    MMM-MotionEye - surveillance video stream on your mirror!
    70 Posts 15 Posters 101.9k Views 15 Watching
    • L
      lolobyte @Cato
      @Cato
      Hi, that’s the info of help.
      Downloaded from
      https://www.dropbox.com/s/xdfcxm5hu71s97d/motion-mmal.tar.gz
      pi@raspi3-MM2:~ $ motion -h
      motion Version mmaltest, Copyright 2000-2005 Jeroen Vreeken/Folkert van Heusden/Kenneth Lavrsen
      usage: motion [options]
      Possible options:
      -n Run in non-daemon mode.
      -s Run in setup mode.
      -c config Full path and filename of config file.
      -d level Log level (1-9) (EMR, ALR, CRT, ERR, WRN, NTC, ERR, DBG, ALL). default: 6 / NTC.
      -k type Type of log (COR, STR, ENC, NET, DBL, EVT, TRK, VID, ALL). default: ALL.
      -p process_id_file Full path and filename of process id file (pid file).
      -l log file Full path and filename of log file.
      -m Disable motion detection at startup.
      -h Show this screen.
      Motion is configured using a config file only. If none is supplied,
      it will read motion.conf from current directory, ~/.motion or /etc.
      • C
        Cato Module Developer @lolobyte
        @lolobyte You will have to install motionEyeOS or motionEye to use this module. Please read pre-requisites.
        • L
          lolobyte @Cato
          @Cato
          Thank you for your answer.
          I just tried MotionEyeOS before i went to Motion.
          In my eyes it wasn’t configurable with my desired functionality.
          I just hoped there is a possibility to implement foreign streams.
          • C
            @lolobyte As long as the software can provide a “motion jpeg”-stream, it can be supported.
            Basically, you can test it your selv by making a local .html-file with <img src="xxxxx" />
            • E
              emos
              For some reason i just get a “broken” picture icon, and if i try to open http://MotionEyeIP/motioneye/1 the site just says:
              {"error": "not found"}
              I have disable the password for the ‘Surveillance Username’ so no login is required.
              I know the cam is available and motioneyos is working as normal. If i open http://192.168.1.200:8080/picture/1/current/ in my browser i can see the last snapshot, but not doing me any good…
              Any suggestion?
              	module: 'MMM-MotionEye',
              	position: 'bottom_right',
              		url: "http://192.168.1.200:8080/motioneye/1",
              		debug: false
              S C 2 Replies Last reply Reply Quote 0
                shashank @emos
                @emos hi, try changing the port (8080) in MM or camera , both MM and camera with 8080 will not work
                • C
                  Cato Module Developer @emos
                  @emos The URL you are using in your config seems to be the “web hook”-URL that you have to configure inside MotionEye if you want to automatically show video stream when motion is detected.
                  The URL should be configured like this (from documentation): Video Streaming URL. You find it in Motion Eye in the Video Streaming Section under Usefull URLs by by clicking the Streaming URL link. It should look something like this: http://motioneye:8081 (probably an IP instead of hostname).
                  • E
                    emos
                    reinstalled motioneye on my other r.pi and now im able to view a stream from http://MotionEyeOS:8081, but only from cam 1.
                    With http://MotionEyeOS:8081/motioneye/2 i still just get cam 1. Get the feeling im not understanding something.
                    			position: 'lower_third',
                    				url: "http://192.168.1.200:8081/motioneye/2",
                    				autoHide: false,
                    				debug: false
                    • SnilleS
                      Snille Module Developer
                      Hi @emos I’m also using different cameras from the same MotionEye install.
                      I have my cameras set on different ports like this.
                      http://MotionEyeOS:8082
                      http://MotionEyeOS:8083
                      I think that the default way…
                      Then you have the motiontrigger url like this in MotionEyeOS/Camera (for example):
                      http://MagicMirror:8080/motioneye/1
                      http://MagicMirror:8080/motioneye/2
                      http://MagicMirror:8080/motioneye/3
                      That’s it. :)
                      If you cant find it, make it and share it
                      MMM-homeassistant-sensors,MMM-Modulebar,MMM-Profilepicture,MMM-Videoplayer,MMM-TautulliLatest
                      E 1 Reply Last reply Reply Quote -1
                      • E
                        emos @Snille
                        @Snille
                        My second camera is a remote camera, not a local one on my LAN.
                        Also http://MagicMirror:8080/motioneye/1 and http://MagicMirror:8080/motioneye/2 is the same livestream. changing from motioneye/1 to motioneye/2 does nothing.
                        SnilleS 1 Reply Last reply Reply Quote 0
                        • SnilleS
                          Snille Module Developer @emos
                          @emos you need to add it in to MotionEyeOS. So it knows about it. I have 3 cameras in the same way. You can add any “network-camera”.
                          rtsp://yourcam:port/whatever-format in the “add” dialog in MotionEyeOS. :)
                          • E
                            emos @Snille
                            @Snille
                            Camera is added to MotionEye
                            Under MotionEyeOS Settings>Video Device>Camera ID the ID is 1 and 2 :/
                            • SnilleS
                              @emos Here is one of mine: 0_1486731274088_Cam01.png
                              • E
                                emos @Snille
                                Only thing thats not identical is under video streaming > Useful URLs.
                                As you can see that under cam ID 2 (left one) is that streaming URL are missing… don’t know if this is a deal breaker or how to change it… :/
                                • SnilleS
                                  @emos Hmm… I wounder if it is because you use an http link? Can you try to change it to an rtsp link?
                                  • E
                                    emos
                                    can i use rtsp for another MotionEye cam? Does it even have rtsp? :o
                                    • SnilleS
                                      @emos Nah, you only need to use rtsp for the “network” cameras. The right one you have looks like a “locally” connected camera?
                                      • E
                                        emos
                                        the right one is local, correct
                                        • W
                                          Woody
                                          Hi Cato, thanks for this Module, I installed it and it works like a charm. One thing I like to ask you is the positioning of the module. I tried to arrange the module appearence pixel-precise with the help of the custom.ccs but was not successful. I added this to the custom.css and deleted the position definition in the config.js. Any idea what went wrong here :question: :question: :question:
                                          .MMM-MotionEye {
                                           left : 700px;
                                           top: 1500px;
                                          • C
                                            I’m really not sure since I’m not very deep into CSS. I would have to test it this weekend. By schedule is pretty tight…
                                            I assume you have a very large screen since you’re putting Motion-Eye 1500 pixels down on it?!? :smiley:
                                            • 2 / 4
