    MMM-Worldclock
    39 Posts 9 Posters 23.0k Views 9 Watching
      MacG @SoleLo
      @solelo Actually, no. For completeness here are my settings from config.js:
      			module: 'MMM-Worldclock',
      			position: 'top_left', // This can be any of the regions, best in top_left or top_right regions
      				timeFormat: 'HH:mm', //Global time format, as defined in moment.js format()
      				style: 'top', // Which way do you want the flag and description from the clock? choices are 'top', 'left','right','bottom'
      				offsetTimezone: null, // Timezone you want to show the difference from. null, "", or omitted from config will be UTC.
      				clocks: [
      						title: "Weltzeit",
      						timezone: "UTC",
      						// timeFormat: "HH:mm MM/DD", // Time format override.
      						// altflag: "world.png" // if you'd like a flag from a file on your mirror device.
      						title: "Vancouver", // Too long of a title could cause bad text align.
      						timezone: "America/Vancouver",
      						flag: "ca", // If you'd like a flag from the standard library
      						title: "Boca Chica", // Too long of a title could cause bad text align.
      						timezone: "America/Chicago", //When omitted, Local time will be displayed.
      						flag: "us", // If you'd like a flag from the standard library
      						title: "Sydney", // Too long of a title could cause bad text align.
      						timezone: "Australia/Sydney",
      						flag: "au", // If you'd like a flag from the standard library
      Did you restart MM or do a reload (Ctrl-R)?
        SoleLo @MacG
        I added your custom css but the title is showing overlapped and I have it as style left, should I change it to top like yours?
          MacG @SoleLo
          @solelo Adjust the width to 200px
           .MMM-Worldclock .world {
                 width: 200px;
          The module may also have an alignment problem on the right side. Further customization of custom.css may be required.
            SoleLo @MacG
            @macg Ok thanks I’ll mess around with it some more and see if I can get it customized. I figured it was simple as adding your custom css snippet in but I guess not
            M S 2 Replies Last reply Reply Quote 0
              MacG @SoleLo
              @solelo Just try to set the width higher and higher, eventually nothing will overlap anymore. But it will probably be quite wide, with the cities next to the time. Maybe that’s why style: ‘top’ is the better choice.
                sdetweil @SoleLo
                @solelo see this
                https://forum.magicmirror.builders/topic/14862/help-with-a-couple-css-issues?_=1632064035932
                u can change the styles livee and then save it to custom.css…
                note that you can doc the dev window at the bottom too, using the 3 dot menu next to the X to close the dev window
                  MacG
                  A supplement to the development tools. When you open it, you can select “Sources” and pause script execution with the “pause button” or F8 in the lower third. This makes it easier to get through all the style classes, which otherwise update every second.
                  • goldyfruitG Offline
                    goldyfruit Project Sponsor
                    I used to install the original woldclock module, just switched to this one and it worked out of the box.
                    Thanks for the work. :clapping_hands:
                    Build smart things with magic and love! | https://smartgic.io
                      SymmetriC
                      How do I center horizontally at the top of the screen instead of left?
                        sdetweil @SymmetriC
                        @SymmetriC put it in the top_center position
                        BKeyportB S 2 Replies Last reply Reply Quote 0
                        • BKeyportB Offline
                          @sdetweil or top_bar
                            SymmetriC @sdetweil
                            @sdetweil Thank you! That worked and the solution was easier than I thought! lol
                              JohnGalt
                              @BKeyport, @ulrichwisser and all: Please let me know if the following questions would be better served under a new topic, but since my issues originated with this older module, and the new module shares the same name I thought it appropriate to post under this topic…
                              Issue: the old module is no longer supported by the developer, who suggests using a newer module which uses the same module name. After cloning the new module, the instructions call for doing an ‘npm ci’ command, which fails due to a lack of an existing package-lock,json file.
                              Question: Is there something different I should be doing, o si this something the developer needs to fix?
                              Old module: https://github.com/BKeyport/MMM-Worldclock
                              New module: https://github.com/ulrichwisser/MMM-Worldclock
                              Error Message:
                              pi@mirror1:~/MagicMirror/modules $ cd MMM-Worldclock
                              pi@mirror1:~/MagicMirror/modules/MMM-Worldclock $ npm ci
                              npm ERR! code EUSAGE
                              npm ERR!
                              npm ERR! The `npm ci` command can only install with an existing package-lock.json or
                              npm ERR! npm-shrinkwrap.json with lockfileVersion >= 1. Run an install with npm@5 or
                              npm ERR! later to generate a package-lock.json file, then try again.
                              npm ERR!
                              npm ERR! Clean install a project
                              npm ERR!
                              npm ERR! Usage:
                              npm ERR! npm ci
                              npm ERR!
                              npm ERR! Options:
                              npm ERR! [--install-strategy <hoisted|nested|shallow|linked>] [--legacy-bundling]
                              npm ERR! [--global-style] [--omit <dev|optional|peer> [--omit <dev|optional|peer> ...]]
                              npm ERR! [--strict-peer-deps] [--foreground-scripts] [--ignore-scripts] [--no-audit]
                              npm ERR! [--no-bin-links] [--no-fund] [--dry-run]
                              npm ERR! [-w|--workspace <workspace-name> [-w|--workspace <workspace-name> ...]]
                              npm ERR! [-ws|--workspaces] [--include-workspace-root] [--install-links]
                              npm ERR!
                              npm ERR! aliases: clean-install, ic, install-clean, isntall-clean
                              npm ERR!
                              npm ERR! Run "npm help ci" for more info
                              npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2025-08-05T17_16_59_150Z-debug-0.log
                                sdetweil @JohnGalt
                                @JohnGalt npm install then
                                  JohnGalt @sdetweil
                                  @sdetweil – That’s what I thought. Just did that and it’s working now…
                                  Thanks, as always!
                                  • BKeyportB Offline
                                    BKeyport Module Developer @JohnGalt
                                    My version of the module developed a fatal bug that I couldn’t get rid of… The best move was to shut it down.
                                      JohnGalt @BKeyport
                                      @BKeyport – Sorry to hear that, but thanks for the module while you maintained it.
                                      And a big thanks for directing us to another module, and not just leaving it hanging out there!
                                      • UncleRogerU Offline
                                        UncleRoger
                                        @BKeyport
                                        Was the altflag option something that was related to the fatal bug in your version? If not, do you think it’s something that could be added to the latest one?
                                        • BKeyportB Offline
                                          BKeyport Module Developer @UncleRoger
                                          @UncleRoger No, it wasn’t that. I forgot about that code. I might go back in and grab it and offer it to the other version once updated.
