    4k Dashboard
    21 Posts 13 Posters 16.8k Views 17 Watching
      Aardal1
      Dashboard
      27" 4k monitor mounted inside the wall.
      Glass front panel, with vinyl cutout on the back. Mounted with velcro.
      Raspberry Pi 4 Model B
      Using it for smarthome monitoring, calendar, power usage++
      Modules:
      Clock
      System stats
      Calendar_monthly
      Calendar
      Netatmo
      Yrthen
      MMM-Tibber
      Iframe-ping (smarttiles)
      Anylist
      Nowplayingonspotify
      teslamate
      Imageslideshow
      Newsfeed
      All tweaked quite a bit with custom CSS.
      Currently working on getting the Ring doorbell module to work. I want it to show the video feed as a overlay on the imageslideshow when someone is at the door. Cant get it to trigger. Wonder if its crashing with the iframe-ping module.
      Its been a pain that the Pie is not liking portrait mode. Everything is super slow and lagging. Running fine in landscape mode. Because of this the configuration has been a real test of my patience…
      C S 2 Replies Last reply Reply Quote 7
        mlhote
        Hello
        great job
        that’s wonderful
        To rotate the screen you did it in css or with the classic interface.
        If it’s not too much abuse can you show us your custom css to learn…
        • P Offline
          Python
          Very nice layout!
          I have a Model 3 on order and already have teslamate setup. I’m looking forward to making a “Tesla Dashboard” specific for my garage similar to how you’re showing your P85 and power use.
          • C Offline
            cyberphox @Aardal1
            @aardal1 I wish I had to patience and creativity to really dive into CSS…instead I just wait for something like this to come along and shamelessly try and copy the code!
            Great looking board!
            cowboysdudeC F 2 Replies Last reply Reply Quote 0
            • cowboysdudeC Offline
              cowboysdude Module Developer @cyberphox
              @cyberphox Eh don’t feel bad… I many of us do the same. LOL
              I’d be VERY interested in his css for this…
              BKeyportB 1 Reply Last reply Reply Quote 2
              • F Offline
                frog @cyberphox
                @cyberphox
                Have you looked at https://github.com/tchellomello/python-ring-doorbell
                C 1 Reply Last reply Reply Quote 2
                • C Offline
                  cyberphox @frog
                  @frog I haven’t…although I’m unsure what it has to do with CSS
                    mvrlogins @Python
                    @python
                    I have a Model X and also use Teslamate
                    I’ve incorporated that into my mirror as below:
                    alt text
                    Using this module -
                    https://github.com/spitzlbergerj/MMM-TeslaLogger
                    And a little node script within an iframe to get the map
                    N6NGN 1 Reply Last reply Reply Quote 0
                      SoleLo @Aardal1
                      @Aardal1 can you share your custom code for MMM-Teslamate?
                      • N6NGN Offline
                        N6NG @mvrlogins
                        @mvrlogins Nice mirror… How did you keep the calendar from fading the time section…I’ve been trying and can’t find out where to turn off the fade… Thanks
                        Dennis N6NG
                          sdetweil @N6NG
                          @N6NG from the doc
                          • N6NGN Offline
                            N6NG @sdetweil
                            @sdetweil I don’t find fadePoint in the config.js file. Do I need to add it or is it in the calendar.css ?
                              sdetweil @N6NG
                              @N6NG those are config.js settings
                              if not specified, then the default value is used.
                              so you can use
                              fade: false
                              to turn off fade
                              or
                              fadepoint:4
                              (for example to start the fade at 4th entry)
                              • N6NGN Offline
                                N6NG @sdetweil
                                @sdetweil I added the fadePoint ok but it only works on the event name. All the times are still faded which is what I don’t want faded.
                                • BKeyportB Offline
                                  BKeyport Module Developer @cowboysdude
                                  @cowboysdude As am I. This would be VERY interesting.
                                  • N6NGN Offline
                                    N6NG @BKeyport
                                    @BKeyport That’s why I asked the person with the 4K mirror.
                                    He had the calendar without faded times and that’s what I want to do.
                                      mvrlogins @N6NG
                                      @N6NG
                                      Sorry for the late reply - missed your post
                                      Following is my calendar config in config.sys
                                            module: 'calendar',
                                            position: 'top_right',
                                            header: 'CALENDAR',
                                              maximumEntries: 21,
                                              maxTitleLength: 25,
                                              fade: false,
                                              displaySymbol: false,
                                              timeFormat: 'relative',
                                              nextDaysRelative: true,
                                              dateFormat: 'ddd MMM DD HH:mm',
                                              fullDayEventDateFormat: 'ddd MMM DD',
                                                  symbol: 'home',
                                                  url: 'webcal://p49-caldav.icloud.com/published/2/abcdefghijkl......mnopqrs',
                                                  maximumEntries: 19
                                      Hope that helps
                                      • N6NGN Offline
                                        N6NG @mvrlogins
                                        @mvrlogins Thanks…
                                        Dennis
                                          rdwilbrink
                                          your mirror looks nice. Can you share your css?
                                          • G Offline
                                            greedyvegan
                                            thanks for this, it’s very inspiring.
