    Bathroom Magic Mirror Cabinet "Alibert" - MagicAlibert
    19 Posts 10 Posters 11.7k Views 10 Watching
    • spitzlbergerjS
      spitzlbergerj Project Sponsor Module Developer
      and again I have finished a bathroom MagicMirror. This time it should be a mirror cabinet by special request, in Germany one says often “Alibert” to this kind of bathroom mirror. And so the MagicAlibert was born.
      The principle of my MagicMirror you can see in this post.
      You can also find the sources for mirror glass and accessories there.
      Exterieur exterieur
      Interieurinterieur
      Parts, milled
      Parts, milled
      Parts, Flat dowel
      Parts, Flat dowel
      Parts, system 32 holes
      Hinge holes
      Hinge holes
      Hinges nearly closed
      Hings open
      Hings open
      Shell clamped
      Shell clamped
      Shell finished
      Shell finished
      With back wall
      With back wall
      wall mounts
      wall mounts
      Hole for cable
      Hole for cable
      Body with doors
      Body with doors
      right door with cutout for screen
      left door without cutout
      back plane for right door
      doors closed
      doors closed
      after painting
      after painting
      hinge
      hinge
      3D prints for left door - bracket glass insert - bracket cross bar
      Screen built in
      Screen built in
      all technic installed
      Screen built in
      Screen built in
      mounted back panel right door
      Handles and bracket mounted to hold up the heavy doors
      left door open
      left door open
      right door open
      right door open
      finished - ready to moun
      finished - ready to mount
      I have used:
      • Raspberry pi 3
      • Beech wood from the hardware store
      • Aluminium composite panel (ACP) with cutout (https://www.plattenzuschnitt24.de/ - german: Alu Dibond Platte)
      • Spy mirror (https://www.glas-star.de/spionspiegelnachmass/chrome-spy-spiegel/)
      • Silicone (PCI Silcofern S) Color: black (Important! Never use transparent silicone. Otherwise you will see it and regret it!)
      • Screen (HP 24w (1CA86AA) 60,45 cm (23,8 Zoll) monitor (IPS, Full HD, HDMI)
      • Radar motion detector (Amazon Haljia 5 RCWL-0516)
      You find a 3D model here
      If you want to know more, then ask ;-)
      Regards
      Josef
      Regards
      Josef
      http://www.spitzlberger.de/smartmirror, https://github.com/spitzlbergerj/MMM-TeslaLogger, https://github.com/spitzlbergerj/CaravanPi, https://www.la-gondola-barocca.de
      S cowboysdudeC N O 4 Replies Last reply
      Reply Quote 12
        sdetweil @spitzlbergerj
        @spitzlbergerj really awesome!!
        spitzlbergerjS 1 Reply Last reply
        • Z
          Zoltan
          I really like the two door idea
          Really neat woodwork
          • O
            oli28
            I love the Bring! App, just had to google for it :D
            • cowboysdudeC
              cowboysdude Module Developer @spitzlbergerj
              @spitzlbergerj this is by far the best bathroom mirror I have seen!! Excellent job and tutorial!
              • spitzlbergerjS
                spitzlbergerj Project Sponsor Module Developer @sdetweil
                @sdetweil, @Zoltan, @cowboysdude Thanks for your compliments
                Regards
                Josef
                • N
                  nickthebeer @spitzlbergerj
                  @spitzlbergerj that’s is really cool, I might make one of these for home when we change our bathroom suite. What’s the toilet roll etc on the display for?
                  • spitzlbergerjS
                    spitzlbergerj Project Sponsor Module Developer @nickthebeer
                    @nickthebeer
                    Hi, thats the module for the bring list app: https://github.com/rseidt/MMM-bringList
                    Regards
                    Josef
                      Binog
                      Hey, Great Work !
                      Can You post a picture from the back !?
                      And maybe a picture from the interior (counted from the last one, a picture between 4 and 5 so how You mounted the pi, etc…)
                      Thx !
                      • spitzlbergerjS
                        spitzlbergerj Project Sponsor Module Developer @Binog
                        Hi @binog ,
                        here is a picture of the back
                        back
                        The wiring still has to be done. This is only the temporary solution. The cords you can see on the photo are currently used for stabilization, because the MagicAlibert is very “door-heavy”.
                        I can only provide a picture of the mounted Raspberry Pi later, when I have removed the back of the door again.
                        Regards
                        Josef
                        B 1 Reply Last reply
                          Binog @spitzlbergerj
                          @spitzlbergerj
                          thx !!
                          • O
                            OberfragGER @spitzlbergerj
                            @spitzlbergerj Great work and finish.
                            Where did u attach the Haljia 5 RCWL-0516) an which Modul are u using for that sensor?
                            • spitzlbergerjS
                              spitzlbergerj Project Sponsor Module Developer @OberfragGER
                              @OberfragGER
                              Thanks for the compliments!
                              I will put the radar sensor outside the body either on top or on the bottom. I have printed a white housing for it with the 3D printer, which I can mount accordingly. Let’s see where it responds better
                              Regards
                              Josef
                                cyberphox
                                That’s next level stuff right there! Great job!
                                • spitzlbergerjS
                                  spitzlbergerj Project Sponsor Module Developer @cyberphox
                                  @cyberphox Thanks for the compliments!
                                  Regards
                                  Josef
                                  • spitzlbergerjS
                                    spitzlbergerj Project Sponsor Module Developer @spitzlbergerj
                                    Hi everybody,
                                    and here are the photos of the interior of the right door:
                                    The screen is already fixed through the cutout of the Alu Dibond plate. With a little tape it is actually already fixed enough. For safety I have attached 4 angles, which press it additionally in. The Raspberry is mounted on a 3D printed plate. The cable routing is done via damp room cable boxes.
                                    right door - interieur
                                    Regards
                                    Josef
                                    • spitzlbergerjS
                                      Hi all,
                                      you could find a 3D model here
                                      Regards
                                      Josef
                                      Regards
                                      Josef
                                      • L
                                        lxne Project Sponsor
                                        Awesome work!
                                        Are the mirrors just glued onto the doors?
                                        And did you use the chrome spy for both sides?
                                        Best wishes,
                                        Alex (Lower Bavaria)
                                        • spitzlbergerjS
                                          spitzlbergerj Project Sponsor Module Developer @lxne
                                          @lxne Thanks!
                                          yes they are just glued
                                          you see my method of glueing better in this post https://forum.magicmirror.builders/topic/9154/bathroom-magic-mirror
                                          No, I don’t use chrome spy, I bought the mirrors here https://www.glas-star.de/spionspiegelnachmass/chrome-spy-spiegel/
                                          Regards
                                          Josef
