    I have some problems about config file
    configproblem
    16 Posts 5 Posters 11.1k Views 4 Watching
      AlexHpoin
      Last two weeks,I have began my project.But until now,I have faced a hard problems.
      My config.js has gone through the check without any problem.
      but It still can not work.
      Could someone help me find out where is wrong?
      THANK YOU VERY MUCH!!!
      var config = {
      	port: 8080,
      	ipWhitelist: [], // Set [] to allow all IP addresses
      	language: "zh",
      	timeFormat: 24,
      	units: "metric",
      			module: "alert",
      			module: "updatenotification",
      			position: "top_bar"
      			module: "clock",
      			position: "top_left"
      			header: "US Holidays",
      						symbol: "calendar-check-o ",
      						url: "webcal://www.calendarlabs.com/templates/ical/US-Holidays.ics"
      			module: "compliments",
      			position: "lower_third"
      			module: "currentweather",
      				locationID: "1809062",  //ID from http://www.openweathermap.org/help/city_list.txt
      				appid: "c8d34ea2cd422XXXX4b1101e96e894d1"
      			module: "weatherforecast",
      			header: "Weather Forecast",
      				appid: "c8d34ea2cd422XXXXXXX101e96e894d1"
      			module: "newsfeed",
      			position: "bottom_bar",
      				feeds: [
      						title: "New York Times",
      				showSourceTitle: true,
      				showPublishDate: true
      • T Offline
        tomyboy96 Project Sponsor @AlexHpoin
        @AlexHpoin What happens when you boot it up?
          AlexHpoin @tomyboy96
          @tomyboy96
          It shows please create a config file.
          Thank you
          Mykle1M T 2 Replies Last reply Reply Quote 0
            Mykle1 Project Sponsor Module Developer @AlexHpoin
            @AlexHpoin said in I have some problems about config file:
            Are you sure it’s named config.js ?
            I just copied what you posted and it fired right up.
            • T Offline
              @AlexHpoin Have u saved the config file in the right place?
              • G Offline
                greda
                Hello,
                You must to have config.js in this path : cd /MagicMirror/config!
                If you use Putty
                If you use WinSCP
                If it does not work. I advise you to copy the original config.js.
                A 2 Replies Last reply Reply Quote 0
                • cowboysdudeC Offline
                  cowboysdude Module Developer
                  var config = {
                  port: 8080,
                  // [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.1.5”],
                  // [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.3.0/28”],
                  language: “zh”,
                  timeFormat: 24,
                  units: “metric”,
                  module: “alert”,
                  module: “updatenotification”,
                  position: “top_bar”
                  module: “clock”,
                  position: “top_left”
                  module: “calendar”,
                  header: “US Holidays”,
                  position: “top_left”,
                  url: “webcal://www.calendarlabs.com/templates/ical/US-Holidays.ics”
                  module: “compliments”,
                  position: “lower_third”
                  module: “currentweather”,
                  position: “top_right”,
                  locationID: “1809062”, //ID from http://www.openweathermap.org/help/city_list.txt
                  appid: “c8d34ea2cd422XXXX4b1101e96e894d1”
                  module: “weatherforecast”,
                  header: “Weather Forecast”,
                  appid: “c8d34ea2cd422XXXXXXX101e96e894d1”
                  module: “newsfeed”,
                  position: “bottom_bar”,
                  feeds: [
                  title: “New York Times”,
                  url: “http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml”
                  Did MagicMirror install without any errors?
                    It is for just this type of situation that I wrote this:
                    How to create a working config - For absolute beginners
                      AlexHpoin @cowboysdude
                      @cowboysdude
                      npm WARN prefer global coffee-script@1.10.0 should be installed with -g
                      npm WARN prefer global jsonlint@1.6.2 should be installed with -g
                      npm WARN prefer global colorguard@1.2.0 should be installed with -g
                      > uws@0.14.5 install /var/www/html/node_modules/uws
                      > node-gyp rebuild > build_log.txt 2>&1 || exit 0
                        AlexHpoin @greda
                        @greda YES.I have saved my config.js to the right place```
                        /config/config.js
                          AlexHpoin @greda
                          @greda I use :
                          sudo mv /var/www/html/config/config.js.sample /var/www/html/config/config.js
                          to create my config file,and then reboot.
                            cowboysdude Module Developer @AlexHpoin
                            @AlexHpoin You should just be in the directory
                            ~MagicMirror/config
                            and type
                            cp config.js.sample config.js
                            Mykle1M A 2 Replies Last reply Reply Quote 1
                              Mykle1 Project Sponsor Module Developer @cowboysdude
                              @cowboysdude
                              Isn’t it crazy?
                                @cowboysdude I did…but it does not work…
                                  @AlexHpoin At this point I would just start over.
                                  There’s really no way of telling what happened. There seems to be an error of some kind, whether it’s file permission or something didn’t install correctly.
                                    I’m curious. Did you even try or look at this?
                                    https://forum.magicmirror.builders/topic/4528/how-to-create-a-working-config-for-absolute-beginners
