    MMM-RAIN-MAP (new: version 2.x)
    192 Posts 38 Posters 300.4k Views 41 Watching
    • JalibuJ Offline
      Jalibu Module Developer @gabrielm9
      Hi @gabrielm9 ,
      contribution is always welcome :-)
      You have to compile the Typescript sources using npm run build.
      Let me know, if you have problems. I‘m waiting for your PR
      • JalibuJ Offline
        Hi @gabrielm9,
        the latest version 2.5.x supports different color schemes now.
        swvalentiS G 2 Replies Last reply Reply Quote 0
        • swvalentiS Offline
          swvalenti Project Sponsor @Jalibu
          Outstanding work fellas
          • G Offline
            gabrielm9 Project Sponsor @Jalibu
            Hi @jalibu,
            Thanks very much! I was about to spend time figuring it out how to variabalize the code but I’ve learned from what you did. I would have taken me a week to figure it out :slightly_smiling_face:. The wife thanks you as well.
            • F Offline
              fmarcu @bhepler
              @bhepler
              osmMapUrl: "https://cartodb-basemaps-{s}.global.ssl.fastly.net/dark_all/{z}/{x}/{y}.png"
              I’m using the dark map referenced above on a black background but every time the module changes zoom level it fills with a white background until the new map tiles populate. It’s worst when zooming out,
              Does anyone know if it there is a parameter I can change so the blank tiles between zoom levels stay black?
              This is a minor annoyance with an otherwise great module.
              Thank you!
              JalibuJ 1 Reply Last reply Reply Quote 0
              • JalibuJ Offline
                Jalibu Module Developer @fmarcu
                @fmarcu said in MMM-RAIN-MAP (new: version 2.x):
                try to add this to your custom.css
                .MMM-RAIN-MAP .leaflet-container {
                  background: #000;
                F karsten13K 2 Replies Last reply Reply Quote 0
                • F Offline
                  fmarcu @Jalibu
                  @jalibu said in MMM-RAIN-MAP (new: version 2.x):
                    background: #000;
                  That worked! Thank you!
                  • karsten13K Online
                    karsten13 @Jalibu
                    @jalibu
                    this is the current rain situation and I don’t understand the differences, first picture your module, second one https://www.wetteronline.de/regenradar .
                    And the second one is reality …
                    • JalibuJ Offline
                      Jalibu Module Developer @karsten13
                      @karsten13 Unfortunately, I can’t tell you that. I am only responsible for the display layer, not for the weather data :-)
                      The radar layers come from the Rainviewer API, which I have actually had quite good experiences with in the past.
                      Is it the usual case on your mirror that the displayed radar images do not match the reality?
                      What I can see is that RegenRadar.de and RainViewer have different scales. With RainViewer it needs a much higher degree of cloudiness to be displayed on the map.
                      • karsten13K Online
                        karsten13 @Jalibu
                        @jalibu
                        Unfortunately, I can’t tell you that. I am only responsible for the display layer, not for the weather data 🙂
                        I’m aware of this …
                        saw such differences this week the first time
                        will oberve this but the differences are heavy and AFAIS not only explainable with the different scales. Meanwhile I was already asking myself if the rain layer is showing a total different location …
                        JalibuJ 1 Reply Last reply Reply Quote 1
                        • JalibuJ Offline
                          @karsten13 let me know your findings
                          • JalibuJ Offline
                            A few days ago, Openstreepmap obviously made some changes with their tile servers. They seem to block requests now, when the requests come from Electron applications. This is the case in most MagicMirror installations. As a consequence, MMM-RAIN-MAP does not show map tiles anymore.
                            I suspect, that also other modules are effected.
                            One possible fix is using another tile server for MMM-RAIN-MAP. One that still works at the moment, is the German fork “https://a.tile.openstreetmap.de/${z}/${x}/${y}.png”.
                            I will adjust the module soon, to use this tile server as a default.
                            You can also change the tile server by setting this property in the module config:
                              mapUrl: "https://a.tile.openstreetmap.de/${z}/${x}/${y}.png"
                            T plainbrokeP 2 Replies Last reply Reply Quote 1
                            • T Offline
                              trlynch @Jalibu
                              @jalibu
                              Woohoo!!
                              Thank you for posting this change. I was going nuts trying to figure out why my radar map became a white background.
                              Bummer the .org site is blocking connections.
                              I’m curious, is there a way to make the radar images more transparent? Here in Ohio we get a lot of deep greens and blues so they hide the map entirely.
                              Playing with rpi's and now weather fun.
                              • karsten13K karsten13 referenced this topic on
                              • JalibuJ Offline
                                the german tileserver fork is default now
                                • P Offline
                                  pminich @Jalibu
                                  @Jalibu I am getting a message that MMM-RAIN-MAP is 2 commits behind but I can’t see to update it. I have run NPM Update from inside the directory to no result. Is there a different process?
                                    sdetweil @pminich
                                    @pminich did u do the git pull in the module directory to get the latest code?
                                    • P Offline
                                      pminich @sdetweil
                                      @sdetweil All set, thanks. Still learning my way around npm, git, etc…
                                      • O Offline
                                        ossman
                                        Seems like we’re in the same Boat! Weirdly enough, it hasn’t rained today. I’ll have an eye on it once it starts again!
                                        • K Offline
                                          kevsfastz
                                          Hello,
                                          Is it possible to add a layer for tropical storm/hurricane tracks similar to how NHC does with their ‘interactive map’?
                                          https://www.nhc.noaa.gov/refresh/graphics_at1+shtml/122110.shtml?gm_track#contents
                                          • plainbrokeP Offline
                                            plainbroke @Jalibu
                                            @Jalibu said in MMM-RAIN-MAP (new: version 2.x):
                                            How do I go about getting that for the usa in particular kansas.?
                                            • 6
                                            • 7
                                            • 8
                                            • 9
                                            • 10
                                            • 8 / 10
