    work in progress
    18 Posts 7 Posters 13.7k Views 6 Watching
    • C
      cornusandu
      Hello Guys,
      work in progress , i think i will be done sometimes in January as i still want to cut a hole in the plywood and install a motion sensor to shut down and start my monitor. the raspberry will be running continuous until it will die i guess. Magic mirror and also on the background is running Alexa which i changed the wake word to Siri as i have in the area also an Echo so that will not respond both of them. I still have to see about microphones install situation and also am thinking to try two microphones on the same usb port for a better wake word situation considering position and distance of caller. I will cut a hole in the wall so that it will be a very thin frame. I was thinking also if you guys have any ideas if for a longer life of raspberry is better to run continuously or to shut down at night with a smart power plug at night and IFTTT at day when my cell (and of course myself ) are not home.
      0_1513762453628_IMG_0709.JPG 0_1513762503749_IMG_0861.jpg 0_1513762512127_IMG_0862.jpg 0_1513762521527_IMG_0864.jpg 0_1513762528332_IMG_0867.jpg 0_1513762535498_IMG_0869.jpg 0_1513762542747_IMG_0870.jpg 0_1513762553673_IMG_0871.jpg 0_1513762563773_IMG_0873.jpg
      E D 2 Replies Last reply
      Reply Quote 4
      • cowboysdudeC
        cowboysdude Module Developer
        Great job!
        C 1 Reply Last reply
        • C
          cornusandu @cowboysdude
          @cowboysdude thank you. It is quite a ride .
          cowboysdudeC 1 Reply Last reply
          Reply Quote 1
          • cowboysdudeC
            cowboysdude Module Developer @cornusandu
            @cornusandu It is a fun ride though :)
            C 2 Replies Last reply
            • C
              @cowboysdude Ohhh yeahhh :) a lot of head scratching and a bit of swearing. I reinstalled about 20 times . But finally got it working smoothly.
              • C
                @cowboysdude Super cool community. Any advice on raspberry power? Should I cut electricity 12 hours a night with a smart plug? Or run it 24/7? Which is better for longer life?
                Mykle1M cowboysdudeC strawberry 3.141S 3 Replies Last reply
                • Mykle1M
                  Mykle1 Project Sponsor Module Developer @cornusandu
                  @cornusandu said in work in progress:
                  In my opinion, I would leave it running. As long as you keep the temp of the Pi somewhere in the neighborhood of 40°C. Personally, I prefer that to 365 unnecessary boots a year.
                  • cowboysdudeC
                    @cornusandu I leave mine running all the time… have had no issues after a year so far :)
                    • strawberry 3.141S
                      strawberry 3.141 Project Sponsor Module Developer @cornusandu
                      @cornusandu if you just turn off the electricity is not that good for the hardware in terms durability, but if you create a shut down routine e.g. 5min before, than it should be fine.
                      Reply Quote 1
                      • C
                        cornusandu @Mykle1
                        @Mykle1 He is running at a stable 65 Celsius
                        • C
                          cornusandu @cornusandu
                          I mounted back the fan. Now is down to 38.5 Celsius
                          Mykle1M 1 Reply Last reply
                          Reply Quote 1
                          • Mykle1M
                            I rest my case. :-)
                            Excellent!
                            • E
                              enettekoven @cornusandu
                              @cornusandu Pretty slick looking MagicMirror! What monitor did you use?
                              • C
                                cornusandu @enettekoven
                                @enettekoven It is a very old 19 inch 3d monitor, My wife decided that she want a curved monitor and this one was just sitting in the garage
                                • N
                                  noelandrews
                                  Very cool! How have you done the full length mirror? Is that film over glass?
                                  • D
                                    doubleT Module Developer @cornusandu
                                    As everyone else said, leave it running, don’t cut the power without shutting the RasPi down safely first. Two advices I would give you:
                                    1. When everything is set up and running, and everytime you add a new feature/module, make an image of your sd card as backup!
                                    2. Think about a UPS, Uninterruptible Power Supply. There are some add ons that combine a batterie that provides power for a few minutes and a circuit that will detect the power outage and initiate a safe shutdown. And when the power goes back on, it will go back to normal.
                                    I learned both the hard way, but I’m still not done finding/setting up a good UPS solution.
                                    • C
                                      cornusandu @noelandrews
                                      @noelandrews it is polycarbonate two way mirror. A but expensive but it looks really good. Size 120 cm. 60 cm.
                                      • C
                                        cornusandu @doubleT
                                        @doubleT thank you. UPS, I will have to shop around for something small and strong enough
