    Complete Walkthrough - Install MagicMirror on a PC - Windows 7/10
    324 Posts 55 Posters 864.3k Views 59 Watching
    • justjim1220J Offline
      justjim1220 Module Developer @jelbear
      @jelbear
      Just to be sure… You do have a folder named exampleImages within you MMM-BackgroundSlideshow directory???
      I just installed and ran this module on my Windows device and it works just fine.
      Looking at the error you posted above, it looks as if your exampeImages folder is missing.
      “Life’s Too Short To Dance With Ugly People”
      Jim Hallock - 1995
        jelbear
        I can confirm that the folder is there
        Modules were installed using git clone command while in the MagicMirror/modules folder.
        Is there anything different you have to do when installing modules under a windows system
        Currently I’m just doing the above command and then adding the required code to the config file
        justjim1220J B 2 Replies Last reply Reply Quote 0
          @jelbear
          Not that I can think of
          I’m not using a RasPi either.
          If I had one, I would try it to se if any difference.
          Sorry.
          Jim Hallock - 1995
            bhepler Module Developer @jelbear
            @jelbear - To my knowledge, the only difference between Windows and Linux systems is that you may have to specify the file paths slightly differently. Windows requires you to put any folder with a space in the name in quotes. This can get tricky when you’re passing in a string which is surrounded by quotes and also contains quotes.
            Is there a space in any part of your path to the exampleImages folder?
            • lavolp3L Offline
              lavolp3 Module Developer @jelbear
              This post is deleted!
                jelbear
                it somehow seems to have resolved itself
                i deleted the folder and redid the git clone and it is working, not sure what happened, but it is working now,
                many thanks for taking the time to reply
                  brandonbrown
                  @Mykle1 said in Complete Walkthrough - Install MagicMirror on a PC - Windows 7/10:
                  Install MagicMirror on a PC Windows 7/10 - Complete walkthrough
                  Thank you so much for this post! I’m new to the Pi and MagicMirror. Working on the PI remotely was a bit of pain and this allowed me to run MagicMirror on my main machine with VMWare Workstation.
                  First off let me say these instructions were ‘spot-on’ and I was up and running immediately.
                  As I added modules, I noticed some of them were not working, a.k.a. not loading any data. They would activate, say “loading…” and nothing else.
                  I researched a few of the modules I was using and found one step that needs to be on your list:
                  ‘npm install request’
                  After that, the modules in question began updating with data.
                  Thank you again for giving me a better dev environment to work in!
                  Brandon
                    Mykle1 Project Sponsor Module Developer @brandonbrown
                    @brandonbrown said in Complete Walkthrough - Install MagicMirror on a PC - Windows 7/10:
                    Well, the modules that require that package should tell you in their respective readme files but thanks for the headsup. I’m glad you found the tutorial helpful. :-)
                      dstoianovici
                      Hello, I had an EACCESS error thrown when launching the MM as directed in this thread. I was able to fix this error by changing the port number from 8080 to 9000 in config.js
                        sdetweil @dstoianovici
                        @dstoianovici yes,if some other app is using 8080 then u have to change it… mine is on 8086. 8080-8085 are in use
                        • C Offline
                          CliffordW
                          It should probably be easy, but I can’t seem to find it. What is the command I can use to start MM on Windows 10 startup?
                          • C Offline
                            CliffordW
                            Thanks for a great guide, got me up and running quickly. Can you guide me where do I insert the commands to rotate the display to portrait mode?
                              bdream
                              @Mykle1 Many thanks for this description!
                              Just got it run under Windows 7. That will help to play and learn how to get own modules :nerd_face:
                              Two questions I have.
                              My MM is version 2.6.0. I planned to run updatescript from @sdetweil but failed. Yahe you any idea?
                              Is there an option to run MM in a window being able to shrink and move over the desktop?
                              cheers, bdream
                              S Mykle1M 3 Replies Last reply Reply Quote 0
                                sdetweil @bdream
                                @bdream come talk in the Updated Installer topic
                                https://forum.magicmirror.builders/topic/10171/anyone-want-to-try-updated-installer
                                  sdetweil @bdream
                                  @bdream F11 will take a window from full screen to not
                                    Mykle1 Project Sponsor Module Developer @bdream
                                    @bdream said in Complete Walkthrough - Install MagicMirror on a PC - Windows 7/10:
                                    Your F11 key should toggle between full screen MM and MM in a window
                                      Damn Sam, you’re just too fast!
                                        bdream
                                        F11 seems to be a got hint, even it comes from @Mykle1 or @sdetweil.
                                        Will try it this evening - thanks!
                                        cheers, bdream
                                        • O Offline
                                          OldShaterhan
                                          For me setup running MagicMirror on Windows 10 worked by:
                                          • cloning the repository
                                          • then edit package.json by changing following line:
                                            "scripts": {
                                              "start": "./run-start.sh",
                                          to:
                                            "scripts": {
                                              "start": "bash ./run-start.sh",
                                          Simple change, works in every location on my PC.
                                          blake_northrupB 1 Reply Last reply Reply Quote 0
                                            jagdambasoft
                                            $ npm start
                                            magicmirror@2.10.1 start C:\Users\Office\MagicMirror
                                            ./run-start.sh
                                            ‘.’ is not recognized as an internal or external command,
                                            operable program or batch file.
                                            npm ERR! code ELIFECYCLE
                                            npm ERR! errno 1
                                            npm ERR! magicmirror@2.10.1 start: ./run-start.sh
                                            npm ERR! Exit status 1
                                            npm ERR!
                                            npm ERR! Failed at the magicmirror@2.10.1 start script.
                                            npm ERR! C:\Users\Office\AppData\Roaming\npm-cache_logs\2020-02-25T06_03_03_308Z-debug.log
                                            What Will I DO
                                            J S 2 Replies Last reply Reply Quote 0
                                            • 6
                                            • 16
                                            • 17
                                            • 4 / 17
