    MMM-aviationwx (Aviation weather)
    111 Posts 12 Posters 145.8k Views 11 Watching
      stephenmelody
      @allebone - what colour scheme do you use for IFR/VFR/MVFR/LIFR? Personally I prefer the alternative one that I have called out above.
      @Mykle1 - no problem, always here to make life harder :-D
      Here’s another option that might be of interest, as it’s JSON format…
      https://www.icao.int/safety/iStars/Pages/API-Data-Service.aspx
        stephenmelody
        @allebone @Mykle1
        This would give you the NOTAM information…
        https://www.npmjs.com/package/notams
        METAR / TAF:
        https://www.npmjs.com/package/metar-taf
        https://www.npmjs.com/package/metar-js
        Don’t know if they help…?
          Mykle1 Project Sponsor Module Developer @stephenmelody
          @stephenmelody said in MMM-aviationwx (Aviation weather):
          Alternative: VFR-Green MVFR-Blue IFR-Red LIFR-Magenta Unknown-Grey
          Would the text coloured per the rules work the same as a coloured circle? Yes - although a circle would be better for screen real estate I would imagine…
          Ok, I’ve coded the “Alterative” color scheme just now, as you’ve described it, using generic colors. You will get the corresponding colored circle depending on the Flight Rule. What I would like from you are HEX color codes for those five colors that work best against the black background. For instance, you may want a lighter blue as the generic blue is a little hard to see. Agreed?
          • cowboysdudeC Offline
            cowboysdude Module Developer
            I would like #FCDFFF, #FAAFBA, #E45E9D, #FFFF00 and #87F717
              stephenmelody
              Is it in a CSS file? That way I’m guessing people could self-configure?
              Here’s what the original module is using and it looks like the below.
              .vfr {
                color: green;
              .mvfr {
                color: blue;
              .ifr {
                color: red;
              .lifr {
                color: #f0f;
              Blue looks ok through my glass, so I don’t see any issue with that.
              alt text
                Mixing color names and hex colors…bad format. I’d stick with hex and people can still change them
                  @stephenmelody
                  What are the last 2 entries on each line
                  10/-1 and (20:51)
                    stephenmelody
                    10 degrees C temperature / -1 degrees C dew point (time of report)
                      cowboysdude Module Developer @Mykle1
                      @Mykle1 said in MMM-aviationwx (Aviation weather):
                      @stephenmelody
                      10/-1 and (20:51)
                      Red and pink LOL
                        You would like that the same? Delete or move Altimeter?
                          Mykle1 Project Sponsor Module Developer @cowboysdude
                          @cowboysdude said in MMM-aviationwx (Aviation weather):
                          Red and pink LOL
                          Hot pink? :-)
                            stephenmelody
                            the format on that image is:
                            Wind direction @ wind speed: 220@05kt
                            Visibility: 10SM 10 statute miles
                            Sky Coverage: OVC - overcast, BKN - broken etc…
                            Cloud base: 150(00)ft
                            Temp: 10 degrees C
                            Dewpoint: -1 degrees C
                            Time of the report in 24 hour clock: 20:51
                            I’d say (personal opinion) that the pressure/altimeter setting isn’t that important. I’d prefer to keep the additional information, if you look at FDY and TBR above, they have:
                            -RA which is showers of rain
                            BR - which is fog (or haze, I can’t remember… 70% sure it’s fog, either way you can’t see through it well)
                            That to me is more important that the altimeter setting.
                            I can look for other examples if that would help?
                            Mykle1M 2 Replies Last reply Reply Quote 0
                              Nope, that’s good for now
                                @stephenmelody
                                How would I denote visibility if this is the data ?
                                Visibility:1500
                                Simply 1500? v1500? vis? other?
                                  stephenmelody
                                  Do you have an example airport you’re getting that from? Is it outside of the US where viz is usually XXSM?
                                    @stephenmelody
                                    https://avwx.rest/api/metar/uudd
                                    EDIT> My bad, that’s miles
                                      I thought that was the whole idea for this module, that it would be international, yes?
                                        stephenmelody
                                        Russian Viz is in metres, so they’d want to see 1500m I’m guessing.
                                        That’s the problem, you’re creating the ability to call weather from international airports but each country / region reports differently. The good thing with AVWX is it tells you the unit to use, so you could just append after the value the unit identifier, so in your example you have:
                                         "Visibility": "9999",
                                        and in the units section:
                                        "Visibility": "m",
                                        so you could concatenate it to be:
                                        visibility: 9999m
                                        Does that make sense? Have I answered the question?
                                          stephenmelody
                                          The three main differences I know of are:
                                          USA reports altimeter in inHg, rest of the world is hPa (or mb, which is the same thing).
                                          USA Reports viz in Statute Miles, rest of the world in Kilometers
                                          Russia reports wind speeds in Metres/Second, rest of the world in Knots. (they also report altitude in meters above the ground and the rest of the world uses feet above the ground (or sea level, that also depends…)
                                          That’s when flying becomes fun, so in the UK, you fly at an altitude in feet, a speed in knots (nautical miles per hour) and with a visibility in kilometers… talk about mixing up units!!!
                                            Yup, I’m on it
                                            • 6
                                            • 3 / 6
