    Further module categories...
    11 Posts 4 Posters 7.3k Views 4 Watching
    • cowboysdudeC Offline
      cowboysdude Module Developer
      With all the new modules coming out it’s hard to tell where to put what at times…
      My suggestion would be to add sub-categories… I know it’s a lot of work [I run a forum] but at times to help people figure out where to post them correctly… :) Just an idea.
      Mykle1M Y J 3 Replies Last reply Reply Quote 1
        Mykle1 Project Sponsor Module Developer @cowboysdude
        @cowboysdude Dude, what forum do you run? :thumbsup_tone1:
        • Y Offline
          yawns Moderator @cowboysdude
          @cowboysdude
          Could you name some additional categories? I would avoid adding sub-categories, because users would have to work their way down the “tree”.
            Jopyth Moderator @cowboysdude
            For reference: I started a similar discussion a few months ago here. Except for the weather/environment category, all have been created.
            @cowboysdude What changes do you suggest?
            I think Utilities is the category that needs “refurbishing” the most. It is basically the category all modules go in, which have no other fitting category and we probably need one like it, but maybe we can try to split it up. My suggestion from back then still stands, we could introduce a Weather/Environment category. Are there enough module to justify a Smart Home, a Sensors (GPIO integrations), a Voice Recognition or a Configuration category?
            Also I agree with @yawns, new and changed categories would maybe be better than splitting some categories another time.
            Helpful sticky: How to troubleshoot
            Y 1 Reply Last reply Reply Quote 3
            • Y Offline
              yawns Moderator @Jopyth
              @Jopyth said in Further module categories...:
              Totally agree!
              possible categories
              • Smart Home
              • Sensors* (GPIO integrations)
              • Voice Recognition
              • Configuration
              Not sure what about the configuration category (I guess you intend sharing configurations?), but I support the other suggestions.
                My suggestion is putting in for instance under each Topic and separate each module into subcategories…
                The reason I say that is because when I was posting modules I had a difficult time trying to figure out where to put a couple of them… not sure where they fit.
                A great example is Utilities… looks like modules where dumped there because people couldn’t figure out where to put them.
                You have Voice control, thermostat control, network scanner, etc…
                Voice control is a mirror util
                Thermostat is a home util
                Network scanner is a mirror util…
                Things like that :)
                  Jopyth Moderator @yawns
                  @yawns Actually I was talking about modules for configuration purposes (Mobile App, Admin Interface, …), but maybe they should just belong to the general System category.
                  Y 1 Reply Last reply Reply Quote 2
                  • Y Offline
                    @Jopyth
                    Ah ok, that makes alot more sense to me :thumbsup:
                      Sorry @Jopyth I was thinking of further defining categories…
                        @cowboysdude So you would go with sub-categories, rather than defining new base categories? It not completely clear to me though, which categories you would split, and which subcategories you suggest? Or do you just want example below the categories, so it is easier to see where a module should go?
                        Also, maybe the future should go more into the direction of @MichMich’s module beta for showcasing modules.
                          cowboysdude Module Developer @Jopyth
                          @Jopyth No, I like your idea better! I also like @MichMich module beta!!!
