if you think you are at a stage where we can work together, feel free to make the pull request early, and I will have a look and see if I can help.
                Otherwise I will concentrate on other stuff, which you have not already implemented.
                  Jopyth Moderator
                  If anyone is interested in helping to test the next major (and future) versions of the module, I am searching for beta testers. Please note that the version may still contain bugs, and thus involves an (unlikely) risk of your Raspberry Pi explo… I mean you having to fix some stuff from the command line and your config.js by yourself.
                  • jdfraserJ Offline
                    jdfraser
                    Thanks so much for creating this module! I have just set up my first magic mirror and started poking around with it. I am going to use my install as a photoframe.
                    I love the show / hide ability in your module especially being able to call it from other modules. When I get to playing around with voice control / face recognition I can see that this would be very useful.
                    I do have a request for this module though, it would be great if we could also control the ‘dim level’ of other modules as well as hiding them. I am specifically thinking of the Random photo module, I would like to be able to dim the currently displayed photo so that the other modules can been seen.
                    If you don’t oppose this added feature and could find the time to implement it I would very much appreciate it.
                    Cheers from Vancouver, Canada!
                      Mr.Meeseeks
                      @Jopyth would it be ok to add module specific functionality/backend only if that module was installed? Thoughts?
                      CAAAAN DOO!👍
                        Jopyth Moderator @Mr.Meeseeks
                        @Mr.Meeseeks What do you mean? Like offer alert sending in the menu only if an alert module is running? Are there any other things which depend on installed modules?
                          Mr.Meeseeks @Jopyth
                          @Jopyth like support a backend/menu for say a gallery module, but only if it’s installed. It would be very beneficial but might add bloat and future compatibility issues. Alert is fine because it’s a default.
                          CAAAAN DOO!👍
                            @Mr.Meeseeks Its installed by default, but not neccesarily in the config and on the mirror. :)
                            That is something I also wanted, but I was not clear on the specification of it. My first draft.
                            The actions must definitely be offered by the modules themselves.
                              Mr.Meeseeks
                              Right, ya, or have yet another module directory inside remote to inject menu definitions node/remote/module code for module’s remote backend, like magic mirror… Damn getting complex, ha. But your right maybe for now needs to hide alert menu if not installed.
                              CAAAAN DOO!👍
                                Manmachine
                                Hi Jopyth,
                                First, thanks for a great module that I have a lot of benefit of. Super well done!
                                However, I have an idea that I would inquire if you could possibly help with.
                                It concerns that I have a Smart Home Controller (Zipato Tile) where it is possible to send http get / post / put / delete.
                                At this sitting blah. Z-Wave PIR Sensor, which is in the same room as my Magic Mirror, which through rule in Zipato Tile could send http post to your module and for example, “Turn Monitor ON”
                                Will this be possible? If so, how would the syntax look like? (I’m definitely not strong in coding javascript)
                                I would think it must be something along the: http://[Magic Mirror IP]/remote?Action= MONITORON
                                Or am I way off?
                                Thanks in advance
                                • strawberry 3.141S Offline
                                  strawberry 3.141 Project Sponsor Module Developer @Manmachine
                                  @Manmachine action should be lowercase and dont forget to add the port specified in the config behind the ip
                                  https://github.com/Jopyth/MMM-Remote-Control#examples
                                    Manmachine @strawberry 3.141
                                    Super! thanks i’ll give it a change.
                                    Will return soon with an update within the next few days =)
                                      @strawberry-3.141
                                      DOH! - it has indeed been in the documentation all the time! (How the heck could I miss it?)
                                      there I sat and tried to find out how the code worked!
                                      how stupid of me!
                                      • L Offline
                                        lolobyte
                                        Hi, that’s great what u have done.
                                        Why it doesn’t work on PC Browser? http://192.168.xxx.xx:8080/
                                        On my HDMI monitor all thinks ok.
                                          Jopyth Moderator @lolobyte
                                          @lolobyte It should work with any browser. Did you replace the 192.168.xxx.xxx with the IP of your raspberry pi? If you set a position for the module, you should also be able to see the URL on your mirror, for example the following should show the URL to the remote inf the bottom left:
                                              module: 'MMM-Remote-Control',
                                              position: 'bottom_left'
                                          • L Offline
                                            lolobyte @Jopyth
                                            @Jopyth
                                            OK, now it works. Was a browser problem with Maxthon. Thank u, but the modules MagicMirror-Netatmo-Module and MMM-Fuel are not shown in the Browser!
                                            At the monitor the are visible.
                                            • 13
                                            • 14
                                            • 5 / 14
